Question about Sony CDP-CX225 CD Player
Problem with a continuously rotating disc tray in my cd player.
Hi, first time posting here so I'm not sure if I've posted this in the correct place. Anyway my problem is my Philips CDC-751 5cd carousel changer/player suddenly stopped operating two days ago when I went to change a disc. Now the unit powers up but the loading tray inside automatically starts rotating and continues to do so unless the unit is powered off again. When it does this, the rotation of the tray is also accompanied with a grinding noise like maybe a slipping gear cog somewhere in the motor. I've took a look inside but I can't identify the problem. I'm gutted about this as I have had this unit since new for quite some years now (1996) and its never had an issue before and apart from this, the unit is in otherwise great condition for its age inside and out. I didn't plan on finding a suitable replacement for it in the near future and this is totally unexpected. Thanks for any suggestions to the problem.
4 Suggested Answers
SOURCE: CD player does not rotate
Hi there.
There could be a couple of reasons. I doubt very much that it is due to the lens. First thought is that it is probably the locking mechanism. If you look at the cd loading mechanism, there is a small plate with a locking tab that moves into place to hold the carousel still when the unit is loading a cd. This plate slides along the bottom of the unit between the cd loader and the carousel.
Secondly, it could be that the carousel is jammed on the rotating platter that it moves on. A couple of screws and it should come out - be carefull not to bend anything!
Thirdly, check the stepper motor that turns it - but I doubt this is the problem either as you said you couldn't turn it by hand either. You will need to remove the carousel to do this.
Good Luck !
Posted on Mar 07, 2009
gopakumarg43
  • 75571 Answers
SOURCE: Where can I find a Manual for a Sony CDP-CP545 disc player ( 5 Disc Ex-change system)
Click here to download it.
Posted on May 01, 2012
SOURCE: CD Changer won't finish loading a CD
I had the same problem and found the cure for it. The drive belt was streched and when it started to close on the disc, the belt would slip and eventually show loading error..The two belts cost $4.50 at belts plus. Hope this helps you
Posted on Feb 22, 2013
COPT CD
I think you just answered your own question... Did you say that when i you put in a blank disc, it says blank disc? Thats correct. And whats is a B-Deck?
Oct 06, 2008 | Sony RCD-W500C 5-Disc CD Recorder
Ford Freestar 2006 cd player not working, says "check player"
test this topics and fix it. God bless you
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Jul 25, 2013 | Cars & Trucks
SL-PD888 rotates disk tray continuously after turn on
The tray is usually detected by an opto interrupter device. When they or the interconnecting circuits fail this is the symptom you will have. It can also be due to the alignment of the tray. This is why all of my CD players are not changers.
Dec 05, 2012 | Technics SL-PD888 5-Disc CD Changer
My aiwa cd disc rotating tray is not working i don,t know what's wrong with it
hi there i know wht is problem rotary changer systems like 5 disic or 3 dics chnager.i have 2 oprions for that 1 is,from cd chnager belt small belt between motor another also mechanism like small tears lack white if there not good oily enaugh,maybe stock with tooth,DO u hear motor when u tray chnage disc 1;2;3? if motor burn rotary change then never will work,Some times belts getting older in cd rotary changers.the gey slepery,like flashy,but i hope will help your problem.Regards,Emil
Sep 13, 2012 | Aiwa NSX-DS55 CD Shelf System
My disc tray won't open the lights turn on and work but the disc tray just won't open. How can I fix this?
hi,
You have to check two things.
1. You have to check the tray loading belt in the mechanism. To see the same you should remove the mechanism.because the loading belt is beneath the cd tray. As it is cyberhome it will be very difficult to remove the mechanism for an user. if your capable for doing the same then make try. Because you have to remove the top cover then the back panel, then the mechanism. Take care the mother board is attached to the mechanism.
2. You have to check the cyberhome dvd player will show this type of complaint if the Spindle motor is faulty (oppen or short ). Spindle motor is one on which the cd rotates. It will not cost a lot.
ok
May 05, 2011 | Cyberhome CH-DVD 300 DVD Player
I cannot get the progressive scan off. I have a zenith xbs448 vcr/cd combo
Hi -
The instructions for switching progressive scan off have been posted on FixYa numerous times, but I'll save you searching for them and post them again . . .
1. Remove any disc from the unit and close the disc tray.
2. Wait for the DISC message to appear on the display
3. Hold the STOP button on the front of the player for at least 5 seconds then release.
PSCAN should disappear from the display on the front of the player and the video output should return to the standard interlace setting
If you are still unable to switch PSCAN off, please post back for further assistance.
Regards,
BElectric
Apr 24, 2011 | Zenith Televison & Video
Slide tray won t seat on projector
Try a couple of things:
1. Turn on the projector & cycle it in "Reverse" 3 or 4 times (without the tray). Do the levers that move the tray move correctly? If so, do you have another tray you can try? If another tray works correctly, follow Step #2.
2. The 140-Tray has to be in the "zero" position for the tray to seat on the projector. Check to make sure the Locking Ring (the ring is in the center of the tray & keeps the slides from coming out) is TIGHT on the top of the tray. Once checked, turn the tray upside-down. Refer to Page 8 in your owners' manual (if you don't have one, I've made an image of the page, below). You have to make sure the plate on the bottom of the tray is lined up at the notch at shown.jauburn_12.jpg
If this helps, please leave positive feedback for me @ FixYa.com. If you need more help, please re-post!!
Apr 13, 2011 | Kodak Carousel 5600 Slide Projector
I have the Denon CDR-W1500 recorder and the recording side no longer functions. It doesn't have that many hours of use. The tray doesn't recognize a blank cd but both sides will playback discs. Your help...
Your original post said it was blank discs that didn't work.
Now it's ALL discs including pre-recorderd ones. THAT changes things considerably.
Is it audibly rotating the disc once it's loaded?
May 21, 2010 | Denon CDR-M30 CD Recorder
Sony CDP-CX225 CD Player Logo
22 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
