Kenmore washing top ladino machine model 26002010110 water pump
SOURCE: Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
Posted on Dec 20, 2008
WRMtech
  • 70 Answers
SOURCE: Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
Posted on Feb 24, 2009
  • 1937 Answers
SOURCE: My Kenmore Elite top loading washing machine won't spin or drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main
agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Dec 07, 2009
  • 1937 Answers
SOURCE: how to replace lid switch kenmore 110 22922 washing machine
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the section on the cabinet.
Then see the following for how to release the console and pull the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=9b19162f839199d33f88dac696ac636c
Posted on May 07, 2010
Daniel S
  • 4323 Answers
SOURCE: I have a kenmore Elite Oasis Top Loading Washing
Hi
This issue can either be due to the suspension rings or due to motor issue. Please check this link for exploded diagram of your washer---
Kenmore Elite Top Load Washer 110.28032701 Diagram
Also, check the stator motor and the retainer, make sure no parts are missing. Hope this helps... Please post back if you need more information.
Daniel
Posted on Dec 30, 2010
Washing machine model 110:23032102 is retaining
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.23032102&pathTaken=partSearch
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
I'd check the hoses for blockage, check the shaft from the motor to the pump and check inside the pump to make sure the inlet and outlet aren't blocked.
Apr 28, 2010 | Kenmore Washing Machines
I have a Kenmore 80 that doesn't spin
You may not have given me enough information, but here goes. If the washer drain some water and then does not spin, the washing machine clutch assembly needs to be replaced. If it is not draining at all then the water pumps needs to be replaced. Water pump replacement is easy, but the clutch assembly- you better be very experienced. Unplug the appliance before you attempt these repairs! You will need the model number to get the proper replacement parts.
Jan 16, 2010 | Kenmore Washing Machines
Water leaks under the washing machine Kenmore top loadin washer, model 110-234642300
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
Also see the following for how to remove the cabinet and gain access to the pump.
newsPath=16&newsdesk_id=134&osCsid=b547cd9bb24b4ffaef51e860554a9cb0
Check the areas for the motor and pump and the Agitator Basket and Tub.
If you've checked the hoses to and from the pump the problem points to either the pump itself or to the Centerpost gasket.
Neither of these is too difficult to replace, the Gasket requires removing most parts of the washer although the pump is an easy replacement.
Jan 11, 2010 | Kenmore Washing Machines
The water in my washing machine does not drain once it goes to the spin cycle. How do i get the water out and what do you think the problem is?
Can you provide the exact Make, Model and Kenmore model number?
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.
Assuming that it does spin, the problem points to the drain pump and/or clogged hoses.
See the following on how to remove the cabinet and pump.
Remove the hoses carefully and drain the water into a bucket or tub.
Check the hoses and look inside the pump (try to turn it by hand) to look for obstructions.
If it won't spin or drain, the first thing to check is the Lid Switch.
See the following on how to bypass the switch.
Nov 02, 2009 | Kenmore 22422 Top Load Washer
My kenmore top loading washing machine won't spin
Once you remove the cabinet,remove the water pump and check it for a garment or lint. Clean or replace the water pump and reinstall it.
Oct 31, 2009 | Kenmore Washing Machines
Washer will not empyy water or spin or wash on any cycle
something caught in drain pump, clamp hoses and remove pump inspect repair or replace.
Apr 04, 2009 | Kenmore 22422 Top Load Washer
Washer will not drain ALL the water out
It was the coil in the wigwag assembly. The washer was not spinning causing it not to pump out all the water
Jan 25, 2009 | Kenmore 22422 Top Load Washer
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
