Question about LG LFD25860TT Titanium French Door Refrigerator
LG LFD25860TT ice maker not working ice forming in back of freezer
My LG (freezer in bottom) ice machine is not working and ice is forming on the back right side of freezer.
  • 1462 Answers
SOURCE: Another Ice Maker Problem
i suspect that repair man got it wrong. ice may be blocking return duct to fridge. worth a chance to turn off for 24 hours with doors open then retry
Posted on Jun 14, 2007
SOURCE: water pooling and freezing inside bottom freezer
I had the same problem with my LRFC25750 and have finally figured out what's happening! The water that is pooling and freezing on the bottom of the freezer is definitely coming from the defrost cycle. It is pooling inside the freezer compartment because the drain inside the back of the freezer intended to carry the defrost water down to the external evaporator tray underneath is blocked with ice. As a result, the defrost water from the coils overflows the collector under the coils and runs down the inside back of the freezer, pools on the bottom, and re-freezes when the cycle is over. this continues until there's so much ice on the bottom that the water from next defrost cycle runs out on the floor. The "easy" solution is to unplug the unit and let it completely melt out (this could take 24-36 hours). I couldn't wait, so I removed the freezer drawers and their tracks and pulled out the back panel inside the freezer -- saw the ice in the collector and blocking the drain and I melted it away with hot water and verified that water could now flow down to the external evaporator tray. Unless you want to do this, I'd say give it a good 24-36 hours for all the ice to melt away. I think it all started when we left the freezer door ajar for a whole day and probably had a lot of frost build-up on the coils. The next defrost cycle was not enough to clear all the frost and things began to build up from there. Once the drain is frozen, though, you're finished -- the defrost heater doesn;t reach down that far and you have to melt it down completely or it will continue to leak forever. I've heard that you can get a drain heater to ensure that the drain never freezes over or at least so that it is sure to clear with each defrost cycle. I'll post an update if I locate one.
Posted on Sep 03, 2007
  • 489 Answers
SOURCE: Lg side by side Ice maker not filling all of the tray/dripping
You may have a restriction in the icemaker.  Remove the icemaker and make sure that there is no ice buildup other than in the cube slots.  Also make sure that the fill tube is clear of any ice obstruction.
Posted on Apr 27, 2008
rickzilla
  • 706 Answers
SOURCE: Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
Posted on Sep 15, 2008
  • 4 Answers
SOURCE: LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
Posted on Mar 21, 2009
What has caused my water inlet pipe feeding the ice making machine to freeze?
It seems there is some blockage in copper tubes ( capillary)
Need to flush internally and then refill refrigerant
Jul 20, 2016 | LG Refrigerators
Fan inside fridge not blowing
is the ice on the floor of the freezer?if so the freezer drain is blocked,ice is building up and the fan blade is jammed from the ice.when the machine gets cold ice forms on the evap coil in the freezer,when it goes into defrost the heater turns on and melts the ice and the water drains down a hole under the evap coil and the water goes down into a pan where it evaporates from the heat of the compressor and condenser coil but your drain is blocked and the water is leaking onto the floor of the freezer instead of going down the drain,i use a steemer to clear blocked drains but if you don't have a steemer you can use a hair dryer to melt out the ice,on your machine you can pull out the machine from the wall,remove the back bottom panel and unplug it first,then look at the right side,you'll see a plastic drain line with a wire tie around it,that's the drain line,you might have to cut the tie and then pull the drain line down and remove it,now go to the freezer,you have to remove the door and racks and then remove the back inside wall of the freezer,melt out all the ice that you see with the hair dryer,after you melt the ice go to the back and snake a long plastic tie like the one that's on the drain line or if you have a piece of 1/4 inch plastic water line or anything you can think of to snake through the hole where the drain line came off of,i would use plastic,if you use metal be careful not to damage anything,then pour hot water into the drain in the freezer,if it drains out the back hole you're done,if not keep hitting it with heat and if you have a turkey baster or anything that will push air down the hole to clear it and when you think it's clear pour more hot water into the hole until it drains.hope this helps and good luck with your machine.
Nov 15, 2011 | LG LFD25860TT Titanium French Door...
My ice maker quit making ice on my amana bottom freezer
Hi, If your ice maker has stopped making ice then you need to check these things.
The lever that controls the ice maker has been pushed up which turns it off. If you have a red lever, pull it down to the wire and if you just have a wire then just pull down the wire to start your ice maker up.
Make sure the freezer temperature is below 10 degrees F If the freezer is too warm ice production will be poor because the ice maker will not cycle properly.
The ice maker fill tube may have ice formed in it, blocking it. Use a hair dryer to melt the ice. Watch out for the plastic parts, so that you do not melt the plastic. Also check the water inlet valve and the shut off valve, to make sure it is not plugged with debris. The openings in those valves are very small.
Check the gears in the ice makers to see if they are broken or stripped. Also look to see if the ice rake is broken. All parts in the ice maker are replaceable individually, If you find broken parts replace them.
Take care
Jul 23, 2010 | Amana ABB1927DE Bottom Freezer...
Ice maker is not working. Light goes on but no water fills the maker Model LFD25860TT
Pull the line off at the icemaker and check for a filter at the inlet...often **** builds up there and stops off the water...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 12, 2010 | LG LFX25960ST Stainless Steel French Door...
Not making ice error code 1f
heatman101
Jul 12, 2010 | LG LFX23961SW Bottom Freezer French Door...
GE Monogram refrigerator/freezer problem/ice dam in ice maker
I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
Mar 26, 2009 | Refrigerators
Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Apr 12, 2008 | Refrigerators
Ice in freezer compartment
I have seen this problem with the LG freezer unders. There is a air leak that is getting into the freezr allowing the moisture to frost up at the back of the freezer. It will form frost all over too. Since your unit is 8 month old call Lg and let them deal with the problem. At my last Lg training the problem is with the air damper in the fresh food section may not be closing fully. So Call for service.
Jul 12, 2007 | LG LRFD22850 Bottom Freezer Refrigerator...
LG LFD25860TT Titanium French Door Refrigerator Logo
60 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
