Question about LG Heating & Cooling
Need Coil Thermister for LG Unit M#LP153H03A
I need price and availability for the coil thermistor for LG unit Model # LP153H03A / Serial #008KAFX00891
  • 43 Answers
SOURCE: Price to replace cooling coil on WeatherKing 12AJA4801
You could have a low air flow condition if the coil is freezing. Check the condition of the filter and the coil itself. If either one of these is dirty or blocked the coil may freeze.
Posted on Jun 21, 2008
SOURCE: AC not cooling enough
Probably low on refrigerant, if valve moves when heated it is working, assuming the system is matched.
Matt
Posted on Jul 01, 2008
  • 6 Answers
SOURCE: fan coil unit won't cool or heat in room1 while room2 runs well
could be undercharged, or overcharged, or wires weren't put back on valves in unit.
Posted on Feb 16, 2009
kentguidry
  • 51 Answers
SOURCE: Need help selling a Carrier 4-ton 10SEER unit!
Yes you can sell this unit. You would have better luck posting on ebay or craigslist.
Posted on Feb 20, 2009
Zaiko e5 error how I can fix my ac
E5 indicates excessive temp. of the outside coil if on cooling, OR excessive temp of the inside coil in
heat mode. On cooling, the E5 will appear if the outside coil temp exceeds 68C. This is an indication
of condenser airflow reduced or non-existent. Using the procedure described above it is possible to
watch the condenser coil temp using the Temp down button and Medium fan speed combination to
display this temp. NB: if fans etc seem to be OK then measure thermistor resistance and refer to table
12. In case the problem is thermistor calibration.
Action: If unit is in cooling mode, examine both condenser fans are running. If
one is running then suspect a faulty motor. If both fans not running then
on units up to serial No. IBSA 01175, investigate the fan speed control
card located in enclosure on the LHS See fig 6.
If this checks OK then investigate main control card.
Fig 1, 2 or 3. Units with serial No's IBSA01176 and
onward are multi speed tapped wound motors not requiring a speed
control card. If both motors inoperative then suspect main control card
Aug 15, 2016 | Heating & Cooling
LSN181HSV. Why is it indicating code 61?
LG error code 61:
Condenser coil over 65°C. Check coil and filters are clean and free from debris, and airflow is OK. Check system pressures for non-condensables.
This would suggest it is not faulty thermistors but blocked heat exchanger in the outdoor unit. Or possibly an issue with the refrigerant level.
Aug 11, 2015 | LG Heating & Cooling
Model ABUW426KSA3 getting an error message "Ch 06"
Is a problem with the Indoor unit coil outlet Thermistor.
Please check this link for the solution. You need to compare a result to a graph in this link. Please go to page 7.
Cheers.
Thank you for using Fixya. Your generous rating will be much appreciated.
Oct 13, 2010 | LG Heating & Cooling
Toshiba e-studio 232 says c440 code
This problem is caused by the thermister in the fuser section. To reset shut macine off, then turn it on while holding down the 0 and the 8 key down for more than ten seconds then release. This is service program mode, now press 4 then 0 then 0 and then the start key, you will see a nuber in the screen, press 0 then start key this should reset that code if not the thermisters need to be replaced
Apr 11, 2010 | Toshiba e-Studio 232 Black and White...
Get a CH02 error. Can't get service. No response.
i have the lg lp120hed units as well. i had a unit give me ch02 error a while back i replaced the unit with a spare....now the spare is not working either.
looking at the manual, ch02 error means "indoor coil thermistor error"....calling lg for that part now.
good luck.
Apr 01, 2010 | LG LP120HED Wall/Window Air Conditioner
My aircon unit turns on runs for a minute then indoor and outdoor unit switch off
If this is a LG Airconditioning unit.
It has reached the set parmeter of the safety switch point.
1 The unit could be running on too low refrigerant charge and cuts out on low temperature on the indoor unit coil (-5°C longer that 30sec switch off)
2 The unit might be drawing to much current, to much refrigerant, cutting out on high pressure.
Check the refrigerant charge and check the indoor pipe temperature thermister (calibrated at 5kΩ @ 25°C)
Mar 18, 2010 | LG Heating & Cooling
LG Dryer won't dry, no heat.
The heating coil is not too big of a problem to replace if you are mechanically inclined and have tools to do the job.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Oct 17, 2009 | LG DLE2512W Electric Dryer
LG split (3 indoor) LMU360CE system. The fans on the outdoor unit start and work. The compressors do not start-up. There is no error code on the indoor unit. On the outdoor unit the error code...
02 Indoor In-Piping Error 2 times OFF
There is a complete guikde to problems on page 66 of users manual. If you dont have one get back to me with your email.
Aug 01, 2009 | LG LMU360CE/LMN120CE Air Conditioner
LG GAS DRYER DLGO332W
You will have to check the thermistor as well as the rest of the sensor. Make sure the gas is off and the unit is unplugged befor you open the back of the unit. If the sensors test good than you may have a bad heating coil unit. All the parts can be tested for free at your local appliance parts supplier.
Jul 18, 2008 | LG Dryers
PANASONIC DUCTLESS SPLIT
Try to check the resistance of your room air and coil thermistor may be its out of range the reading of both thermistor is 8000 to 10000 ohms @ 25deg C temperature. if its higher or lower then the thermistor is out of range and need replacement. And try also to check your terminals and connector for loose.
Mar 18, 2008 | Heating & Cooling
Heating & Cooling Logo
24 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
