Question about Summagraphics SummaSketch III Graphic Tablet
SummaSketch III has no power
After a year of being dismantled, I reassembled my pc, with Windows 98. Every component works well -- the monitors, the keyboard, the mouse. But the SummaSketch is not powering up. My program does not detect it, and the light on it does not illuminate. The connections seems fine, and it worked well the last time I used this computer. Is there any way to revive my SummaSketch? I cannot access my files/documents without its functioning. It was purchased around 1996 or '97. The Dell computer is from around 2000. Thanks for any tips or help!
    Problem Solver:
  • 9 Answers
Absolutely, the Summasketch III needs a power pack, 12vdc which plugs into the RS232 plug (Computer side) Without this power supply plugged into the wall and into the cable the tablet will not work,
Try looking for a power supply at this URL: http://www.interwld.com/Home/FAQ.htm#SummaGraphics%20Digitizers
or the one: http://www.interwld.com/PriceLists/SUMUSPricelist.htm
Gerry
Posted on Oct 16, 2008
And just one more thing - there is likely to be a power switch along the top edge of the digitizer, as on my SummaSketch II Pro. It toggles the power - press it once to power up, press it again to power down. Good luck.
Posted on Aug 30, 2007
I have a SummaSketch II Professional. It connects to the computer's serial port. The serial connector has a piggy-back adaptor with a socket on it that accepts power input from a plugpack. Your SummaSketch III may require the same arrangement. If you don't have the plugpack connected your tablet will not be receiving any power, and that would explain why the power indicator lamp does not illuminate. Do a search on www.gtcocalcomp.com for details of the power requirement for you SummaSketch III.
Posted on Aug 29, 2007
SOURCE:
In a dell e177fpf lcd monitor all the capasitors fuses diodes in power supply and inverter board are ok.but the back lights remains 2 seconds.
Hello...I recently opened up my Dell E173Fpf monitor because the screen went black, yet the power button was green. I thought it was a capacitor problem. But before doing anything I gave the board a thorough inspection, looking for anomalies. I observed a substance, (later identified as silicon) puddled around the power connections. I gently removed the semi rigid stuff and didn't touch the capacitors as I had originally planned. I partially reassembled the monitor for a test run and it worked again. (Being 9 years old, I don't know for how long...) Only thing I can think of is that a spill happened at the factory and over the years it gradually "melted" to puddle around the wires behind the power input. (Weird, but that seems to be what happened.)
Dec 05, 2014 | Dell 17" e177fpf lcd monitor black
SummaSketch III drivers to work with Autocad 2004 and Windows 8
To use AutoCad with almost any digitizer, summasketch included it is recommended you download the driver from this site: http://www.vtablet.com only works with serial interface and costs +- $60 however they do allow u to use it for free for 30 days.
If u need a USB to serial that WORKS for your computer head to www.interworldna.com and search for the usbadpt adaptor
Hope this helps
Nov 02, 2012 | Summagraphics SummaSketch III Graphic...
System minimum requirements
System requirements never get smaller, but 7.0 bumps them up significantly. All systems need 128-MB RAM (192-MB recommended) with a CD-ROM drive and an 800x600 color monitor with at least 16-bit color (24-bit recommended).
On the Mac, you'll need a PowerPC (G3 or higher recommended) running OS 9.1 or higher (or OS X) with 320-MB of free disk space.
On Windows, you need a Pentium III or 4 running Windows 98/ME/NT/2000/XP with 280-MB of free disk space.
Jul 24, 2011 | Adobe Photoshop 7.0 for PC
Product Will not install
According to the Maxtor website, this device is only supported on Windows Vista, XP, and 2000. It does not work with Windows 95/98/ME.
Jul 06, 2009 | Maxtor OneTouch III R01E080 80 GB USB 2.0...
Elitegroup nForce3-A Motherboard
check the power cord of your monitor. If problem persist give it a nice kick and you should be OK.
Jan 20, 2009 | EliteGroup nForce3-A Motherboard
I can not use iball pen drive 4gb on windows 98
you will need the USB drivers to use the flash drive on windows 98..if you have the cd then install the drivers or look at the iball website
http://cr.am/framed.php?url=http%3A%2F%2Fwww.iball.co.in%2F&ref=driverguide
hope it helps!
Nov 18, 2008 | Microsoft Windows 98 for PC
Digital pen + SummaSketch III
Not sure what your problem is, the pen looks like the correct pen for a Summasketch III.
If you need to order parts or replacment digitizer got to this page where you can order them:
More infor on the Summasketch can be found at this link:http://www.interwld.com/summa/summasketchIII.htm
And FAQ at this link:http://www.interwld.com/Home/FAQ.htm#SummaGraphics%20Digitizers
Gerry
Aug 30, 2008 | GTCO (01-0339-001) Digital Pen
Skipping and Shaking cursor
I had a similar problem years ago w/ my ss III 12x12 that had worked flawlessly for years. I talked to tech support and they said move it away from monitor (crt) or other source of RF interference - this did not help mine. I tried replacing the power supply w/ generic one - no help. I noticed that the power supply voltage was spiking when check w/o load. After talking to an electric guy I know, he suggested a voltage regulator. Finally I built a home-made voltage regulator and wired it into the generic supply line -Problem solved This was about 10 years ago - still working good today.
Feb 23, 2008 | Summagraphics SummaSketch III Graphic...
Monitor goes to standby mode intermittent.
Sounds like this one needs component-level troubleshooting in the power supply section.
Dec 31, 2006 | LaCie Electron III 22" CRT Monitor
Open Questions:
We have a digitizer we are trying to resurrect: SummaSketch III with 4-button Diamond Puck 12 x 12 MM compatible version 1.91 Win XP SP2 (version 5.01 build 2600) Tablet Works 7.46.0619 com1 All buttons work and are assignable The puck works in mouse mode. In WYPIWYG mode there seems to be some problem: In Tablet Works Control Panel, the digitizer area doesn't stick - the (almost) whole digitizer area is still used; a small selectable area cannot be defined. I use this in AutoCAD with the Wintab Comaptible Digitizer ADI 4.2 - by AutoDesk. AutoCAD will recognize the tablet and allow me to configure regions and a screen pointing area. Menu items on the tablet work and the screen area allows geometry selection. Here's the problem (you could feel it coming couldn't you): Counting up from the lower left corner of the tablet The tablet "sees" (steady indicator light) from about (4.75cm, 4.3cm) (my ref: X-5) to (28.0cm, 26.5cm) (my ref: B-27) In the GTCO tablet configuration utilities the cursor can paint the test screen area from the lower left corner to about 75% of the test screen area up and to the right. A few years ago we had a problem with the puck: A button wasn't working. We repaired it. The cross-hairs cover fell out and the coil wire broke, we resoldered it. I don't remember clearly but we may have tried to replace some of the coil wire. Questions: How can I repair this here myself? If the coil is not the correct sensitivity will that cause the symptoms we have? What is the correct wire size and number of turns for the coil? Any suggestions on how to rewind it? The felt on the bottom of the puck is worn. Do you have a suggestion for a replacement material? What is a good way to keep the cross-hairs cover from falling out? We are a not-for-profit NGO that works to help rural villagers have good empolyment by making building materials on a small scale. We use AutoCAD to design buildings that use their materials and equipment and tools for them to produce the materials. We also mentor interns from local and foreign universities and colleges. We would appreciate any help you can give us. Sincerely, Geoffrey
Aug 31, 2011 | Summagraphics SummaSketch III Graphic...
Summagraphics SummaSketch III Graphic Tablet Logo
929 people viewed this question
Top Summagraphics Computers & Internet Experts
Ekse
Alun Cox
Are you a Summagraphics Computer and Internet Expert? Answer questions, earn points and help others
