Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
No picture or sound
Black screen appears with video 1 in left corner afer power on and 4-5 lcd blinks no sound
  • Anonymous Dec 01, 2007
    stand by blinks 6 times no picture or sound
  • Anonymous Dec 25, 2008
    i have the same problem
  • 398 Answers
If the screen displays VIDEO 1 then the set is in video 1 mode, looking for a signal on the video 1 input jacks. Press the TV/VIDEO button on the remote (or the set itself if it has it) and cycle around to the input you are actually using.
Posted on Aug 29, 2007
SOURCE:
Get 8 blinks when tv is turned on with no picture or sound
Check out your power supply since set is sort of dead with no audio or video.
Mar 27, 2016 | Hisense TL1700 17 in. LCD Television
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Vizio e420vse
If your TV is under warranty you have to contact the store where you brought it..
Jan 17, 2013 | Vizio E420VSE 42" 1080p 60Hz LED LCD 2.4"...
Black screen blinking line in upper left corner
you just need to re-install the Operating System from recovery cd
Dec 19, 2012 | Dell Dimension 8250 PC Desktop
When I will plug in the pludg into power, LTV-42ASB whitout press a power knob, start blinks blue light in corner 3 times and then I see on screen logo ,,ASTAR.. After 3-4 sec TV want to show next ...
U can still hear the tv audio,after the picture logo is gone and went to a black screen panel a few sec later?Yes,than the tv have these 1 or 2 long boards call the LCD inverter baords are dead.These 1 or 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a pcture.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 long refurbishes LCD inverter boards for the replacement.
Dec 04, 2010 | Televison & Video
Black circles on left edge of lcd tv screen
Bad LCD panel. https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=7857212
May 01, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Screen Wiggles, CPU Shuts Self Off, Powers Up Very Slowly
Hmm... Any errors on the screen?
Could be a power supply. Fluctuations in that can cause power drops, which would be visible in the video card, and if severe enough, cause the PC to shut off. There are 4 screws and one 1 wire holding those in. It would take about 10 minutes to replace and probably cost you $40-$50 in parts.
To have Geeks do it: Probably $100.
Dec 06, 2008 | Dell OptiPlex GX280 PC Desktop
Blinking screen
ON THE 36 INCH SONY THE PROBLEM LIES ON THE PICTURE TUBE.THERE IS A LEAKAGE EITHER HEATER TO CATHODE OR G1 INSIDE THE CRT.THE ONLY WAY TO FIX IT IS REPLACE THE CRT OR HAVE THE CRT GUNS CLEANED THRU PICTURE TUBE TESTER/RESTORER/REJUVINATOR AVAILABLE ONLY FROM TV TECHNICIANS.GOOD LUCK.4TUNE.
Jan 09, 2008 | Sony KV-35S42 35" TV
Panasonic Projection HDTV Made 9/2003
Your lamp has most likely blown out. that is what happened to mine and once I replaced the bulb it worked just fine. this is one of the cheaper stores to find a replacement bulb, www.bluestar-online.com
Aug 29, 2007 | Panasonic PT-40LC12 40 in. LCD Television
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
116 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
