Question about Garmin StreetPilot 2620 GPS Receiver
Start-up loop For some reason whenever I turn the unit on the main screen that says streetpilot comes on then the saftey warning not to use it while driving then when you click ok it goes back to streetpilot 2620 and keeps making the same circle. Is there any way to reset the unit. I know by holding down certain buttons while turning the unit on you get different screens is there any way of making it read and display maps again
    Sergeant:
  • 279 Answers
Hold down PAGE, MENU, and FIND then turn unit on to perform a Master Reset. That might do the trick. There are some other undocumented features you might be interested in available here: http://home.socal.rr.com/diverhank/SP26X0UndocumentedFeatures.htm#_Toc144991134 That site also has links to manuals, if you need them.
Posted on Aug 30, 2007
SOURCE:
I have a toshiba satellite L445D-S5976 and I am experiencing the black screen but this is different from most of the problems I've seen on here, whenever I try to turn it on the fans start up fast then...
hey.. Well this is one of 2 problems, More than likely the BackLight on your screen is dead. Dont worry that's a common problem and the fix basically is to replace the screen. You can order the screen online and then simply remove the old one from the housing by first removing the rubber plugs then the screws hidden under the plus. lift the lid off and unscrew and replace the screen. The reason why the monitor may not be turning on is because you need to switch the primary display. If you look carefully at the keyboard you will notice that there a key written Fn usually in blue, Thats the function key. There will be another key with a blue Monitor symbol usually f8 (may not be the same on yours). you hold Fn and press that key to enable the external Monitor.
If you were doing that then this is the reason for your problem. THE GPU (graphics processing Unit ) usually called the graphics card is Damaged. unfortunately yours is built onto the ma board which means to fix this you have to replace the entire board. But thats a very very rare issue. I'm betting that the First (above) one i mentioned about the Back Light is the reason for your problem..
Becuase the fan turn on loud and then settles down it means the main board is functioning properly ad the system is booting its just that you cant see it because of the back light and not switching the display unit.
Dec 28, 2012 | Computers & Internet
Gaarmin 2620
Hi hummer49....Your GPS Software needs to be updated by clicking on the following URL: http://www8.garmin.com/products/webupdater/howtoinstall.jsp If you have misplaced your Owner's Manual, you may download a copy by clicking on the following URL: http://www8.garmin.com/manuals/439_OwnersManual.pdf Please update your post if you need further assistance and also to update me on your progress....good luck my friend
Aug 06, 2007 | Garmin StreetPilot 2620 GPS Receiver
Top row of number and letters not responding when I punch them in. for example #1 comes up #4, #2 comes up #5,and #3 comes up #6! How do I resolve?
To calibrate your Streetpilot c-Series touch screen, follow these steps:
    1. Begin with the unit turned OFF and unplugged from a power source.
    2. Power the unit ON, continue to hold the Power button for 1 minute.
    3. A screen will display instructing you to Press dot in the lower left corner.
    4. Release the Power button and touch the sequence of dots until your unit displays, Calibration complete.
    5. Your unit should now function normally.
I hope this helps. Please rate my reply. Thank you.
Jun 27, 2011 | Garmin StreetPilot c340 GPS Receiver
Why does my c340 keep losing satellite reception
Hello there:
please follow these instruction and this should help if not let me know and i willcontinue to get you more information for you
nstructions
  1. Step 1 Calibrate the screen of the Garmin StreetPilot C340. If the touch screen does not seem to respond when you hit it with your finger or a stylus, you may need to calibrate it. To do this, turn the unit off and then hold down the "Power" key for approximately one minute. You will see a calibration screen come up that will recalibrate the GPS2_bing.gif unit.
  2. Step 2 Reset the Garmin StreetPilot C340. If your GPS unit is not responding or is stuck on a particular screen, it may need to be reset in order to operate. To reset, remove the face plate of the unit by gently prying it off. Locate the "Reset" button under the face plate and press down in order to restart the device.
  3. Step 3 Change the fuse of the Garmin StreetPilot C340. If the fuse blows on the GPS, you will need to make a replacement using an ACG/3AG 2 amp fuse. Unscrew the adapter cord at the end and remove the fuse found there. Put in the new fuse to see if this returns function to the unit.
  4. Step 4 Update the software for your Garmin StreetPilot C340. If the GPS is not providing you with correct directional information, you may need to update the software or download new maps onto the device. Connect the Garmin StreetPilot C340 with the USB cord to your PC and log on the Garmin website for available updates.
Jan 15, 2010 | Garmin StreetPilot c340 GPS Receiver
The garmin 2620 will not load maps
You are caught in a loop most likely caused by a failed microdrive. Search Garmin 2620 cornice for a thread that is likely to provide the information about the failure you are experiencing. In short, if it is the Cornice drive that has failed you will find it very difficult to repair, if not impossible depending on your level of expertise and ability to find a used part for repair as the drives needed are no longer manufactured or readily available.
Aug 03, 2009 | Garmin StreetPilot 2620 GPS Receiver
Street pilot 510 can't get rid of saftey mode ex-rental
Safety mode (prevents you from changing routes whilst in motion) is enabled disabled in the system options.
Found by navigating Setup (spanner at bottom of main screen) --> System --> Safe mode
Mar 01, 2009 | Garmin StreetPilot c510 Deluxe GPS...
Map update gone bad
Connect it to a PC and delete the map(s) using windows explorer.
Oct 20, 2007 | Garmin StreetPilot 2620 GPS Receiver
Garmin Streetpilot 2620
Most likely your hard drive is gone bad. Push "menu+find" buttons then turn on, you will get diagnostic screen, it will show if your cornice drive is bad. It will say"Cornice Dive removed"4f3efc6.jpg
Sep 23, 2007 | Garmin StreetPilot 2620 GPS Receiver
Garmin Streetpilot 2620 Goes not go to maps
I would like to know the same thing! My father has the same unit and he updated his with version 4.80 & web updater (both free) on garmin and it solved his problem. I believe my problem is that my North America v8 did not install properly. ????? well see
Aug 25, 2007 | Garmin StreetPilot 2620 GPS Receiver
Garmin streetpilot 2620
Hold down Menu-Find buttons if you get this screen, your hard drive gone bad. Garmin charges $275 to replace your unit8863097.jpg
Aug 16, 2007 | Garmin StreetPilot 2620 GPS Receiver
Garmin StreetPilot 2620 GPS Receiver Logo
96 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
