Your touch pad should do the trick.
They are called "Gestures". They are set to active by default. If it's not. Go to "Control panel > click "mouse" and find "touch pad". There you will find "Gestures". Activate it.
1. Put two fingers on the touch pad and try to move both fingers up or down. Learn how to scroll up and down.
2. Move those fingers side ways. This should do the "Horizontal" scroll.
There are others, like:
Put one finger stationary and rotate the other. This rotates the orientation of the object.
Try it and good luck.
Sometimes there is a setting, under mouse, in the control panel. But also there is a time based issue, you need to stop while pressing in the scroll area, and the mouse shifts from mousing to scrolling. Duration of time, and first touch to the pad in the scroll area are keys.
It depends, do you know if there is an icon down in the taskbar near the clock that has options for your mouse, if there is then you would double click that and there should be options in there.
If you have the drivers for the touchpad installed then you should be able to run your finger up or down the right hand side of the touch pad and have it scroll the page you are one.
If it doesn't work then you may need to either reinstall the drivers or find the program that handles the touch pad settings (usually found in program files) and turn the scrolling feature back on.
Try uninstalling the drivers from the device manager, then do a hardware search. It will automatically find the touch pad and reinstall the drivers. If this doesn't work, then check the connector under the keyboard. Disconnect it and reconnect it, they sometimes work loose. If these don't correct the problem, then you have a faulty touch pad and you'll have to replace it.
Next time you try scrolling on the touch pad, also push down (really) hard on the touch pad(kind of like you're squeezing the player). Keep doing this, and you may get it working. I've dropped mine a few times, and this push/squeeze/scroll seemed to work.
