Fedders a3q05f2ag air conditioner
How many BTUs
hemantraj
  • 638 Answers
SOURCE: Fedders Air conditioner
e5 is comp overload code . if you have infared remote for indoor units point at anyone while pushing all 3 buttons at the same time- 'mode' 'temp up' temp down' this will bring up OO where temp set point is normally displayed. scroll up or down with temp up or down buttons (1st digit only) untill you here the beeping sound change tone, this is the 1st part of the fault code. press mode once to change to 2nd digit, scroll again with up and down listening for change of beep- 2nd part of code ie "E5". press mode again will bring up afunny looking T-test mode. press mode again to exit. THATS VERY ACCURATE SOLUTION.SAVE IT FOR FUTURE.WISH U SUCCESS .REPLY FOR FURTHER ASSISTANCE IF REQUIRED.BYE
Posted on Jun 07, 2008
  • 143 Answers
SOURCE: air conditioner fedder 6000 btu
No. The oil will not return properly to the compressor.
Posted on Jul 28, 2008
  • 10865 Answers
SOURCE: what is the air exchanger (open or closed) switch for?
The air exchanger is there to give you the option of adding fresh outdoor air [open] or recirculate the air in the room [closed].
Posted on Jun 04, 2009
  • 99 Answers
SOURCE: 24000 BTUs LG split air conditioner external unit
Hi; Look into Your owners manual for troubleshooting codes. If You dont have a manual call or google the manufacturer...alpharome416
Posted on Jan 22, 2010
  • 34 Answers
SOURCE: can't find a manual for air conditioner
BTU means "British thermal units" and is a measurment of cooling and heating capacity. Other units are Kw "Kilowatts", and HP "Horse Power".
To convert
Multiply by
To obtain
kW
1.341
hp
kW
3,413
Btu/hr
hp
2,545
Btu/hr
Posted on May 21, 2010
Looking for replacement of Fedders model T1A10W7A (not sure if installed in a type a or b sleeve). Which model can I replace with?
I suggest that you measure the sleeve's dimensions and shop the a/c dealers. They should be able to match you up with something of comparable BTUs, but more efficient.
Aug 24, 2013 | Fedders AZ7A12W7A Air Conditioner
Everytime i plug in the ac the relay switch trips
That is because there is a wire shorted in the unit or the compressor is locked up and has gone bad...
The most likely thing is that the compressor is bad... it will cost more to replace it then the unit is worth...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air ConditionerTrouble - Review the Possibilities
heatman101
Jun 21, 2011 | Fedders A7Q08F2B Q Chassis Room Air...
HOW DO I GET MY FEDDERS AIR CONDITIONER BACK TO FARENHEIGHT
Problem with Fedders (A6R12F2A) Air Conditioner
FARENHEIGHT
Nelvie: silverslipper@candw.ky
Aug 20, 2010 | Fedders AED24E7F Wall/Window Air...
I have a 27 inch wall sleeve can a 26 inch friedrich unifit work?or do I need a 27 inch unit
the a/c units keep getting smaller, when unit replacement is slightly smaller , the extra space can be filled with a piece of plywood or rigid foam insulation with a thin layer of plywood, any edges seen from inside can be covered with trim, make sure the wood covers entire bottom layer of sleeve to properly support. or just find the larger unit if you can. hope this helps.
Apr 23, 2010 | Fedders A6U14W7B U Chassis...
Does not start, manual nor remote
found fedders is bankrupt and another company is using the name
the tech there told me about the reset button on the other side of the plug, and the reset button worked
thanks
ALAN
Feb 11, 2009 | Fedders A6Y12F2B Y Chassis Room Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
