Question about Refrigerators
Leisure hja6100 Fridge freezer display unit off not dispensing water or ice and not getting any signs of coldness but light is on
4 Suggested Answers
SOURCE: Water & Ice do not dispense. Maytag ICE2o
Possibly the water valve (also known as a solenoid valve) on the back of of your refeer has gone ka-put. It is easy to find and spot. The water line from your source (out of the wall) goes to this valve. If it is not operating, you will get no water supply thru that line into your dispenser or your ice-maker unit. No water in means no water and no ice out. This is a pretty simple fix you can do yourself. The part is reasonably priced. Get the model number of your refrigerator off the door and contact your local distributor for your brand. Make sure you turn your water off at the wall, or house, before you start taking that plumbing line apart. Otherwise, get yourself a surfboard and lay in a good supply of paper towels. Take your time and unplug your unit from the wall to be on the safe side...
Posted on Mar 06, 2008
  • 111 Answers
SOURCE: My GE side by side fridge/freezer is working,
fill the ice maker with water manually, if you have ice in the bucket you know that the ice maker is working , after check the water valve if is opening , if it is replace main board
Posted on Jun 17, 2009
  • 30 Answers
SOURCE: I have an leisure HJA6100
how full is it? if the vents are blocked this will cause the freezer to not cool enough. what is the temp ? second the defrost timer or the element may not be working this will cause the evapator coils to get clogged with ice therefore hampering airflow. third the cold control it is a thermostat sensor that tells the compressor to start the cooling. how's the fridge ? The fridge should be aboult 40 degrees +or- 5 degrees and freezer around zero if working correctly. the defrost timer is located somewhere around the cold control. there should (if a mechanical timer) be a small hole about the size of the tip of your pinky just inside that hole is a small plastic nub. you should be able to turn it if you find it try a small phillips head screwdriver to turn try both ways. if you hear a sound like winding a clock and then what sounds like a clock running at anypoint you have found it. what this does is it shuts down the cooling and activates a small electric heat strip in the freezer to melt the ice that collects on the coil remember grandma's old freezer and all the ice? this system takes care of that for you but does break. if the timer starts the defrost cycle you might have to run it thru a couple of cycles to melt the ice. if it's any prob but too full of food you will want a trained tech to repair. but you can find out what the problem most likley is and not get taken to the cleaners when paying for repair
Posted on Aug 07, 2011
My Leisure HJA6100 with ice maker and chilled water dispenser now tripe the main circuit breaker for that part of the house when switched on. The plug 13amp fuse does not blow but the consumer unit tripps/...
A breaker trips when the current draw exceeds specifications. This is usually a short or where a component has failed and drawing excess current. It is also a good thing as it prevents a fire! The likely culprit on a fridge is the compressor and that is not usually a DIY job. You can poke around looking for evidence of arcing or overheating but likely a service call.
Jan 08, 2015 | Refrigerators
My maytag msd2657heb i could hear it running but the fridge and freezer not cold at all
It can be faulty compressor or issue with defrost.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
I have an leisure HJA6100 Fridge Freezer. the freezer doesnt seem to be getting cold enough even set to max. the display shows an exclemation mark in a square. also the temp bar is not shown
Aug 07, 2011 | Refrigerators
Have a gs201eta ww refrigerator ice maker problem Unit makes ice, light works and water dispenses from the door. However ice cubes and crushed iced does not dispense from the door. The dispenser motor...
The fridge gets its cold air from the freezer through a vent between the freezer and fridge. the fan in the freezer blows air through it. there is a flap you adjust with the fridge temp. control.
Make sure it's opening and closing when you adjust the fridge temp. try to chec in the user guide.
Hope helps.
Jul 07, 2010 | Refrigerators
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser won't work --ice dispenser is fine but no water comes of the water dispenser.
fridge set too cold ? frozen tank or water lines in fridge. set ref warmer for a couple of days
Aug 26, 2009 | Amana AFB2534DE Bottom Freezer French Door...
Ice maker & water dispenser won't work
I recently found out that the water supply lines are coiled up inside behind the frige on the refrigerator side moving the unit will cause those coiled up lines to shift to the freezer side of the unit, causing a freeze up,take the cardboard lower back off and move those lines further away from the freezer side of the unit, as one of those coiled up lines are to chill the water for the dispenser and the other is supply for the icemaker, this should fix your problem, becareful not to move them too far away from the freezer side as they are meant to chill the water for the dispenser
Jan 16, 2009 | Frigidaire FRS266ZDSB Side by Side...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
