Question about Brother Sewing Machines
Empisal sewing machine ESM 2900
My timing is out and the thread is not catching, how can i reset the timing?
louislevel_2
  • 374 Answers
SOURCE: need sewing machince help????
hi;
breaking thread and thread below not hook up by upper thrread, this is due on not properly set up of thread tension,first check bobbins windin35caecd.jpgg see figure.the threads should
be counter clockwise.
the theading on upper set up should prorerly inserted follow figures.7dabcae.jpg
the dial set up tension should start at #3 to # 5
the stitch tension should be set to # 8 to # 12
use trial run for fabrics,diffferent set up in every fabric tru to study before sewing in other fabrics.have a nice day don't forget to rate me.thank s a lot
Posted on May 17, 2009
  • 5 Answers
SOURCE: Sewing Machine (brother XL 3200)
You may have the bobbin case in wrong.  I have this machine, and I know that it is really easy to put the bobbin case in wrong.  Try taking it out and making sure that the little stop is in the front and it is seated down in there and able to wiggle back and forth.  My experience with this machine, until the other day when my cat knocked mine off the table and knocked something out of alignment, is that it just works.  Any time mine hasn't worked, it has either been dirty, needing oil, threaded wrong or the bobbin case wasn't seated right.  In other words, it has always been my fault.
Posted on May 25, 2009
  • 9 Answers
SOURCE: NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
Posted on Jun 14, 2009
  • 18 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Posted on Aug 16, 2009
  • 1116 Answers
SOURCE: Purchased a HomeStyle sewing machine Model
Check the needle to see if the flat side is facing to the back of the machine. This is usually how the needle should be inserted.
Thread the machine with the presser foot up.
Hold onto the thread tail at the needle and hand walk the needle down and then back up to pull the bobbin thread up.
Take both threads under the presser foot and to the back of the machine before you begin to sew.
Posted on Feb 21, 2010
Empisal creations and episal EXP889 sewing machines.... which is the better one and more recent model
It really depends on what You envision yourself doing with the sewing machine and then finding the machine that has the most functions that fit your needs.
Empisal 889:
  • 36 Stitch functions
  • Front load bobbin
  • On/off switch
  • Left and middle needle position
  • 18 Stitches
  • 4 Step buttonhole
  • Stitch width control
  • 4.5mm Maximum stitch width
  • Soft cover
  • 4.5mm Maximum stitch length
  • Reverse stitch
  • Twin needle
  • Free arm
  • Carrying handle
  • Uncoupling bobbin winder
  • Clip on, clip off foot
  • Drop feed
  • Sews on buttons
  • Zipper foot
Empisal Expression 889 Sewing Machine Empisal Sewing Machines
Empisal Creations
  • 4 Step buttonhole
  • 19 Built-in stitch patterns
  • Oscillating hook
  • Sews on zips
  • Adjustable stitch length: 0 - 4mm
  • Adjustable zigzag stitch width: 0 - 5mm
  • On / Off swithch
  • Free Arn
  • Accessories
  • Reverse stitching
  • Horizontal spool holder
  • Self uncoupling bobbin winder
  • Cover on accessory compartment
  • Large working surface
  • Thread cutter
  • Adjustable presserfoot pressure
  • Built-in tension
  • Darning plate
  • Fold away carry handle
  • One touch snap on foot
  • Versatile utility stitches
  • Sews through heavy fabrics
  • LED lighting
Empisal Creations Sewing Machine Empisal Sewing Machines
https://www.russells.co.za/empisal-creations-sewing-machine
Dec 11, 2017 | Sewing Machines
Hi i have a empisal 550d overlocker . I have difficulty with cotton breaking after sewing for a few seconds. Can you help please ?
Could be the tension is set too high on that particular thread tensioner.
If it is not the tension, then this is the first thing to try (I know, it's painful but 99% of the time takes care of my issue): Remove all the threads from the machine, ALWAYS RAISE the presser foot and then rethread from the beginning. Verify that you are threading each in the "proper" order and that the threadpath for each is correct.
If it is a needle thread, replace with a brand new needle. Try a different brand of thread or spool on that particular threadpath. AVOID old or bargain bin thread. Check to make sure that particular thread is not hanging up on a burr, a sharp spot, or looped in the thread tree, etc. that catches the thread and holds it from advancing through the path.
Serger needle thread breaking sewing discussion topic PatternReview com
Lower Looper Threader Keeps Breaking Thread sewing discussion topic...
Jun 09, 2017 | Sewing Machines
How do I thread an empisal sewing machine 7610? Please help.
This is their web-site. if you don't find your specific machine, look for one that is similar - threading should be the same.
http://www.empisal.co.za/instruction-manuals/
Apr 01, 2017 | Sewing Machines
Step by step how to adjust the timing on my empisal dress maker 270D
Search the internet for:
sewing machine timing
There are multiple web sites an videos available.
Jan 03, 2017 | Sewing Machines
How do you thread an empisal vogue 66 sewing machine?
Perhaps you can get an instruction manual here:
Empisal Sewing Machine Instructions
You can look around on the internet for similar style sewing machines. Frequently, the threading sequence is very similar.
Nov 09, 2016 | Sewing Machines
I need to know how to thread a empisal purdy 444 sewing machine
Most machines thread basically the same.
Thread spool
Thread guide
Thread guide
Tension
Take up lever
Thread guide
Thread guide
Needle.
There may be an extra or one less of the guides but for the most part I've been able to thread any machine.
Good luck and god bless
Angela
Sep 11, 2016 | Sewing Machines
How to thread a Empisal overlocker.. model 760C
Perhaps the manual would help:
Empisal Overlocker 760C Empisal Sewing Machines
On most machines, it is important to ALWAYS raise the presser foot when threading the machine (although the instruction manual says to raise the presser foot only to pull the thread tail under it). Be sure to give the thread an extra little tug when going through the tension disk to seat it properly. Be sure to thread in the order as specified (Upper looper, Lower looper, Right needle, Left Needle). If the machine messes up, it is usually a best policy to remove all the thread and rethread from the beginning. Threading out of order will almost guarantee failure!!!
Jul 20, 2016 | Sewing Machines
Empisal dressmaker 270D - top thread wont catch bobbin thread
Thanks for the advise, but I've opened the magine and it looks like at the back of the bobben, the part that controls the bobben has missed or skipped a louver so that's why my magine does not grab the cotton. The bobben case is not rotating the way it suppose to.
Jun 04, 2014 | Sewing Machines
Sewing Machines Logo
108 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
