Question about Ricoh CL-7200 High Yield Toner Refill Kit 4 pack (riccl72004pk) for Ricoh CL-7200 CL-7300 CL7200 CL7300 CL7200C CL7...
Problem Ricoh CL 7200 error SC 542
Does anyone know the steps to clear this erro code? I was given them by a tech, but I lost them.
  • Ricoh Expert
  • 155 Answers
Fuser assy replace it and reset code or have tech come out and fix it
Posted on Oct 15, 2014
WHY RICOH AFICIO MP 171 SPF IS SHOWING SERVICE CALL SC 542.
Reseting SC 543 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Oct 18, 2016 | Ricoh Office Equipment & Supplies
Sharp photocopy machine showing error code Sc 542
SC 542 Basically the machine is telling you that the fuser did not reach its target temperature in a specified amount of time. In normal circumstances this code will appear if the thermistor is not maintained or replace periodically or in abnormal circumstance the heat lamp blew. This is a Service Tech reset code. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won't come ready until the prior error condition is cleared. basically you will have to care a service tech to clear it
Aug 03, 2015 | Sharp Office Equipment & Supplies
Hi, i have a error code SC 542 but i don't see Yellow Key [clear modes] button on control panel please send me deatil moeen_rauf@yahoo.com
SC 542 Heat roller warm-up error and for that you will need a technician since the machine may need some part replacement .
Feb 15, 2011 | Ricoh Aficio CL7200 Laser Printer
Error code, SC 547 on a Ricoh Aficio 1075
have you tried sc reset through the service mode and then turn off .. you can get to this by pressing yellow clear button then 107 then hold down the cancel stop button..wait for the screen to change then go to mode 5 and you need to arrow down to sp 5 810 sc reset execute turn off the copier and try turning on to see if it clears.. if not the ac board maybe defective caused by a power surge or static down the line..
Aug 05, 2009 | Office Equipment & Supplies
Sc 542 error code
press clear (yellow) and press 1,0,7 and press and HOLD the stop button 5 secs. (red) press 1 when u see the copy sp mode and press 7 (datalog) and press ok, look for the sc/ jam counter reset. press the execute 2x. turn of the machine in the main switch (orange switch on the lower front side) the shortcut mode is by pressing 7807 na press execute
May 22, 2009 | Ricoh Aficio CL7200 Laser Printer
Ricoh cl 7200 error code 374
The code may go away if you power on/off, but it will continue to return. It is a problem with the black development unit - replace it.
* please rate me :)
Mar 25, 2009 | Ricoh Aficio CL7200 Laser Printer
Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
Sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Aug 13, 2007 | Ricoh Aficio 2015 Copier
Ricoh CL-7200 High Yield Toner Refill Kit 4 pack (riccl72004pk) for Ricoh CL-7200 CL-7300 CL7200 CL7300 CL7200C CL7... Logo
169 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
