Question about Rival Gr-825 20 Inch Electric Griddle
Replacement grease tray - Rival Gr-825 20 Inch Electric Griddle
Subzero 650 Drip tray full of water and factory grease....
Grease or oil,,,,,its common for some oil but if its excessive it could have a leak "refrigerant leak"...Does it cool?
Jul 25, 2015 | Sub-Zero 650 / O Bottom Freezer...
Replacement greese tray for george foreman grill GR44TMR
Here is the link to the company so you can order the part you need
http://www.georgeforemancooking.com/support/default.aspx
In the mean time, you can fashion a grease tray out of some aluminum foil. Enjoy your grill.
May 31, 2009 | George Foreman GR44TMR Indoor Grill
I have a George Forman GRP46R. I'm having a drip tray problem where the grease is going under the unit and then dripping from the bottom. Some of it goes in the tray but the majority of it goes under the...
Since I accidentally left my drip pan inside the unit and preheated the unit without checking, I am now without a drip pan. The unit really heats up fast and likes to melt plastic. Anyhow, I used a cookie sheet underneath that has a lip around it to catch the drippings. I would suggest that you place your whole unit on a cookie tray so no matter where the grease runs out it will go on the cookie sheet and not your counter.
Oct 14, 2008 | George Foreman GRP4P Indoor Grill
Replacement grease catcher
I am using a disposable foil loaf that I bent to fit in the drip space.
May 18, 2008 | George Foreman GGR50B Grill
Tray Sticking on CD Player
reoccurring tray problems are a paim. It mauy be a spot of oil or grease on the tray motorbelt, or the wrong belt fitted, and or dry failing bubricant to opening cam and sliders. Best approach is to strip and clean everything, lube only with white plastic grease, and sparingly. I use graphic powder on tray sliders, be careful not to get lubricants on drive belts. try next size down belt also, or be sure the belt fitted is 2.0 mm crosssectional area
Dec 16, 2007 | Teac CD-P1250 CD Player
CD Drive not Ejecting properly
Hi, Since the warranty period has expired I will assume that the CD/RW has been in use for some time. Normally a small belt powered by a motor drives a gear that slides the tray out. Sometimes this belt is loose, warped or plain cut. Replacing the belt should solve the problem. You have to open the CD and it is near the front just below the tray. In other instances, the grease on the toothed railing at the sides and/or underneath the tray gets gummed up, cleaning and repacking with new light grease should take care of that. Rarely (but still does happen), the motor itself burns up and replacement (if you can get the part) is in order. An interim fix is to push a small straightened metal paperclip at a small hole below the tray cover/lip and slightly push till the tray partially opens. You can then manually pull it out. Hope this be of some help/idea to you. Good luck and kind regards.
Aug 27, 2007 | Samsung (SH-W08AENB) DVD±RW Burner
Trays locked
remove the tray out & put the grease on gears under the tray
Apr 01, 2007 | Philips CDR795 2-Disc CD Recorder
Rival Gr-825 20 Inch Electric Griddle Logo
48 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Henry  Thomas
Henry Thomas
Ric Shull
Ric Shull
Level 1 Expert
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
