Question about Panasonic MC-V9644 Bagged Canister Vacuum
Automatic cord return
The cord doesn't retract all the way. It stops with about 3ft. remaining out. Can this be repaired or replaced?
  • Anonymous Nov 24, 2007
    cord is stuck in place
  • 625 Answers
If it is anything like an electrolux there is a coiled spring inside that free wheels around a hub. pulling the cord too far out makes the spring slip on the free spinning hub. you may need to take apart the vac and rewind the spring.
Posted on Aug 29, 2007
SOURCE:
Husky power cord reel won't retract
spring in cordreel is sprung. cord is probably on last leg. Go to vac replacement parts online store and order a new one.
Feb 04, 2013 | Vacuums
Cord retractor doesn't work
does it retract at all or not at all? or does it not stop when the cord is pulled out any amount?
Oct 20, 2011 | Electrolux Guardian Bagged Canister Vacuum
My Miele Carina Vacuum stopped working. Does it have a fuse that can be replaced that could be at fault here?
although it might have an internal fuse on this model, I dont think that will be the problem.
The miele cord rewinder has been known to have a small fault in it where the cord winder that actually retracts the cord onto will come apart from the electrical connection in the cord winder itself.
As most of these units have a 5 year warranty anyway, I suggest that you take it to your nearest miele dealer for a repair/replacement on the cord rewinder.
Good luck.
Nov 06, 2010 | Miele Carina Vacuum Vacuum
The retractable cord will no longer retract into the vacuum. The vacuum is a month old.
rewind spring broke return to where you bought it for replacment
Feb 10, 2010 | Vacuums
Blue sparks from motor stopped working
either cord shorted out or switch failed would replace cord first if that doesn"t work probably have to take into repair shop
Jul 04, 2009 | Kirby Vacuums
Electric cord won't retract
Depends on the machine. If its a Sebo K model then usually pulling on the cord will re-automatically retract the cord anyway. Any other brand and it will need to be replaced by a qualified repair.
May 06, 2009 | Vacuums
Cord will not remain OUT..keeps slip-sliding back in
The return is stuck on your cord retractor. Take the machine apart untill you can see the retractor, then there is a button or wire that retracts the cord. If it is stuck in the down possition simply reset it, if it is broke you must replace the complete cord retractor.
Apr 11, 2009 | Hoover S3755 WindTunnel Bagless Canister...
Sanyo vacum cleaner SC-815
The power cord does not stop and retracts automatically, how do I re-tension the cord,
Do you have copy of instruction manual or manual on repair?
Apr 19, 2008 | Sanyo SC-800P Bagged Canister Vacuum
Panasonic MC-V9644 Bagged Canister Vacuum Logo
308 people viewed this question
Top Panasonic Vacuums Experts
Archie Ferrarini
Archie Ferrarini
jasbo
jasbo
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
