Question about Russell Hobbs 9376 Classic 2-Slice Toaster
Instructions the screen-printed lables below each of the four buttons have been wiped off. I know one is for "frozen". I need to know the function of each button so that I can somehow re-lable...please?
How do I align my Citizen CLP 7202e Lable printer print head to align with the lables? Currently it starts printing low on the lable and thus the last 1-2 lines print over onto the next lable
Adjust vertical offset in printer properties. If that doesn't fix it, adjust it under "advanced". Or... you can set the offset in the printer itself. Hold down the left two buttons at the same time. Cycle through the settings until you get to vertical offset.
Apr 19, 2015 | Citizen CLP-7202e Thermal Printer
My tablet is frozen and I have clicked on the reset button and it will not still turn on
You need to do a factory reset, follow these instructions:
Step 1. With your tablet turned off, press and hold the volume up (+) button. While holding the volume up (+) button, press the tablet's power button until you see the RCA logo with Nipper and Chipper on the screen. After a few seconds, the screen will change and you will see the Android bot on his back with a caution symbol above him.
Step 2. Now you are going to press and hold the tablet's power button, and without releasing the power button press down on the volume up (+) button. You should then see the screen below.
Step 3. Use the tablet's volume up (+) and down (+) keys to navigate to and select the "wipe data/factory reset" option. To select this option, press the power button.
Step 4. The tablet is going to ask you to confirm your selection. Use the tablet's volume up (+) and down (-) keys to navigate to and select "Yes - delete all user data." Once again, use the power button to select this option.
Step 5. At the bottom of the next screen, you will see "Data wipe complete." Press the power button to restart the system.
Jan 02, 2015 | RCA Audio Players & Recorders
Screen frozen
You may want to follow the step-by-step instructions posted below to hard reset you LG Nexus 4 when it becomes unresponsive. Please note that the phone will wipe all contents.
How to perform a hard reset when my LG Nexus 4 is unresponsive
1. Ensure the phone is off.
2. Press and hold the Volume down button and thePower button.
3. Scroll to Recovery mode by pressing theVolume down button.
4. Press the Power button.
5. Press and hold the Power button and then press the Volume down button.
6. Scroll to Wipe data/factory reset using theVolume down button.
7. Press the Power button.
8. Scroll to Yes -- delete all user data by pressing the Volume down button.
9. Press the Power button.
10. The phone will now wipe all contents.
11. Press the Power button.
12. The phone will now reboot to the initial setup screen.
Jan 20, 2014 | LG Nexus 4
How do I reset my lg optimus
See the instructions below how to factory reset your LG Optimus
First, try this:
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
  1. Turn the power off. If your LG Optimus T is frozen, pull the battery out and reinsert it
  2. Hold the Home and Volume Down button
  3. Press and hold the Power button until the device turns on
  4. Follow the on-screen instructions to reset your device
All data including third-party applications will be deleted from the LG Optimus T. Once the wipe is complete, the phone will reboot to its factory fresh state.
Amardeep
For More Tips, Visit My Blog @ http://thegeektweet.wordpress.com
May 27, 2011 | LG Cell Phones
The RDS OFF message is on the radio screen today. The remote controls on the steering wheel and the memory buttons do not operate. How do I get the RDS back on again? Do not know how it was turned off in...
Many buttons on your radio have two functions, the first by pressing and releasing the button, the second by pressing and holding the button for a few seconds, the first function is clearly printed on the button, the second may be printed in a not so easy to see fashion either above or just below the button, look at your radio carefully for these.
If you do not find one called rds, look for a button labled menu, push it and scroll through whats there, you should find it, good luck, hope it helps.
Mar 25, 2011 | Car Audio & Video
I have an hp 2210 All-In-One printer. Check print cartredges
Check to see if the installed cartridge is the correct one for the printer. If the cartridge is the proper part number, remove the ink cartridge and make sure all the packaging tape has been removed from the copper circuitry strip on the backside of the cartridge. Reinsert the cartridge and try printing again.
If the error continues, remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, contact the Customer Care Center listed in the printer's User's Guide.
Reinsert the cartridge and try printing again. If the error continues, the cartridge may need to be replaced.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
Zebra LP 2844 Prints 30 pages of junk instead of a Dazzle mailing
Turn off the printer and place your finger on the green feed button. With the button depressed, turn the printer back on. Let the light flash2.gif (ONLY!) four times and release the button. Printer will cycle through 2-3 labels. Press the feed button one more time.
You've just set the printer back to factory default.
Jul 23, 2009 | Zebra LP 2844 Thermal Printer
Doc not printing in color
Check under printer preferences. Click print. A screen should pop up asking you to choose a printer. Directly below the printer list is the preferences button. Click it. You should see a tab labled "Color". Make sure the print in grayscale is unchecked.
Jul 16, 2009 | HP Photosmart 2575 All-In-One InkJet...
Screen wont come on
no "lock" button but there is a function button to switch the primary monitor from the built in one to an external one. on the lower left han side of the keyboard there is a key labled "function" hold that down and look along the top row of buttons (f keys) one of them has a green or blue picture of two monitors, with the power turned on try holding the function bution and the f key and see if it comes back on. also there is a brightness key as well make sure it is all the way up.
Not to discourage you but I just sent back 4 of these same models to acer for warranty for the exact same problem. All four of them however did work with an external monitor.
Dec 10, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Insert or over-type feature
I have the Microsoft Comfort Keyboard and it has a "F lock" key. This key has to be set on "Off" to let it know that I want to use the Print Screen function versus the Insert function on the same key. May be your keyboard is the same way.
May 03, 2008 | Computers & Internet
Russell Hobbs 9376 Classic 2-Slice Toaster Logo
Top Russell Hobbs Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
ashburton
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
