Question about Home Security
How to "force arm" GE Networx NX-148E
How does one "force arm" a GE Networx NX-148E alarm system, rather than individually scroll and bypass all open windows? We often leave our sensored windows upstairs open when we leave the house for short periods. Our old Westec 5000 system had a "Bypass All" function that allowed us to quickly arm the system with whichever windows were open. The Networx system is a pain by comparison, since each open zone needs to be bypassed individually before the system is "Ready" to be armed. The "Force Arm" function sounds like it would resolve this, but there is no instruction on how to do it.
4 Suggested Answers
SOURCE: problem arming all sensors on ge simon security
I have yet to test it but I think I've figured it out... I spoke to the place I bought the alarm from and he stated that for both the door/windows & motion to arm, you have to leave the house (or activate an exit door) or the alarm thinks you are still in the house. Since the motion is instant on, this prevents you from accidentally setting off the alarm if you armed it and never left.
So what if you want to arm both and stay inside? There is an option called Unvacted premises (in the Timers menu). It's on by default and makes the alarm behave as described above. Set this option to off and you should be able to set both and not leave the house.
James
Posted on Feb 10, 2009
  • 1340 Answers
SOURCE: I have a DSC 832
Did you have the old battery still in it for 5 years?If you did,I would almost guarantee that the battery leaked and junked out the system.It may not be obviously noticeable,but a battery left in a unit that long with no use,will always do that.Whenever something battery powered is not going to be used for more than a month,you should take it out.If you can remove the back to examine it,you may find something.If you think you got battery acid on your hand or wherever,baking soda is a neutralizer for acid.It would be worth a look if you can though.If you have any questions or need more help,just comment here and I will get an autolink to your post and reply ASAP.Good luck,Greg
Posted on Dec 05, 2010
steve_hillin
  • 44 Answers
SOURCE: Can I adjust the volume on my GE Networx NX-148E
There are a couple of things you can do, you can silence the keypad via a programming change to the alarm panel, but this requires knowing the installer or 'go' code. On the other hand, you can change the tone of the keypad by pressing * 0 and using the arrow keys to adjust the tone up and down.
Posted on Mar 05, 2011
We have a Direct Alarm Supplies home Networx NX 16 security system installed in our home after we have a power blackout & the power comes back on the alarm goes off. Is this normal or how to fix
If you have had the system for some while, its internal battery eventually looses full charge by constantly being charged by the system. When you loose power the alarm will try to resort to the battery that obviously can handle the job no longer and forces the system to alarm. Recommend that you replace the battery on a regular basis around 12 / 24 months. Otherwise may be a configuration of your system that identifies power loss as a setting.
Apr 01, 2017 | The Home Security
We have an NX-148E keypad. Our building has 4 doors alarmed to the panel and the Chime sounds when any of the doors is opened. Is it possible to set the Chime only to sound when 1 of the doors is op
I am sure there is separate programming for each zone. You will need the manual for the system. Probably can get it on line. This chime feature usually comes from the factory with no zones programmed for reporting. Hope this helps
Oct 03, 2012 | GE / Caddx Networx Programmable LCD Keypad...
I forgot my password for my Caddx NX-8 Alarm. It was installed in 1999
My caddx nx-8 system, have started going into a instant alarm mode for no reason, what can I check for this?
Mar 30, 2011 | GE / Caddx Networx NX 8 Control Panel...
Keypad message reading 12volt low battery on three wireless zones. changed out all batteriies and still getting message.
This could be referring to your battery backup for the control panel. Make sure your battery connections are secure and check the batteries' voltage with a multimeter. If it is showing less than 12 volts and has been connected to the control panel for more than 24 hours, the battery is bad and needs replacement. Contact your local alarm company and ask them verify the battery is bad, and they can install a new one for you right then.
Feb 23, 2011 | GE / Caddx Networx NX 8 Control Panel...
Can I adjust the volume on my GE Networx NX-148E keypad?
Feb 10, 2011 | GE / Caddx Networx Programmable LCD Keypad...
Hi i have a ge Caddx NX-148E-RF - beeps only on the hour anoying
Press * 2 and it should tell you what the problem is.
AlarmProfessor.net
Jul 04, 2010 | GE Security Simon 3 Wireless Home Security...
Hi Liam here I just installed a networx nx4 and when powered up key pad has 1,2,3,4 flashing rapidly with service light on I was able to get rid of service light but zones still flashing And there is only...
This could be a supervision problem. If zone expanders, gsms, keypads, etc. are added to this alarm panel, you must enroll the device with the control panel. This is done by entering into programming mode ( * + 8 + {go code} ) and then simply exiting programming mode by hitting the exit button. The GE NetworX control panel and it's affiliated compatible devices will auto-enroll after about 15 seconds. The default 'go' code is 9713, but this is usually changed by the alarm company installer.
Apr 21, 2010 | General Electric GE NX-591E-GSM NetworX...
Contant Beeping on alarm
The Fail To Comm message is not related to your low battery problem. A Fail to Communicate occurs when the alarm system tries to send a signal (alarm, trouble or restore) to a monitoring service but can't. Most often the causes are telephone related. Has your system been disconnected from it's phone line? Have you recently changed phone services from your main carrier to an internet provider that provides VOIP service? Sometimes alarm systems have a hard time communicating over these services. Whatever the reason for the
Mar 28, 2009 | GE Interlogix Dvmre Pro 10 Channel Triplex...
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
