Question about Refrigerators
HUSKY FASCU MOTOR RUNNING FRIDGE NOT COOL
IFIXALL
  • 868 Answers
SOURCE: Whirlpool Fridge not cooling
Check de-frost timer.
Posted on May 21, 2008
wheelshot
  • 102 Answers
SOURCE: Amana refrigerator stopped cooling.
Have you been hearing a clicking noise coming from behind the unit? This is the first indication of a failed compressor relay. Pull the unit out and unplug it. Remove the back cover and go to the compressor. You will find a device on the side of the compressor that has the wires hooked to it. This is the compressor relay and overload. It may be under a black cap. Remove the cap to access it. It may have 2 pieces to it or it may just have the 2 pieces encased in a white and tan box. Remove this box and shake it. If it rattles like gravel in it then it is bad. If it is in 2 pieces then it will have a brown relay. This is the piece that will rattle if bad. The white and black piece with one wire is the overload. They most never go bad. Use this replacement part kit...8201786 and follow the detailed instructions included in the kit. Thanks for the question. Hope this helps.
Posted on Apr 11, 2009
  • 2330 Answers
SOURCE: Fridge Motor
which one?evap fan motor or the condenser fan motor?i've seen the evap fan blades in the freezer wear out in the center where it slides onto the motor shaft so when the motor comes on the blade doesn't spin with it,need a new blade,or if the freezer is on top the drain blocks and the air vents freeze up,is there water leaking anywhere or ice on the freezer floor?need to send a little more info,also model number would help
Posted on Jan 23, 2010
heatman101
  • 43501 Answers
SOURCE: 2 yeaor old kenmore fridge not working, motor runs
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jul 12, 2010
ginko
  • 19396 Answers
SOURCE: Motor runs, freezer defrosting and fridge won't cool
If you have frozen coil at the back of the freezer section, then the defrost thermostat is usually failing. Allow the fridge to defrost completely overnight. If the fridge restarts cooling immediately after defrost, then the problem was the defrost system. In that case the fridge will stop cooling again in a couple of days, as soon as the evaporator coils restart freezing and the condenser goes under stress with the whole cooling system loosing efficiency.
Posted on Dec 09, 2011
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
I have a Matsui MUL1107WW fridge and the motor appears to be cutting out when the fridge gets too cold. Is this normal ? or does the motor need looking at ?
The compressor motor only needs to run to cool the fridge down.
Once the fridge is cold enough the compressor motor will switch off.
The compressor will start again when the fridge warms up
May 02, 2011 | Refrigerators
Both sides are warmer than should be. motor running nonstop
You refrigerator needs regassing that is why things are not cooling. Your sides of fridge are hot because the motor keeps running to keep what gas is there flowing though the lines trying to cool fridge
May 25, 2010 | Maytag MZD2766GES Side by Side...
Freezer is cooling, but refrigator is not cooling
take a look at your evaporator fan motor in the freezer to make sure it is running and not built up with ice around it. this fan motor pushes the cold air from the freezer into the fridge to cool the fridge. you say the freezer is "cooling" , is it freezing??
Oct 14, 2009 | Hotpoint Refrigerators
My cda554 beko refrigerator not cooling
hello there.........is the refrigerator motor running...(not the fan)...if this is running...pull the fridge out for access.....check the smallest diameter pipe on the compressor for heat.(not the small charging stub which goes nowhere)...in normal operation this small pipe should be quite warm to hot.....if its not it is possibly due to an internal gas leak....fridge motor will run but not cool the fridge.....if the motor isnt running but the internal fridge light is on when you oen the door it is possible the thermostat (temp control) needs replacing
Regards Sir Galahad
Jun 22, 2009 | Frigidaire FRS26R4A Side by Side...
Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
May 17, 2009 | Samsung Refrigerators
New fridge will not cool or freeze
By motor do you mean fan or your compressor is running if your compressor is running but it is not getting warm to the touch then you have no refrigarant in the system
Mar 31, 2009 | Frigidaire FRS3R5EMB Side by Side...
Nov 25, 2008 | Jenn-Air JCD2389G Side by Side...
Fridge is not cooling or freezing
can you tell me the model # on the fridge please? the motor is running continuously because it's trying to cool the fridge. it may be a few things, the defrost thermostat, the fan motor itself or the compressor.
Sep 13, 2008 | Magic Chef Refrigerators
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
