Question about Amana Portable Air Conditioner
Amana free standing air condition manual model #ap08jr
2 Suggested Answers
sloooo44
  • 156 Answers
SOURCE: Where is the drain on amana air conditioning wall unit model pth123d35arda
Drain is usually out the back of the unit on the bottom to drain outside
Posted on Aug 05, 2016
Aug 04, 2016 | Amana Heating & Cooling
Boiler doesn't fire up. 25 years old Amana outdoor boiler model #3612M-A Mfg # P68191-1F,It had leak in pump housing and replaced, replaced igniter ,but no fire, no leak in system ,pump are keep running...
How a Central Air Conditioning System Works
Facts:
  • The typical central air conditioning system is a split system, with an outdoor air conditioning, or "compressor bearing unit" and an indoor coil, which is usually installed on top of the furnace in the home.
  • Using electricity as its power source, the compressor pumps refrigerant through the system to gather heat and moisture from indoors and remove it from the home.
  • Heat and moisture are removed from the home when warm air from inside the home is blown over the cooled indoor coil. The heat in the air transfers to the coil, thereby "cooling" the air.
  • The heat that has transferred to the coil is then "pumped" to the exterior of the home, while the cooled air is pumped back inside, helping to maintain a comfortable indoor temperature.
  • Central air conditioning can also be provided through a package unit or a heat pump.
Benefits:
  • Indoor comfort during warm weather - Central air conditioning helps keep your home cool and reduces humidity levels.
  • Cleaner air - As your central air conditioning system draws air out of various rooms in the house through return air ducts, the air is pulled through an air filter, which removes airborne particles such as dust and lint. Sophisticated filters may remove microscopic pollutants, as well. The filtered air is then routed to air supply ductwork that carries it back to rooms.
  • Quieter operation - Because the compressor bearing unit is located outside the home, the indoor noise level from its operation is much lower than that of a free-standing air conditioning unit.
ed.
Sep 10, 2008 | Amana Heating & Cooling
How do I replace the fan?
Free Amana Air Conditioner User Manuals ' ManualsOnline ...
homeappliance.manualsonline.com > ... > Household Appliance Amana
Products 1 - 10 of 10 - Amana Air Conditioner 18M23TB. Amana Room Air Conditioner Use And Care Manual. Pages: 0 Saves: 0. See Prices Buy or Upgrade .
Jul 10, 2015 | Amana Portable Air Conditioner
I cant find the booklet that goes with my Amana Portable Inroom AC. Model # ap148D
The Amana portable a/c units have their documentation at Haier America. The direct link to the manual you want is here: http://crm.haieramerica.com/PUBLIC/User%20manual%20AP148D.pdf . If you want to buy the manual, go to http://www.partstore.com/Model/HAIER+AMERICA+TRADING/Haier/AP148D/Other+Cables,+Cords+%26+Wires.aspx . Scroll down to the All Parts section and then find the Use and Care Manual for $4.56. (It is a special order.)
I also found a link to the manual for the AP148DS here: http://homeappliance.manualsonline.com/ex/thread/view/idThread/295978 . However, you need to be a registered user (free registration) to access the link. Click on the Get This Manual button and the registration/login will pop up. This may be a similar enough manual to help you use the A/C.
I hope this helps.
Jul 07, 2011 | Amana Portable Air Conditioner
We have an amana ac and no manual. The model number is not visible and we can't get the ac to go below 75 degrees. What do we do and how can we obtain the elusive manual?
Here is a link to contact Amana.I could not find a free download for a manual,however I am sure you will need to find out the model number somehow.The model number should be on it somewhere.If it is a unit where you have to mount the casing and then slide the unit into the casing,it should be on the back somewhere once you pull it out.That's all I have for now.If that does not work,Amana should be able to tell you where it is with some description of your unit.Good luck!
http://www.amana-hac.com/Home/AboutUs/ContactUs/tabid/171/Default.aspx
Jul 27, 2010 | Amana AC053R Thru-Wall/Window Air...
Hello, the exclamation point light is blinking on my free standing amana ac. I've drained the water and cleaned the back filter. aby other suggestions?
Try disconnecting power for 5 to 10 min to reset the unit.
If the light comes back on let me know and locate your owners manual for refference.
Aug 25, 2009 | Heating & Cooling
Say me certain reliable brand gas air conditioning for home
Goodman, Trane, and Amana are all pretty good manufacturers of heating and air products with some of the best warranties available.
Goodman: www.goodmanmfg.com
Trane: www.trane.com
Amana: www.amana-hac.com
Hope this helps.
May 27, 2009 | House Brand Heating&Air Conditioning...
We have a 2007 Amana Portable Electric Air Conditioner 7000 BTU. We can't find the manual and it is leaking water out the back. How do we fix this?
That is a normal function of the air conditioning. Nothing to worry about, it is removing humidity from the air.
Jul 04, 2008 | Amana Heating & Cooling
Amana Portable Electronic Air Conditioner 9000 BTU
Unfortunately I am unable to find the Manual in our system. Here is the information that you can use to contact them directly. They should be able to send you a new one.
Consumer Affairs Address:
7401 Security Way
Houston, TX 77040
To speak with a Heating and Air Conditioning Consumer Affairs Representative from within the United States, please call 1-877-254-4729
Jun 27, 2008 | Amana AP073M 20" Portable Air Conditioner...
Amana  Portable Air Conditioner Logo
81 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
