Question about Refrigerators
Psw26pssb no water to ice maker,there is water to door dispensor
HVACRH20
  • 237 Answers
SOURCE: Ice maker not dumping ice
Make sure the freezer is at least 17 degrees or colder (colder is better). If you have a square cover on the end of the ice maker see if you can pull it off and press on the gear face (don't turn just press). That may clean the electrical contact springs and get it working again. Basically if ya got water, 17 degrees or colder you will get ice. Other than that the ice maker motor module is likely bad (broken gear, etc.). Pretty common.
Posted on Nov 09, 2006
fridgetech
  • 473 Answers
SOURCE: Ice maker not making ice
Chances are it will be best to replace the ice maker but give me your complete model # from the sticker inside the fridge.  Also, make sure the fill tube to the ice maker isn't frozen up.  There should be a 3 digit # in front of the 52554100.
Posted on Oct 18, 2007
SOURCE: water dispensor not working in door
when the chicken crosses the road!!
Posted on Jan 30, 2008
maklean
  • 1665 Answers
SOURCE: no water to ice maker
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Posted on Jul 28, 2008
    itls
    • 17 Answers
    SOURCE: GE side by side refrigerator: water/ice dispensor
    I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
    Posted on Mar 16, 2009
    Parts inside my ice maker in the door fell out cant figure out how to get the front panel off the ice and water maker
    Remove the top freezer door hinge cover and disconnect the plug there . This removes all power to the door so the refrig can still run while working on the dispensor . Use a butter knife slipped down between the lower portion of the dispensor cover and the main dispensor from the inside and press down . There are 2 plastic tabs holding the lower cover in place . After the lower portion is unclipped , lift upwards to remove the top portion . Disconnect the plug to the dispensor front . There are 3 or 4 screws holding the white " body " in place , so remove them and it should slide out a little ways to allow access to the inner workings .
    Jun 08, 2010 | Estate TS25AFXK Side by Side Refrigerator
    GE REFRIGERATOR'S ICE DISPENSOR PROBLEM
    CAN U TELL ME WHAT YOU DID TO FIX THIS PROBLEM. I AM NOW EXPERIENCING THAT EXACT PROB!
    Nov 09, 2009 | GE Refrigerators
    The ice maker stopped making ice. Any solutions?
    A lot of filters ( not all ) do not even access the ice maker . Only the water dispensor . If your water dispensor is working fine , then you need to replace the dual water inlet valve behind the refrig . This is the piece the wall water line connects to . It is called a dual valve because there are 2 coils on the valve . 1 for the ice maker and 1 for the water dispensor .
    Oct 23, 2009 | Kenmore Refrigerators
    I have cold water but the ice maker is not working, there is no water in the ice maker
    The refrig has 2 coils on 1 valve . 1 coil is for water dispensor and the other is for the ice maker . You need to replace the water valve behind the refrig . This is the piece that the wall water line connects to on the refrig .
    Oct 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
    My ice maker stopped making ice all the sudden. there is no water in the ice maker
    do you have a water dispensor in the door? if you aren't getting water check the filter. if the water line is not clogged you may have a bad water fill valve or the motor/gear in the ice maker is bad.
    Sep 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
    Ice maKer is not getting water but the water side works.
    Your refrig water valve , has 2 coils on one valve . One is for the water dispensor , and one is for the ice maker . So even if you get water thru the dispensor , the other coil ( for the ice maker ) could be bad . The fill tube from inside the freezer to the ice maker , could be frozen solid , keeping the water from entering the ice maker . This frozen tube , would be caused be the water valve " seeping " , which means , it isn't closing completely , and drips freezing inside the tube . indicating a bad water valve . Pour about 2/3 cup of water into the ice maker . If it dumps , but doesn't refill with water , replace the water valve but also check this tube . If the ice maker does not dump the frozen cubes , replace the ice maker , but also check the coils under the refrig , for dust , lint , etc , needing to be cleaned off . The ice maker needs to be 5 degrees to operate , and dirty coils can keep the freezer at 6 degrees or above .
    Sep 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
    GE Profile Artica - Water & ice dispensor not working.
    This could be as simple as the door switch or as complex as the dispenser control board. I would try the door switch first. When the door is close it turns on the dispenser controls. If the contact is defective in the door/light switch then this happens. Unplug remove the door switch and mark wire locations. 1 Powers the lights and the other powers the dispenser. and one is the power itself. Sea Breeze
    Jul 26, 2009 | GE Profile Arctica 25.4 Cubic Feet...
    Ice maker works, fills door but doesn't come out
    You have a bad dispensor flap solenoid . Frost due to flap not closing completely and ice will catch in the shoot .
    Jul 25, 2009 | Whirlpool GS6SHAXLS Side by Side...
    Refrigerators Logo
    19 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
