Watches Logo
A
Anonymous Posted on Jul 19, 2013
Xhilaration fmdx208 watch - Watches
TGXL103GRN
TGXL103GRN Check inside watch where the battery holding area has a metal tab to secure it. There's always a big gap btwn the tab/batt area and where it makes keyboard contact. To fix:
1 remove screws and watch back.
2 put tiny screws in dish
3 notice battery condition/position.
4 change batt if necessary
5 fold a tiny piece of paper to fill gap
6 use tweezer to put in place (no foil, no glue)
7 to test if gap is gone, close watch
8 must screw shut + reset to test
9 be patient, adjust as needed
10 take care to not strip screws.
Jan 26, 2013 • Watches
How set time and date on xhilaration FMDX204 digital stop watch
Did everthing and it still wont stay at the time a had it set at
and i have the xhilaration FMDX206 52.
Dec 26, 2012 • Watches
4helpful
How do I turn off the alarm on a xhilaration FMDX248 I have no instructions!
hold reset and then push start at the same time...the alarm bars disappear
Dec 20, 2012 • Watches
9helpful
I bought a pink and purple xhilaration watch from target, on the back of it, it saysTGXL103PNK, CHINA, MODULE, CR2032, 0712, AWC............ it has to two side buttons on the left side and one on the right...
press on the MR/C (set) button. This button is located on the calculator buttons area of the watch. Hold this button until the date begins to blink. you select the numbers you want to set the date and time to by pressing the correspondent numbers on the key pad. once the date and time is set press the enter key.
Oct 30, 2012 • Watches
How do you shut alarm off on xhilaration watch fmdx253?
This site had the answer.
http://www.dakotawatch.com/PDF_FILES/Digital.pdf
Aug 21, 2012 • Watches
4helpful
How do I set the time on my xhilaration watch
press the setup button 3 times then followed by the right side button then press & hold the left side button for 5 secs. May take 3 or 4 tries to get it right.
Jun 07, 2012 • Watches
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
