Pilot tele picklock lgs 11 - Televison & Video
Pilot light wont stay lit once button is released unit is about 11 years old
call your plumber and have it serviced possibly just needs the thermocouple replaced .
Dec 28, 2015 | Bosch & Tankless LP Hot Water Heater
I need the code 4 one for all remote for tele maxim 11 lcd 15 dvb
0381,0388,0389. Try these codes. For more information check this link. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Dec 01, 2013 | Televison & Video
N90 EHLtype C 11 Pilot gas wont stay alight.
Your problem is probably with the thermacouple. Contact a service company.
Apr 13, 2010 | Thetford Refrigerators
Can u tell me function of DSP , LGS CARDS IN 3600
LGS is same with FXS (Foreign eXchange Subscriber) card. It's voice card for serving voice needs with 2 wire connection. A analog phone connect to LGE on alcatel 3600 and other analog phone or PBX on remote alcatel 3600.
Look the others card e.g LGE (FXO) and E&M card.
DSP card processed the voice.
thanks
Feb 26, 2009 | Alcatel Newbridge MainStreet 3600...
Tuning a Grundig Tele Pilot 750c Television
It might be an old hotel tv. Try this, it worked for me
http://www.tvtuning.co.uk/makes/grundig.htm
basically you hold the i button whilst turning on the tv.
ta
Jan 07, 2009 | Grundig GF70-600 TV
I need the latest eurovox v max codes, east london
KEY 00 = 3F 32 37 03 D0 73 84 84
KEY 01 = C6 64 1D EF 47 5A 0E EF
FOR TELE/W ON 30/11/08 @ 6.55PM
Nov 30, 2008 | StarTech.com StarView SV211K 2-port KVM...
Need cods for eurovox max v virgin/cable bristol area please
6.00PM ON 30/11/08 FOR TELE/W , V/M
Tele codes starview
29 nov
n*l
0=CD 11 58 05 EE 96 E7 F3
1=EA B7 BF B2 D5 AA 46 AB
Nov 29, 2008 | StarTech.com StarView SV211K 2-port KVM...
Tv
I had the same problem with my new TH-50PX60B. I turned the tele on then after 5seconds it would switch off. The standby light would then blink on and off 11 times, pause for a second then flash 11 times. This would continue until the power wasturned off. Note the TV would not turn on for more than 5 seconds.
I solved this problem by turning the tele on and checking the fans at the back. My tele had 3 fans. If one of the fans is not turning, this will be the cause of the problem and the tele will shut down under the Emergency Shutdown System. To clear the fan try blowing on it to free up any dust etc. If that still doesn't work try using a thin instrument (tie wrap etc) to manually turn the fan and free it. Then power off the tele and turn it back on. The tv should work perfectly.
Sep 02, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
