How to remove a Duravit sink cabinet drawer
How do I remove the drawer from a wall mounted Duravit cabinet so I can get to the plumbing? The front of the drawer pulls up but I can't see how to pull it over/off the tracks.
SOURCE: NEED TO REMOVE WALL MOUNTED GE JVM1190BY002 MICROWAVE
I also have a JVM1190 and was baffled as to removal. My very handy brother solved it in two minutes. Above the door and keypad there is a long grill secured by two small squarehead (Robertson) screws. Remove the screws and grill and you will see on either side of the opening a long bolt. They go through to the back of the microwave where the support plate attached to the wall. The bolts have a slot in the middle for a flat blade screwdriver. Simply turn the bolt to release from the back plate. Make sure there is a helper underneath as the microwave is fairly heavy. Do the reverse for re-installation.
Posted on Feb 08, 2009
SOURCE: HE4T How to remove the front panel
if you want to take the top panel off,there are 3 screws at the back of the machine,remove then lift
Posted on Feb 25, 2009
  • 659 Answers
SOURCE: Remove the base of a pedestal sink.
There are two bolts on either side of the sink. Remove them and lift the sink off of the base. Sometimes, depending on who installed it, you can slide the base out without removing the sink. Hope this helps.
Posted on Mar 16, 2009
  • 297 Answers
SOURCE: kohler shower diverter leaks (behind the wall)
if you have a closet behind the shower or a wall you may be able to get to the diverter without damage to the tile ,are you sure you can't just change the cartridge? most times this is all that is needed to fix a problem like yours.
Posted on Jul 24, 2009
  • 5 Answers
SOURCE: How do I remove Frigidaire FMV156DCC under cabinet microwave?
Underneath the microwave, on the right & left hand corner sides at the back, there are levers that you pull down & it releases the mounting bracket.
Posted on Sep 12, 2009
Foul Odor & Occasional Leak
Looks like you were suffering thru the same thing we have in our house - did you ever get a solution to this? I was wondering if some of your vent pipes were cracked or partially clogged, especially where you had that plumbing access hole in the wall. Hope you've got this fixed already, since plumbing companies usually charge about $350 to run those smoke tests to find and pinpoint problems, and it doesn't always work. Buzzie
Feb 07, 2014 | Plumbing
Tip
Sink Cabinet Replacement Bottom
IF your sink cabinet bottom is water damaged and in need of a replacement, this video gives step-by-step how to information for fixing it. This video was created by a cabinet professional who specializes in fixing Formica kitchen cabinets.
It is very informative for the person who likes to do it yourself" when it comes to repairing things around the home.
Tools and materials needed:
Saber saw
Diagonal cutters
Hammer
New sink cabinet bottom
Caulking
Caulk gun
Clorox Bleach
Three Support Struts
L-brackets
Finish nails
How to do the Repair:
Take the doors of the kitchen or bathroom cabinet off.
Remove the water damaged sink bottom by cutting it in half from front to back. You may need to use the hammer at this point. Just be extremely careful to not damage the plumbing.
Break off the staples with the diagonal cutters.
Clean the mold with the Clorox Bleach.
Install the struts designed to support the new sink cabinet bottom. Use L-brackets if necessary for attaching the center piece.
Install the new sink cabinet bottom replacement board. Attach it with finish nails.
Clean the inside of the kitchen or bathroom vanity cabinet.
Caulk all interior areas of the sink cabinet bottom.
Replace the doors.
Every sink cabinet is built differently. Make sure to examine how the cupboard was built to determine the best method for replacing the bottom of the cabinet. If you have a center style, you will need to cut it out and reinstall it using L-brackets.
on May 26, 2010 | Home
My duravit toilet was hung too low and I'm trying to find a solution that doesn't require opening the wall
If you raise the toilet you will have to raise the plumbing so you have little choice.
Nov 05, 2013 | Duravit Home
I am replacing my sink, medicine cabinet and adding a small cabinet below the sink. I need to know how to remove the old and install the new.
The task you are embarking on is a great DYI project. But, be forewarned, it can get tricky. First, make sure the new sink will fit in the space of the old sink. If not do you have enough space for the new sink to fit securely against the wall? Next, remove the cabinet. There should be about four screws. You may also have to use a razor to cut calking from around the outside of the cabinet. Sometimes it's used to fill-in gaps between the tile and cabinet. Remove the cabinet. If the cabinet is setting in the wall, make sure you check and see where the support beams are located. If you are not putting in another wall cabinet, then you will have to know what kind of wall you have. Sheet rock, no problem. Plaster requires a bit more work. Measure the hole, and then you will need chicken wire, lime, plaster, paint, and matching tile. Fasten the wire to beams in the wall. The wire will hold the plaster in place. Let dry, sand smooth then paint. If you have sheet rock walls measure the hole cut the sheet rock to fit. Fasten it to the beams, use plaster or Spackle to cover the holes from the screws. You will need sheet rock tape to hide the space between the existing wall and the sheet rock patch. Smooth on cover the tape with Spackle, smooth by sanding.
To remove the sink: first, turn off the main water supply. Get a pipe wrench and remove any connections. If you're not familiar with plumbing you may want to get a plumber to attach the connections.
Putting a cabinet under the sink is the easy part. Make sure you have the right size cabinet. Get a leveler; make sure the sink and cabinet are level. Depending on your walls, you can just screw the cabinet to the wall. If they are plaster walls you will need wall anchors. That should do it. Enjoy
Feb 23, 2013 | Plumbing
My geberit in-wall toilet won't stop running, and there is no way to access any type of plumbing fixtures to fix. Please help me!
Shut off main water supply
shut off water value going to your wall mounted toilet.
look under your apartment or the room ajoining the wall unit.
look for hidden wall space above unit
Nov 29, 2010 | Duravit 111335001 Geberit In Wall Carrier...
We cannot get the mounting clips to stay on
I have spent several hours trying to solve the same problem with a Franke Granite double basin sink. The clips for this Franke sink appear to be a piece of engineering garbage, and the instructions are utterly useless - A huge piece of paper with a template, and tiny pictures that look like they were drawn by a kindergartner with a crayon. The instructions for using the clips --oh there are none - other than a blurry picture in which the clips could fit inside this period (.). Lots of other people appear to have the same issue. I like the Franke sink, but without proper mounting hardware, this franke sink is no better than the poorly made clips, and the Franke Sink horrible instructions that it came with.
May 02, 2010 | Franke Work Top Double Bowl Kitchen Sink...
How do I remove the toilet seat for duravit
You need an open end wrench or socket I believe 9/16 is the size
Nov 14, 2009 | Duravit Darling Wall Mounted Toilet White
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
Mounting OTR microwave oven under a penisula cabinet
We put false doors on the back of the peninsula, mounted the wall mounts on the inside of these doors and then connected it to the top.
Mar 24, 2017 | GE Profile Spacemaker Over-the-Range...
Washing Machines Logo
161 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
