Question about LG Televison & Video
'NO SIGNAL' display on TV
LG HB966TZW. When DVD played the surround sound system works fine but the TV displays NO SIGNAL. Changed HDMI cables, no change! Any clues or remedies would be appreciated.
    New Friend:
    Problem Solver:
  • 7 Answers
Are you with a tv provider? try unplugging your tv and all, wait for couple moments a nd replug in. then you will have to wait for the tv to catch up. it should give you the display. good luck
Posted on Jul 20, 2013
SOURCE: how do i get my ps3 to run through my lg surround sound
Connect your yellow and red lead from the PS3 to the surround system, connect them to aux input. (the white lead is not needed). Then in the sound settings on the PS3, go to audio multi-output and change it to on. On your remote for the sound system press the input button until aux appears on the front of your LG HT303SU, and thats it, happy gaming.
Posted on Feb 17, 2010
SOURCE: Compatibility with Samsung LCD Display
It sounds like the HDMI port on the back of your Marantz is damaged. if you know for sure that the HDMI port works on another tv still you might just use component connection because the visible difference between component and HDMI is not very recognizable.
Posted on Jan 13, 2009
jomabug76
  • 1148 Answers
SOURCE: No sound from TV to home theatre system
hdmi does sound to,,,try if the reciever has hdmi,,unhook the optical cable and try it by itself,,and vise versa
Posted on May 17, 2009
SOURCE: Distorted color on hdmi output
If you haven't already stumbled across the fix: I just had the exact same problem after about eights months of casual use. Unplugging the DVD player for about 15 minutes and then plugging it back in "solved" the problem. Until next time it happens, anyway.
Posted on Jun 01, 2009
SOURCE: YOUR TV DOES NOT ALLOW DISPLAY OF THIS PROGRAM THROUGH THE DVI IN
I solved the same problem by disabling SIMPLINK from OPTIONS menu. I own the LG TV myself. The LG TV comes SIMPLINK "ON" as default setting from the factory. Go to MEMU -> OPTIONS -> Turn SIMPLINK to "OFF". This should work....
Posted on Sep 23, 2009
I have a LG LHB335 Blu-Ray home theater system, & a LG TV I can get Full surround sound when the blu-ray is play a DVD but not when just watching Reg TV. I use a HDMI, should I hook up sonething else ?...
LG documentation states:
When you use SIMPLINK function, you have to
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
Jan 11, 2011 | LG LHB335 Theater System
What cables do i need to connect my ps3 to my sony recevier.
do you wan the suround sound to play sound for what the tv is displaying or just the ps3
for just ps3
connect hdmi to ps3 and tv
connect optical to ps3 and suround sound
change video settings to hdmi
change sound settings to optical
it asks to set settings automatically you have tyo doo it manually
if you want to play every thing that tv displays then
connect ps3 to tv with hdmi
connect suround sound with hdmi to tv
(this might not work)
if it dont work then
and your tv should have sound out or something along those lines it should be two phono plugs in the back of the tv connect that to the suround sound
Dec 31, 2009 | Sony HT-DDWG700 Theater System
I have a 5.1 jvc dvd surround system and have just bought a 37'' new lg tv. The system plays in stereo when listening to just tv. It does not have an HDMI connection on the DVD. Can i update with a blue...
Your LG tv should have an optical output socket,if your surround system has one as well,(input) then connect an optical lead from the tv to the system,then select either input 1 or opti 1(depending on your system) you will then get the sound from whatever you are watching on the tv
Nov 04, 2009 | Televison & Video
Issues Displaying picture from HDMI upconversion
I've posted this other places. Hope it helps.
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
May 22, 2009 | Onkyo HT-S5100 Theater System
Cant get my viera linked panasonic to play through surround sound
I had the same problem, so i contacted panasonic, I am including the email they sent me.
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Dec 16, 2008 | Panasonic Home Theater System System
I want to connect the Audio from tv to Surrounding audio system
Thank You,
Panasonic Consumer
LG HT 503PH Hi-Fi Surround Sound only come with one black lead that fits into the TV but nowhere to fit into the DVD system
You need to get an optical cable (not supplied with the system of course!). Will cost about £20. That will fit from the sound system to the TV to give you 5.1 surround (else you're stuck with stereo) and THEN you need HDMI from your DVD to the TV... presuming that's the way you're going. Else it's whatever you output from DVD to the TV and then the TV sees you have optical out and pushes the sound to the 5.1 system.
Dec 11, 2008 | LG Televison & Video
Samsung surround sound wont connect up properly to samasung plasma tv
i have a plasma samsung 42 inch and i dont know how to connect my jacks red,white, yellow from the dvd to the plasma and what channel should the plasma be on to see the dvd ???? thanks anthony
Mar 28, 2008 | Samsung HT-Q100 System
Rookie to Sound System
are u runing tv throw system and video ? with hdmi then back up to tv hdmi best to run hdmi cable from dvdplaye rto tv direct ok then dish box ect cable hdmi out direct also to tv then use optical out put digital on tv outto sterio digital in on back ok for tru 5.1 best way to do this is this way
Jan 30, 2008 | LG LHT734 System
Televison & Video Logo
150 people viewed this question
Computer Repairing
Computer Repairing
