Question about Microwave Ovens
Ge a1455 problems
I can record video, but there isn't any sound recorded with the video. I don't hear any sound when watching on the camera or on the computer.
    Top Expert:
  • Microwave Ovens Master
  • 12,223 Answers
Follow this instruction. God bless you
Check connections from DVD
Recorder to TV.
Check that Scart connections are pushed
fully home and that the Scart plug has not
come out on one side.
If separate audio and video connections are
in use check the audio output from the DVD
Recorder is connected to the Audio input of
the TV
Posted on Jul 20, 2013
Why do I hear a popping noise when turntable revolves counterclockwise.
If the turn table automatically picks up the tone arm and starts the record and changes after the record is over, then you are haering the gear box.
Feb 23, 2015 | Samsung SMH1816S 1.8 Cu Ft Over The Range...
I have GE JVM1540DN1BB microwawe. It beeps all the time and says "keypad sorted" and service needed. The beep sound is annoying and it beeps every 30 seconds
see this causes and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | GE Microwave Ovens
Undercounter light & fan don't work
It is most likely one or two defective door switches, "common problem with this unit.
May 07, 2012 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
I have a GE Spacemaker XL 1800 microwave (6 years old) that wont heat anything. All panel functions work fine. I think it is the magnetron but want to rule out anything else. I have the tech data sheet and...
In a case like this, one should first try to determine if the high voltage transformer is getting 110VAC on its primary terminals when you try to cook.
Please be careful if you decide to check this, and do not attach your meter leads to the high voltage side of the transformer.
Testing the high voltage will require a proper high voltage probe (not a simple multimeter) and I would not recommend it to anyone without experience. The high voltage can be instantly lethal.
It's easier to tell by ear if the high voltage section is getting power. You'll hear a slight thump and hear a slight humming.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
If it's quieter than usual, then it may be as simple as a bad door switch or switch mount, very common issues. See this help file on door switches.
If it's louder than usual, it may be a failed magnetron or a shorted high voltage diode.
See these test links:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
Once you look all this over, if you're still not sure, or you tend to suspect the magnetron, note that some GE models have a 9-year warranty on the magnetron, some as little as one year.
But it depends on the full model number on the tag in the cooking cavity. That tag will also tell you the manufacture date.
Your owner's manual will tell you what the warranty is.
If for some reason you don't still have your owner's manual, you can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If it's still under the magnetron warranty, GE will send you the magnetron free to do it yourself. Call them at 888-239-6832.
If it's not under the magnetron warranty, you would have to purchase it yourself.
You can find handy exploded views and order parts by model number
here.
If it's a door switch or mount issue, you would not have to remove the oven from the wall.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Once you have the controller off, the switches are accessible, and the magnetron should be, too.
If you need to replace the magnetron, you will need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Oct 22, 2011 | GE XL1800 1100 Watts Microwave Oven
How to replace the handle GE microwave spacemaker xl..... thank you
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Sep 16, 2011 | GE Microwave Ovens
GE Spacesaver JVM132K made in November 1993 just died. Made a buzzing sound and went dead. No lights. No camera. No action! Is this fatal?
Buzzing or loud humming is one of the signs the magnetron tube, the microwave source, has gone bad. Since your oven is over 15 years old, this isn't too surprising. It is possible to replace the tube, but it's usually not worth doing. The magnetron is a costly part, and this kind of repair should be left to a professional because of safety concerns. Between part and labor costs, it's often not much more to buy a new oven.
Jul 28, 2011 | GE Microwave Ovens
I don't know why my microwaves keep beeping and starts the Exhaust Fan automatically every 5 mins. The display says F-3. Please help me with the problem I'll appreciate.
F-3 is usually for the temperature sensor being faulty. What you need most likely is to replace the temperature sensor. This would explain why your microwave oven exhaust fan keeps going off, because your temperature sensor is telling it that it is overheating even though it isn't.
Jul 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Turn table on Microwave oven not moving correctly
You can see and hear a video of how a turntable motor should sound when you rotate it by hand: http://www.youtube.com/watch?v=rPSWi_z7M58
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts for GE models by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
May 14, 2008 | GE Microwave Ovens
Not sure if I have a problem with the 1.4 Cubic ft. 1150 watts Microwave oven just purchased. The turn table and support will not move when attempting to turn by hand. Our old one which we replaced,...
If it's still under warranty then I would certainly contact the manufacturer for a free repair.
Since this is posted under GE, I'll assume it's a GE. If not, please reply back with your brand and model number so we can help you.
GE Customer Service is online here.
GE Spacemaker Microwave JVM165OWB005--No more heat!
If you look at consumer affairs.com, there are many problems like this with GE microwaves. Not a good track record, experiencing problems with mine as well.
Apr 15, 2008 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
20 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
