Question about DR Scholl's Foot Spa Plus with Infrared Heat
Can you use epson Salt for soaking without harming spa?
What happens if I put too much salt in dishwater
Hey Des,
I assume you're referring to the pool rather than dishwater. Adding too much salt won't necessarily do harm instantly. However, to some swimmer, the high salt content can be quite rough on skin and even hair. Aside from swimmer experiences, any masonry around your pool will erode quicker over time due to salt being extremely abrasive by nature. I'd recommend getting a salt tester strip or electronic meter to check your salt.
To add on, if the salt generator is constantly saying to add salt, it's probably time to clean your salt cell also.
Sep 15, 2017 | Pool & Spa
HOW DO I REMOVE TO MUCH SALT FROM BILTONG
You can soak for awhile in Warm water. Change out the water a few times to get rid of any excess salt. You can add a bit extra brown Sugar to this to flavor out any remaining salt. Hope this helps.
Sep 29, 2014 | Pool & Spa
What is code 91 on intex 8110 model
This is the code for "Low Salt"... Could mean two things
  1. Low Salt and will need to test ppm and add to target 3000ppm
  2. Dirty electrolytic cell, soak with vinegar and flush clean..
Hope this helps!
Aug 20, 2011 | Intex Automatic Salt Water System for ...
Getting a code 91 LOW SALT. We have had our pool since June. Took a sample to the local pool shop for them to diagnose and my salt was at 4200ppm. It is still triggering low salt....any suggestions?
Usally if the salt level is above 2000 ppm, it's the electrolytic cell. Did you look inside and verified it did not have any white flaky buildup on the plates??? Do the following if you haven't already and see if the low salt alarm goes away..
  1. Remove the cell unit and cap one end...
  2. Fill the unit with white vinegar and let soak for 24 hrs...
  3. Flush with pressure nozzle until clean.. ( If you can still see some white stuff on the cell plates, soak for and additional 6hrs and flush again)
  4. Re- assemble and set your cycle according to your chlorine level...
Hope this works for you!!!
Aug 11, 2011 | Intex Automatic Salt Water System for ...
My pool is definatly oversalted but the pump keeps showing low salt. When tested it shows no chlorine. Is this two diferent problems or all related to the same and how do i fix it?
Low salt alarm also comes from having the electrolytic cells "dirty" of calcium/sodium build up.. Check and soak/clean with vinegar.. Shold solve the low salt alarm.. Hope this helps???
Aug 05, 2011 | Intex Automatic Salt Water System for ...
I added three bags of salt and let it dissolve and still get 91 everytime I try to start the salt water system
Have you checked the electrolytic cells? If any white calcium present, you will need to clean with vinegar..See you manual on how to soak...
Please rate if helpful
Jul 24, 2011 | Intex Automatic Salt Water System for ...
Will the saltwater harm the grass if I drain the pool?
Most salt systems need 3-4000 ppm of salt in the water to operate. (which is no big deal).You will probably do more damage" Drowning" your lawn.There is a lot more water in there than you might think.
Sep 27, 2010 | Intex Automatic Salt Water System for ...
What do i use to clean the copper cells
Soak the unit in vinegar. cap off one end the cap came with the unit
let soak for 6-12 hours
check your salt level sounds like you have too much in the pool
get salt to 3000ppm
Aug 29, 2010 | Intex Automatic Salt Water System for ...
DR Scholl's Foot Spa Plus with Infrared Heat Logo
76 people viewed this question
Top DR Scholl's Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a DR Scholl's Health and Beauty Expert? Answer questions, earn points and help others
