Question about Dryers
Wtl 6100 manual
Hello I need the electronic schematic of the control module of a Bosch WTL6100/01 thanks
5 Suggested Answers
  • 5 Answers
SOURCE: How hard is it to replace the heater of a bosch
Hi - not 100% on that model but many of the recient dryers have their heaters at the raer (as oposed to the around the front door) so are easy to remove after you unscrew and lift off the rear cover... a 10min job once the machine is out.
Posted on Feb 20, 2010
SOURCE: Bosch Maxx WTL 6100 tumble dryer - door switch
i have wtl 6100 bosch and the mashine is not running. There is power on the machine, it can run but it can not run and heat. I can get light in al the panel, but it is like it needs to be rebouted. I can get it to show 111,222,333 etc in the window but i cant get it to work
Posted on Sep 05, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Hello, there is no heat
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape and running the dryer to check to see if the element is red or not,
or with an ohm meter check the two terminals of the thermostat/thermister
after you have removed the wires, the thermostat/thermistor should have/show continuity across the terminals.
If the coil heats up, or the thermostat/thermistor shows an open circut
then replace the thermostat/thermistor as it is defective.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the an element go to the following website, it will give you an idea what you are in for:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Jan 02, 2011
  • 39 Answers
SOURCE: I need the user manual for Bosch WTL 4613
0027 516659 Instruction manual de,nl,fr,es,en,pt,it 7.80 USD Unfortunately my search on-line for this manual came up short. You can order one directly from bosch at their appliance website. The cost is $7.80, the part number is 516659. Weblink: eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodp.htm?prod=WTL4613%2f01&ESHOPTYPE=A">http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodp.htm?prod=WTL4613%2f01&ESHOPTYPE=A
Posted on Jan 30, 2011
My dryer working but not get hot conden water sign blinking what is this mean.
If dryer is not getting hot check the condition of the heating element(s).
Oct 10, 2015 | Bosch Dryers
How do I run a self diagnostic on Bosch Classic Electronic SGU53E75AU/86?
Before going to the controller it might be better to verify the heater or thermostat (NTC).
If you want to know the part details refer this schematic
http://www.bosch-home.co.uk/store/spareparts/Builtunderdishwasher/SGU53E75AU/86
It is interactive and you can switch between assembly drawings and parts lists. The heater and thermostat are drawing 4.
Apr 26, 2014 | Bosch Dishwashers
What does E1 mean?
Welcome to FixYa.
Can you possibly double check that model number and reply post. I ask because the "E1" error should only pertain to those models which are condensor (non-vented)... "WTL" dryers.
The error indicates either a blocked drain hose or a failed pump. This from Bosch...
E1 Pump failed
(WTL 5400condensationdryer only) Pump failed.
Check voltage at and wiring to pump.
Turn off dryer, measure pump resistance (110 - 136 ?) and replace faulty pump.
Also - Following items apply only to the WTL (Condensation Electric Dryer) models
Cycle is interrupted and ''E1'' appears in display• Condensate hose is blocked in some way. Turn off dryer and check hose.
I'll watch for your reply and try and help you move forward in any manner I can.
Regards,
Macmarkus :)
Apr 14, 2011 | Bosch Axxis WTA 3510 Electric Dryer
I need the user manual for Bosch WTL 4613 electronic tumble drier
Jan 30, 2011 | Bosch Dryers
How hard is it to replace the heater of a bosch dryer wtl 6100. Do I have to dismantle the entire dryer or just plug-play from the back side?
Feb 08, 2010 | Bosch Axxis WTL 6003 Electric Dryer
Load capacity of WTL 5410
7 kg is the max this is quoted as dry load not wet halfed when wet.
May 30, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Oct 25, 2008 | Dryers
How to clean the bottom filter
Don't know how old your machine is but on my wtl5400 the bottom flap is opened by:
1. open the drier door
2. note small round button on the lower right hand side of the drum surround
3. press the button which will spring forward then
4. lower filter cover springs off giving acess to filter drawer
NB if the filter is over full the button will spring open itself as a gentle hint
NNB YOU CANNOT CLOSE DOOR WHILE THE BUTTON IS EXTENDED so take care door will only close when lower cover has been correctly replaced relocating the button flush with the front of the machine
Aug 28, 2008 | Bosch Axxis WTL 5400 Dryer
Bosch WTL6300 condenser dryer
From experience, it will quite probably be a fault with the PCB controlling electronics. Worth checking all wiring is in place as machines do vibrate and can cause wiring problems.
Aug 10, 2008 | Bosch Axxis WTL 6003 Electric Dryer
Dryers Logo
66 people viewed this question
Top Dryers Experts
