HP LaserJet M1120 MFP All-In-One Printer Logo
Posted on Mar 30, 2009
Printing quality copied or printing output having some vertical lines on the page with blackish background
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 09, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
101
Points
The problem is that film element at fusing asy scratch/broken change and remove this part
http://eservitia.co.cc
Print problem sir in 2420L
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing.
Happy with us Dial Epson Printer tech support phone number 1-877-778-896 for technical support of customer executive regarding with the Epson printer, if your printer is not connected with your PC & Laptops, Don't worry, dial our Tollfree 1-877-778-8.9.6.9 and get better and feasible solution of your issues within a time in the USA.If you want more information regarding with Epson n printer visit us:http://printertechnicalhelp.com/epson-printer-technicalhelp.html
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Savin 9935DPE is printing one thick vertical balck line down the copy or print pages. About 2 of every 3 pages printed. What's wrong?
are you printing from Doc feeder or glas?? if from feeder then try to make a copy from the glass, does it still do it? yes problem is with drum.
No? problem is with the small scanning glass to the left, look carefully see if any spots or lines on the 1inch glas --- clean it
I just replaced my old Printmaster with the 2011 Platinum. I designed business cards using the template from the list. But when I print, the cards are too large to fit on the page. I've tried reducing...
According to your problem you want print a business card and face the with font size & background
colour. It may caused your printer settings.
# First check your paper size in your printer propreties. It must be visiting card size.
# check printing resolution.
# printing quality in printing preferences should be suitable for a card printing.
for your second problem find the background graphics option in your printer properties and set it
properly.
For supported resolution, background image see ith product mannual
When copying or printing a fax, a vertical black line 2-3 mm line
try cleaning the rollers with water in the feeder at the top check the glass too too see if it's dirty
Samsung ml-2010 printer prints vertical lines on the page
it may due to scearch on roller. check the roller for any scearch mark.
Printer won't print
Printing on stand alone has a big difference when printing from pc.... try using the kodak website for this issue www.kodak.com/go/itg and use "image quality and blank page" for subclass
Problem with printing smoothly
Hi morshi. I found a potential solution to your problem with your 5610 printing vertical lines at HP.com:
Vertical black lines or streaks
It's hard to tell from the rest of your message what other problems you're describing. I did find a troubleshooting page at HP that shows how to address general print quality problems:
Problem with quality of copies
If those links don't solve all of your problems, the Color printing issues page for the 5610 at HP has numerous other solutions:
I know the name of that last link may seem misleading since you haven't described color printing issues, but the links on that page offer different general print problems and their solutions.
Good luck.
2answers
1helpful
Printing and scanning problems
Go to " Dell All in One centre"
Click on maintain/ Troubleshoot on top of the page.
Then click maintain or fix quality problems.
then choose the problem you have.
It should be sorted,
Let me know how it goes.
k24674
Grand Canyon Tech
Grand Canyon Tech
