Question about Little Giant - 3-MDQX-SC Inline Pump
Humming noise, but no turning..
I purchased this inline pump used along with a used tank and sump setup. I brought it home and it was only making a "humming" noise(plugged it in dry for a second to check if working). So, i took it apart and checked the wiring and oiled some parts. plugged it in, again for a quick second, and it worked like a charm. 3 weeks later I am setting up my tank, and plugged it in to verify its in working order, and again only making "humming" noise and no turning. any suggestions?????????
3 Suggested Answers
  • 14 Answers
SOURCE: Little Giant stopped working; makes hum noise but wont push wate
Can you take it out of where it is and clean it with vinegar? There may be calcium built up in it. I have one also on my aquarium and when I turn it off sometimes it won't start back up, just humms.. That tells me it's time to clean it.
Posted on Jun 14, 2009
  • 14 Answers
SOURCE: Hi, I have an inline aquarium pump made by Little
sounds like you need to get that pump off, take it apart and give it a good cleaning in vinegar. I have 135gal reef tank and do mine about once every 6 mos. You need to have cut off valves on each side so you can take it off when you need to. Go to 3reef.com. They can answer any question you've got!
93 petrol 80s Cruiser. Turns over, won't fire. Took off fuel line @ fuel rail, no flow. No pump noise from inline & tank pumps. Electrical problem Or have both pumps failed? Kind regards Neil
Hi. Thanks for your question. For assistance on issues related to fuel line and tank pump you can visit https://www.reliable-store.com and download the entire workshop manual which includes all the information along with the diagrams for better understanding. Good day!
Feb 25, 2018 | Cars & Trucks
Fuel Pump
A humming noise in the gas tank is usually a failing fuel pump.
The pump uses liquid gasoline to keep it cool and lubricated.
May 01, 2013 | 2004 Pontiac Grand Prix
Question i have a septic tank according to the drawing of the land. How can i find out if it has a sump pump. i am currently in the process of purchasing this home and there is a switch located on the...
that breaker could be the supply to the float inside the tank that sounds the alarm when full, check with the escrow company handling your purchase for full disclosure of the pump and installation, they should have all that if the pump and tank were installed with the correct permits . if they don't, ask for that Info from the seller ,
Aug 03, 2011 | Plumbing
It makes a humming sound but does not pump water. the pump gets very hot there is no debre in the outflow
The motor is binding that's the humming noise. Check to see what **** the thing sucked up. Then try to clean it out. I dont know what happened
Dec 25, 2010 | Little Giant 6 Cia, 1/3 Hp, 45 Gpm, 230V...
I installed this pump to company specs and don't understand why it's not working. I brought it back to the place that i purchased it and they got it to work. What am i doing wrong? Municipal water is...
How high does the pump have to lift, in feet from the water in the sump to the highest point of the piping?
While the pump is running, what is your municipal water pressure near the sump pump?
You saw it work in the store, were those conditions different?
Gary
Dec 14, 2010 | Liberty Sump Pump Jet WaterPowered Back up...
Kitchenaid Whisper Quiet + dishwasher making loud humming noise
Very likely pump motor shaft seal leaks water into bearing casing buildup of rust and consequently noise. I just replaced $112 worth of pump assy and it's back to normal. I would also buy repair manual for $10 on-line to be sure how to disassemble the sump to get to the pump.
Jul 14, 2009 | KitchenAid Dishwashers
Turns on makes weird humming noise
The noise is most likely your drain pump trying to clear water from the sump area. If you remove the bottom screws holding the lower access panel in place, look for the drain pump and a block rubber hose connected to it. I suspect there is something preventing the pump from draining all the water. Remove the clamp holding the hose to the pump (have towels handy as there will be water) and clean out the sump, then put it back together and give the washer another try.
Mar 08, 2009 | Frigidaire GLTF2940ES Front Load Washer
Pump is not working
The reason could be the following.
You used your machine on a mains working with 50 cycles/sec. In U.S. frequency is 60 cycles /sec. this could alter the working of the oscillating piston in the pump. The impedance of the coil is somehow about 20% higher on this mains, reducing so current and power of the pump.
To be quite shure of this, try to fill the pump thoroughly with water.
(Disconnect machine from mains, use Low pressure hose , max 0,5 bar, tied to the inlet -where the water tank feeds-, and fill until water comes out of the open hood)
If now the same humming persists an no pumping effect is noticed, i even will be a bit wiser knowing that 60Hz is not good to 50 Hz pumps.
Jan 04, 2009 | Philips Senseo HD-7810 Coffee Maker
Pipes humming in house
From your description, I am guessing you are on a deep well with this answer. I think you have an issue with the well pump. To isolate it do this...........
Turn the main supply valve off to the house. Your well tank should have a hose bib on the well tee. Hook a hose up to that and run it outside. Open the valve to the hose until you heard the pressure click on which activates the pump. After the click close the valve and listen for the hum. If it still hums it is the Well and not the piping in your home.
Will follow-up.............
Please rate this response after testing and Good Luck, Phil
Dec 30, 2008 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
Little Giant - 3-MDQX-SC Inline Pump Logo
50 people viewed this question
Top Little Giant Garden Experts
J.D. Browning
J.D. Browning
Jim Goldsmith
Jim Goldsmith
Mike Squire
Are you a Little Giant Garden Expert? Answer questions, earn points and help others
