Question about Sharp El-501w-bk Scientific Calculator
What is the exponent key on the sharp el-501w
informatica
  • 1114 Answers
SOURCE: exponential form
Hi - You can download the manual from the link underlined in blue below:
EL-531 W
You need to set it to "SCI" i.e. scientific mode to show the exponents:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Posted on Aug 06, 2008
SOURCE: how do i display exponents besides 2, or 3 on the
EL-531W SHARP:
If you want to find 5 to the power of 6 (5^6)
you hit the 5 button, then the button that says yx ( the x is in the exponent spot) then the 6 so it will looks like this 5^6 then press enter to get the answer...hope that helps!
Posted on Sep 10, 2009
  • 8068 Answers
SOURCE: I have a SHARP EL-501W calculator and i am getting
The source of errors is most certainly due to the wrong schoice of angle unit (degree or radian). If the default angle unit set in your calculator is the degree, any value fed to the trigonometric functions (sin, cos, tan) is considered to be expressed in degrees. Consequently, if you calculate the arctangent ( tan^-1) of a value, the angle returend by that inverse trigonometric function is expressed implicitly in degrees.
Similarly if radian is the default angle unit in your calculator, any angle returned by an inverse trigonometric function (arcos, arcsin, arctan) is in radian.
Set the default angle unit as the one required by your problem at hand. This way, the angles returned will be in the right unit and you will not have a problem of interpretation.
Hope it helps.
Posted on Dec 07, 2009
  • 8068 Answers
SOURCE: PDF Manual Available for EL-501WBBL Calculator?
Here, I think I got you a link.
Posted on Jan 30, 2010
  • 8068 Answers
SOURCE: I have a sharp EL-501W and I want to know how I
Here is a picture to show you how to configure it.
How do i enter an exponent on the
It depends on the base of the power function.
For exponential function use [SHIFT][LN] (e^x) followed by the exponent value. If exponent is negative use the change sign +/- key before exponent.
For a general power, type in the base (number), then press the [Y^x] key followed by the exponent.
For a power of 10, use the [Exp] key. Careful here. For example to enter 1.6x10^(-19), type in 1.6, press the [Exp] key, then the change sign key +/- and the exponent. Press [=]
1 . 6 [Exp] +/- 19 [=]
Sep 28, 2014 | Sharp EL-531WBBK 12-Digit 272-Functions...
How do i do exponent 4
The key you are looking for looks like y raised to the exponent x. It is below the "hyp" key. To determine an exponent, enter you base, hit the y to the x key and enter the exponent.
For example, 3 to the power of 4, enter 3, hit the y to the x key, and enter 4 and hit the = key.
Good luck.
Paul
May 26, 2014 | Sharp el-531x scientific calculator
Is it possible to do exponents other than 10 on a SHARP El-W535X Scientific Calculator?
Use the y^x key (two keys up from the 7 key). For example, to calculate 8^9, press 8 y^x 9 =
Feb 04, 2014 | Sharp Office Equipment & Supplies
Exponents
What about the "Exp" key just above the "7" key? This key will let you enter an exponent of 10 when entering a number.
Nov 24, 2013 | Sharp el-531x scientific calculator
How do i do exponents
The "Exp" key just above the "7" key will let you enter an exponent of 10.
Where is the exponent key on the 531x
If you mean the key to raise a number to an exponent, it's the key marked "y^x", two keys above the "7" key. If you mean the key to enter an exponent of ten, it's the key marked "Exp", just above the "7" key.
Feb 18, 2013 | Sharp el-531x scientific calculator
Where is the combination button on SHARP EL-501W calculator?
There is no such key on this calculator. You can calculate it using factorials. To calculate nCr you can calculate n! / (r! * (n-r)!).
Apr 30, 2012 | Sharp EL-501WBBL Calculator
Hi, I just bought a calculator model# EL-501W ( by SHARP) and i can't figure out how to plug in #'s in scientific notation? Can you please give me instructions on how to do that??
Without knowing the specific type of scientific notation you are trying to enter, there is no way to give you accurate information. Here is where you can download the manual from...
http://www.usersmanualguide.com/sharp/calculator/el-501w
if you provide additional information, perhaps I can provide a more detailed answer.
Good luck.
Jan 15, 2011 | Office Equipment & Supplies
How do you raise to a power on a Sharp el-738 business calculato?
I don't know about this specific calculator, but there is probably a button on your calculator that has a "y" with an "x" as a superscript (exponent). Or is could be reversed. But you wanted 2^8, you would push the 2 first, then the exponent button, then the 8, and there's your answer.
Good luck.
Jul 14, 2010 | Sharp EL-738 Scientific Calculator
Sharp El-501w-bk Scientific Calculator Logo
274 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
