Question about Minka Lavery Minka-Aire F705-Stw, Napoli Sterling Walnut 56" Ceiling Fan With Light
Fan speed problem
Fan slows when high speed is selected.
3 speed fan barely changes speed
You are talking about your blower fan for the air conditioner and heater right? More information will be needed to solve the problem.
When you say it barely changes speeds, does that mean it doesnt speed up, or doesnt slow down? By that I mean, is it "stuck" on low, or high?
Most blower fans run at different speeds through the use of a multi-stage resistor built into the fan switch circuit. Low speed is a high value resistor, medium speed is a low value one, and high speed is the fan running without any resistance.
If your fan is running on high and doesnt seem to want to run on lower speeds, the resistor pack may be failing. If the fan is running on low speed only, it may be that the fan itself is beginning to fail, or that the lubricant in it has gotten gummy.
Dec 07, 2015 | Cars & Trucks
Cooling fan is too slow.
  1. right click the battery icon on the bottom right toolbar
  2. select "power options"
  3. select "high performance" (if not visible use drop down to show additional power plans)
  4. click "change plan settings"
  5. click "change advanced power settings"
Feb 19, 2014 | MSI Emachines E528 Original Laptop Genuine...
Fan slow down and them high speed
change the fan ASAP, since the zooming noise and the slow performance will affect even the processor and you might end up replacing the processor as well if it persists. So get the fan ASAP and problem will be solved.
Sep 30, 2013 | Gateway GT5622 PC Desktop
How do I control fan speed?
Keeping the fans clean is especially important, because the fans blow out hot air and bring in fresh air to cool down the laptop.
Fans attract dust, however, which can slow them down, resulting in a hot laptop.
If the laptop overheats, vital parts can cease functioning altogether.
Consequently, keeping your laptop's fans clean is crucial.
The fan speed on a laptop can determine how it operates consistently and reliably.
You can slow it down or speed it up, based on the circumstances.
For instance, slowing down the fan speed may be useful in reserving processes or during a prolonged slow time.
Speeding it up is beneficial in keeping the laptop cool during ongoing use or high-traffic times. For the long term, find a happy medium for regular use, so you won't "psyche" out your computer by constantly adjusting the settings.
Click on the Start menu and select "Control Panel." Next, choose "Performance and Maintenance."
Select "Power Saver."
To slow the fan speed, locate the slider next to "CPU Processing Speed" and slide it down by moving across to the left.
To speed up the fan, move the slider to the right.
Press "Apply" and then "OK," if prompted.
Hope this helps
Nov 08, 2012 | Lenovo IdeaCentre Q150 PC Desktop
Fan noise-fan lags speeds up to normal then slows and will eventually stop. This occurs on fan only operation (high and low) and cool high and low.
The bearings,or bushings in the fan motor are gone out,the friction eventually slows,or stops the fan motor.
Jul 01, 2010 | Heating & Cooling
Ceiling fan only operate in slow speed, the medium/high not work
either you do have a defective running capacitor, or fan motor,or try lubricating the fan bushing.
Aug 06, 2009 | Dryers
Fan Speed Too Slow
You need to pull the fan chain until it is set to the fast setting, then you use the remote to set the fan at the speed you desire.
May 26, 2009 | Dryers
Hampton Bay 54 In. 5-Blade with remote control at wall.
1. Set the remote to run the fan on high.
2. Pull the fan speed chain until the fan reaches high speed.
3. All speeds should work normally now.
The remote is modulating the maximum speed as set by the pull chain.
Dec 29, 2007 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Minka Lavery Minka-Aire F705-Stw, Napoli Sterling Walnut 56" Ceiling Fan With Light Logo
65 people viewed this question
Top Minka Lavery Photography Experts
Tony
Are you a Minka Lavery Photography Expert? Answer questions, earn points and help others
