Question about Lithonia Lighting Home
NEED WIRING DIAGRAM FOR 1B 632 MVH TO 277V
No info came with this light fixture, want to make sure the wiring is the same for 120v and 277v as it states on the box. but again no wiring info came with it.
3 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: Need wiring diagram for T104M
Here is the basic instructions:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t104%20-%20english.ashx
Below is a larger and better diagram of a 240V connection Terminal connections are White to White on 3 & 4 Black to Black on 1 & 2:
http://waterheatertimer.org/images/T-104-control-240V-Load4-35.jpg
More info: http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
I am assuming you have the 240 VAC clock motor so the clock timer motor wires are connected to terminals 1 and 3.
If you only have the 120 VAC clock motor the wires will be connected across terminals 1 and 2.
Thanks for choosing FixYa,
Kelly
Posted on Jun 27, 2011
  • 5245 Answers
SOURCE: new fixture installation
Fixture is not identified.
Usually each light fixture is held in place with 2 screws -or- a center nut.
Remove old light and you can see 2 wire nuts covering black wire and white wire, and possibly another wire nut covering green wire or bare copper.
Untwist wire nuts.
Attach new light fixture wires same way as old was removed.
Make sure black wire goes to black wire on light. White to white, green to bare copper.
Copy and paste following links to see basic wire nut, and single-pole and 3-way switch wiring:
http://waterheatertimer.org/How-to-select-right-wire-nut.html
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
Posted on Jun 26, 2012
How to wire a cooper Quadra Mark MH 277 Volt light
Quadra mark is commercial metal halide light
It appears the 208-240 480V model is different from 120, 277 or 347V model.
You cannot connect 277Volt light to 240Volt
These are two different things.
Commercial 277V has 1 hot leg and a neutral (very similar to residential 120V which also has 1 hot leg and neutral)
http://waterheatertimer.org/images/How-to-wire-outlets-14.jpg
While residential 240V has 2 hot legs
http://waterheatertimer.org/See-inside-main-breaker-box.html
Check rating label on light and see if it shows 120V in addition to 277V
If rating plate shows 120V, then it should work.
Residential 240Volt has 2 hot legs, each Hot leg measures 120V to ground
So you can use one Hot leg from the 240Volt breaker, and use ground wire to make 120Volt circuit.
Using ground wire to complete circuit in this manner is completely out of code and not recommended by any professional electrician. But it will work.
http://waterheatertimer.org/How-to-wire-3-phase-electric.html
http://www.electriciantalk.com/f5/
Apr 16, 2013 | Electrical Supplies
How do i install a 14-3 wire with ground to the breaker
Following wiring diagram is for general purpose household 120V-240Volt service.
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-10-1000.jpg
http://waterheatertimer.org/Color-codewire.html
Why are you asking that question without saying what you are wiring? 120Volt, 277V, 480V etc?
What does rating plate say on device you are connected to 14-3 wire?
And what amp/volt/watt rating are you connecting to 14 gauge wire?
No electrician would omit that information.
14-3 wire is usually only for 3-way switches and other light duty applications.
Must be connected to 15 amp breaker and no larger.
Apr 08, 2013 | GE 15 Amp 1 inch Single Pole Circuit...
How to hook up 14-3 wire to the panel
Apr 08, 2013 | Electrical Supplies
277v-box
Is this a single pole switch? Or a timer switch that is rated for 277V? Or a dimmer switch?
Please include brand and model number and what you are controlling when adding comment to this thread.
277Volt has one hot wire and one neutral wire, exactly like 120volt.
Just like ordinary on-off switch for 120v, the 277 Volt hot wire is switched on-off, while the neutral remains continuous throughout the circuit.
http://waterheatertimer.org/How-to-wire-switches.html
Sep 17, 2012 | Lutron Ceana Single Pole 277V Switch,...
Intermatic T103P Timer (120V) Wiring Guidance
Copy following link for T103 timer wiring options:
The clock motor is 120Volts, but clock motor can be changed from WH1570 to WG1573, and this action changes 120V T103 into 208-277V T104 timer:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
Jun 08, 2012 | Intermatic Hardware & Accessories
Need wiring diagram for T104M 208-277v Mech. Time Time Switch
Kelly
Jun 27, 2011 | Intermatic T104 24h 208-277v Mechanical...
Installing a outdoor timer t104m this is for the pool cleaner,need wireing instruction.next to pool pump timer.
Open following link for wiring diagrams and manual.
240Volt T104 can be wired many different ways.
What is the significance of 'next to the pool pump timer?'
Are you getting power off the 240V pool pump timer to operate the new T104? This is perfectly fine. The pool pump wires would bring power from the breaker box.
Is the new T104 going to control 120Volt lights? The timer can do that, it just has to be wired correctly.
In any case, the T104 has 240Volt (or 277V) clock motor, and clock will not operate with 120V
If you add specific details, I can help with exact wiring diagram for your project.
Apr 18, 2011 | Intermatic Hardware & Accessories
The t104 comes new in box with timer jumpers to points 1 and 3 if i am wiring this to 277 i need to remove the jumper to post 3 and add a nuetral to the timer? correct?
277V instructions say:
Move small white motor wires to terminals A and 1
Connect 277 Neutral wire to terminal A
Connect 277 Hot to terminal 1
See illustration:
http://waterheatertimer.org/images/T-104-control-120V-Load-277-400.jpg
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 04, 2011 | Intermatic T104 24h 208-277v Mechanical...
I have an LED exit sign that is not working. What steps do I need to do to troubleshoot?
If you've just installed it and it doesn't work, make sure that the ballast is rated for the power you're giving it. If you put 277v to the 120v taps, you've cooked it and the unit will have to be replaced. If you put 120v to the 277v taps, it will probably still work if you take it apart and wire it the correct way.
Otherwise, check all connections within the unit (even the ones you didn't make).
Jun 28, 2010 | Sign Led Emergency Exit - Red
How to wire this ge timer 120v
Open following links for GE timers and 15087 wiring:
http://waterheatertimer.org/GE-timers-and-manuals.html
http://waterheatertimer.org/How-to-wire-GE-15207-timer.html
GE box timers can be wired many different ways to control single-loads, multiple loads, 2-speed motors, 120V, 208V, 277V, 240V, 440V, 24V.
Add a comment and say exactly what you are wiring, and what voltage you are using for more information.
Dec 07, 2009 | General Electric GE 56941 24-Hour Outdoor...
Home Logo
74 people viewed this question
Top Lithonia Lighting Home Experts
Angel Joseph Jr.
Angel Joseph Jr.
ray gallant
Are you a Lithonia Lighting Home Expert? Answer questions, earn points and help others
