Question about KitchenAid Ovens
Oven buzzer doesn't work
Hi the timer works but the buzzer doesn't sound. I have kitchenAid glass top oven, probably 5-10 years old. i have the control panel open but can't identify the buzzer. Is this an easy fix?
jsrock516
  • 5911 Answers
SOURCE: Frigidaire Model FEFL78CSA oven not heating
I apologize for not getting back to you sooner. I tried to respond to your question yesterday, but the web link was not working. Your assumptions are probably correct as the ERC controls all the oven features on an electric range. This is a fairly simple repair job that any do-it-yourselfer can accomplish.
The ERC is easily accessed by removing the back panel of the operator console. The circuit board is screwed in place with a series of wire connectors. Most models have the wire color coding printed on the circuit board for ease of identification. In addition, there should be a wiring diagram located either inside the console, or on the back of the range. This will also list the color codes. If not, I would recommend you label all wiring BEFORE removing to ensure everything is reconnected correctly (a digital camera can come in handy as well).
New ERCs generally do not come with the overlay. This is the plastic printed face-piece that covers the front of the board with all your controls and numbers. Some manufacturers provide this with the new ERC, but MOST do not. The existing one can be reused by carefully removing and reinstalling to the new ERC. You may consider ordering an overlay too if yours is in bad shape.
You can order a replacement at searspartsdirect.com. Pcappliancerepair.com also carries the part for just a few cents cheaper. I recommend the sears website for the helpful exploded view illustrations. Just type in your model number and look under the "Backguard" heading for item number 20 (part #316207529). The overlay is listed as item 20A (part #316220804). If you wish to save a little and order from the other website, use the part numbers provided by Sears for your search criteria as I could not find your model number listed.
Please ensure you UNPLUG the appliance before servicing. No special tools are required. If you have questions, please post back and let me know. I hope this helps you.
Posted on Nov 28, 2008
SOURCE: THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Posted on Dec 08, 2008
SOURCE: ge profile advantium 120, scb1001 oven, display panel out
My GE Profile Advantium120 interior lighting it out .What do i do to replace these bulbs.
Posted on Apr 06, 2009
localwonder
  • 6784 Answers
SOURCE: Kenmore gas Range -- Control Panel not working
Hi. your assessment is correct. when you have normal operations with the stove top and the control panel is blank or non operational, this will confirm either a wiring harness issue or a dead control circuit board. The wiring harness can sometimes become lose or the connectors can become corroded but, in this issue, i am sure its the ECB(electroninc control board). In this case, you will have to replace the board it self.
Please rate and god bless:)
Posted on Apr 16, 2009
Turned off breaker for 30 seconds. Display returned.
Posted on Jan 20, 2010
KitchenAid gas convection oven model # kgst307hbl4 won't turn off
seems like the safety switch not work. be careful
Mar 27, 2017 | Ovens
Oven beeps and flashes F1 Glass top burners work but oven doesn't.
F1 is for the ERC failure and it will need to be replaced. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Dec 05, 2012 | Amana AOES3030 Electric Single Oven
Frigidaire wall oven CPEB30S8CC2 lower element does not work
We have a Frigidaire CPE30S8CC2 with the bottom bake element not working. We tried to replace it with no luck. The old element does not look burnt out at all. The timer, clock and broil all work just fine. The bake button works and you can set the temp. it just doesn't actually heat up at all. There are no knobs on the controls for any cook top. it is all on a circuit board for overn only. help?
Jul 16, 2012 | Frigidaire Ovens
Lower oven will not common. The button to ignite the oven doesn't light up to start .
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 24, 2011 | KitchenAid Ovens
Kitchenaid superba electric oven (includes convection feature) and the entire digital panel suddenly stopped working after 6 years of perfect service. The stove top burners (acrylic top) appear to be...
It sounds as if the electronic clock/timer has failed and needs replacing. If you don't use the timer and don't need the clock it can be bypassed so that the oven will still work. A repair person should be able to do this fairly easily.
Feb 13, 2011 | KitchenAid Ovens
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Volume control candy oven timer
Switch off the oven, leave for 5 seconds and switch it back on.
Candy Customer Services asked for over £100 to have an engineer sent to my house, which I refuse as I thought the oiven was good.
I had to switch off all the electricity in the kitchen but after this 'reset' the oven turned to the normal 'high' volume.
Jan 12, 2010 | Candy Ovens
Oven door locked
ah, you lucky guy. You can try a hard reset by unplugging the range for a good 1/2 hour, then plug back in. Unfortunutely this probably won't work, as these clock/timers are notorious for only lasting a few years. You have to blow $150+ and replace the clock/timer. Note: A hair dryer will help you get the face off the old one to put onto the new one.
Nov 10, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kitchenaid oven KEBC107KSS03 won't heat after cleaning cycle.
I have a kitchenaid oven # KEBC107KSS03. When I set the temp to 400 the buzzer goes off saying the temp has reached the desired temp, the temp is only 250 and will take another 20-30min to reach 400.
thanks for your reply
Aug 25, 2009 | KitchenAid KEBC107 Electric Single Oven
Whirlpool super capacity 465 timer won't beep
clock timer and motot for a black electric oven 220Volt. oven number on plate at bottom of door is these two RGE 1600 P 5.8 and MK 93877451 4.4
rge
Jan 12, 2008 | Whirlpool GBS307PR Electric Single Oven
Ovens Logo
14 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
