Question about Freezers
Frigidaire freezer problems
I have a part with the number 240380100, it goes behind the ice box but I don't know how it goes in.My ice cubes are going behind the box when the drop down from the ice maker.
duby1990
  • 367 Answers
SOURCE: Ice Maker in Freezer in side-by-side not working
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
Posted on Nov 19, 2008
farfield
  • 462 Answers
SOURCE: Ice Cubes won't drop
Something is holding your Ice Slab at the bottom from your description.
Some causes are
1 Dirty - scaled up evap, or just dirty w muddy covering,
2 the vacuum breaking holes are stopped up If it is making a sla whith the evaporator warm no ice take a flashlight and hold it where its shining to the back of the evap and look for the light on th cube forming slots next to the ones your shining the light into Upper corners of each hole must be open.
3 The slab is freezing uneve most like cause is a stopped up distributor tube at the top thats feeding the water down the evaporator.
4 On some models thay had a closer fitting water curtian (the cover in front of the slab) and the top of the sheet touched this and caused the slab to stay uprite and continue the "slide" forward.If your curtian is of the older style and has metal hooks on it with verticle slots n the curtian look at the slots and see if the slots are worn making the whole curtian slide down ward I have seen this several times.4B On some older models there is also a plactic coated wire diverter on the bottom infront of the evaporator. If the palstic coating is gone or the bottom or is not even, the slab could hang up there. 4C If you have the newer plastic pins make sure thay are seated in the mounting properly.
5 Nickel plating could be comming off (any copper color on the lower 1/3 of the evaporator?).
6 I have seen some of the horizontal plates them selves be loose and not in flush try pushing and pulling on them especially the ones at the bottom. ANy that are loose and comming out is your problem.
This lengthy extrapolation is by no means all of the possibilities but most of the common ones. If this helps you solve your proble please rate me accordingly. If it leads you to the correct and completed repair WOULDNT WE MAKE A TEAM?? And Good luck to you.
Posted on Mar 18, 2009
MNTECH
  • 1543 Answers
SOURCE: GE TBX21ji Refridgerator/Freezer Factory Icemaker quit making ice
Normally, when the temp of the icemaker gets to about 14 degrees F, the icemaker goes into the harvest mode, turning on the mold heater and attempting to eject the cubes. When the heater has warmed the mold sufficiently to release the cubes, the ejector can continue and push out the cubes, then the icemaker fills with fresh water to beging to make a batch of ice again. Manually starting the cycle as you have done only allows the cycle to start without the temp sensor seeing the 14 degrees. The mold heating generally takes a couple minutes. If your mold heater or the temp sensor are not working, you will have to replace the icemaker, as they are not available as a repair parts.
Posted on Jul 04, 2009
myrlex
  • 674 Answers
SOURCE: american fridge freezer siemens KA58NA50GB. Freezer not freezing
If you are not capable to do that much better to call service Engineer to avoid big damage of your Freezer.
Posted on Apr 04, 2010
  • 389 Answers
SOURCE: I have a liebherr freezer with ice maker. ice maker broken
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
Freezer wont freeze ice cubes
Hello Friend, this is Z. Thank you for your post!
I interpret that you are having trouble with the freezer of your Frigidaire refrigerator not freezing ice cubes. It appears that your refrigerator is not properly cooling. Make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. Please allow 24 hours for temperature to stabilize. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your freezer status has changed successfully. Thank you!
Aug 26, 2014 | Frigidaire Freezers
Why are the cubes not breaking apart when dumping from the tray?
It is over-filling and the cubes are fused together... If the fill is adjustable, lower it, but you may need a new water valve... Frigidaire Water Inlet Valve 242252702
Jul 31, 2014 | Frigidaire FFSC2323LS 22.6 Cu. Ft....
Maytag MSD2651KES delivers crushed ice but no cubed
There is an metal arm that extends out behind the ice bucket that moves up and down when you press the cubed/crushed ice buttons. You need to take the ice bucket out and check the hardware. It's possible that some ice has managed to form in the unit and are blocking the motion. Remove any ice and check if the arm moves freely when you press the buttons on the refrigerator. Similarly, you should check if there is ice blocking the forward and back motion of the plunger in the freezer that bar sits on. This plunger is right next to the auger motor.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MSD2651KES/3048/0165000/W0703730/00013 has a picture of the ice bucket parts.
Dec 06, 2013 | Freezers
Check valve
If you are asking about the valve to the left of the water pump, it is used to dump water when the unit pumps the water out of the sump to keep sediment out. If it is bad, the unit will have short freeze cycles as the the valve is leaking water out causing the float to drop prematurely and causing small cubes and short freeze cycles.
May 11, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Ice maker will only make crushed ice and no cubes, what could be the problem
Open the freezer door.
Pull the ice bin forward about 3 inches.
Push the ice bin to the rear of the freezer until it seats and locks in place.
Then try to dispense cubes.
The ice bin can become dislodged from its locked position and the crushed ice solenoid activates automatically.
Sep 17, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Our subzero freezer has a new problem. The cubes
Ice cubes WILL BE slightly moist when they land in the ice bucket. they've just been slightly melted in order to eject from the ice maker. Stop playing with the settings, for starters. put them back to normal, i.e., middle setting, place thermometer in center of freezer, and if you can, one in center of fresh food. monitor after 24 hours, and for the next three days thereafter. freezer temps should be in the -5 - +5°F, sometimes up to 10°, fresh food should be 35-40, sometimes up to 44°at the normal settings. If you are not having temperature issues, see if you notice any frozen drips of water on the underside of icemaker, indicating a possible crack in the ice maker mold, or a faulty water valve. You didnt include your model and serial number, so not knowing the path of the ice shoot, some go out the freezer door, some slide over and get dispensed from the fresh food side. Its possible you may have a problem instead with the flapping door that opens to allow ice cubes to be dispensed, or similar type mechanism. If this door does not seat completely when its closed, it will leak warm air directly into the ice bucket, which would make them slightly moist, also too, this warm air can cause frost and ice to buildup near the warm air source...look for any unusual forms of ice and or frost leading up from the flapping door to the ice bucket. Also look for any gaps in the door gasket when closed, this warm air leak can also cause similar problems, but its most likely with the ice door. could be the door, the spring, the solenoid, or something else i wouldn't know without personal refrigerator inspection.
Mar 27, 2010 | Freezers
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
Km900mah short freeze cyles and small cresent cubes, also need the correct dip switch settings as they are not listed for this model thanks
In most cases, when you have the problems you are having, it is because the float switch is not set properly. On most machines, it's located in the front of the machine, just behind the front cover, next to the water pump. It is usually white with a black boot on the bottom. There should be 2 screws holding it. You can loosen the screws and slide the float switch all the way down to the bottom of the slots and then tighten them back. This will lengthen the freeze cycle and the cubes will become larger.
Your Model number is not in any of my manuals and the Hoshi tech site has no such model listed. Please check you model number. Can not get you dip switch settings if we don't know the machine you have. Plus Hoshi has changed their board several times. We would have to determine if yours has been changed, and if so, to which one.
Hope this helps you.
Dec 18, 2009 | Hoshizaki Freezer Commercial Ice Machines...
I have a Sub-Zero Model 501F freezer making ice cubes
Check defrost heater that goes into drain tube. When the drain freezes ;the defrost water spills into the icemaker.
Oct 08, 2009 | Freezers
Slow icecube maker
the harvest mode is started when the ice cube reaches around 14 degrees so lower the temp in the freezer or decrease the size of the cubes also make sure the fan vents in the freezer is unblocked. check the temp in the freezer should be around 0 degrees.
Dec 12, 2008 | Frigidaire Freezer Refrigeration White...
Freezers Logo
56 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
