I have a air conditioner model 580.75051500 Kenmore I would like to know what kind of freon it takes
SOURCE: Danby air conditioner model #DPAC10060(R)
here is the manual link: http://www.danby.ca/manuals/DPAC8020.pdf
Posted on Jun 15, 2007
  • 31 Answers
SOURCE: punctured an air-conditioner Freon line
when the freon is released from the unit,you have to repair the leak,pull a vacumm to rid any moisture in system then refill with freon,if you dont have the equipment,it would be cheaper to just replace the unit
Posted on Nov 17, 2008
  • 56 Answers
SOURCE: air conditioner needs freon
If the system runs you will first need to add freon to the system (make sure it the right freon) Just enough to find leak. After you find leak and repair evacuate the entire system and weigh in charge. Hope this helps.
Posted on Feb 12, 2009
SOURCE: fan not blowing
you need a 6.3v capacitor to get the fan going i had the same problem.
Posted on May 08, 2009
  • 72 Answers
SOURCE: goldstar air conditioner model gwhd5000 doesn't really col unlca
you may use a bullet piercing valve to do so
Posted on Jun 07, 2009
What kind of freon was used in this unit when made
You didn't give a model or brand so here is what to check. Find the model--serial tag on the air conditioner and it should tell you type of freon and usually the amount. Most older air conditioners were freon R22.
May 20, 2015 | Heating & Cooling
I have a sears kenmore air Conditioner about 10 years old. Not sure the model number. It stopped blowing cold air a few days ago and in cleaning the filter the hold down elastic string got caught under...
What came loose was the heat sensor bulb, it is snapped into a retainer clip and connected to the unit be a very small copper tube.
This is not the cause. Most likely cause is low freon, bad compressor or the capacitor
Jul 27, 2014 | Kenmore Sears Air Conditioner 74054 Clean...
What type of freon 5695
Hello Friend, this is Z. Thank you for your post!
I understand that your inquiry is listed under Frigidaire Air Conditioner and that you would like to know what type of Freon 5695 is. You may typically locate information regarding the Freon on the serial tag (which lists your model number) of your air conditioner. You can normally find the serial tag behind the front grill by the air outlet or on the inside of the cabinet. Hope this helps!
Jul 14, 2014 | Frigidaire Heating & Cooling
What kind of freon does my unit take? Model number CPLE24-1
Refrigerant 22. Here is the site for the units specifications on the CPLE24-1. http://www.alpinehomeair.com/viewproduct.cfm?productID=453054740 Please grade the help I have given. Good or bad, it all helps. Thank you. Roger
Apr 04, 2011 | Goodman CPLE24-1 Air Conditioner
When i turn on my air conditioner in my 1999 durango it blows out hot air. can i put in antifreeze myself or do i need to take to the dealership?
Antifreeze is only for the radiator, does not affect the air conditioner, make sure you have the setting on cold, if it is still hot than take it to your local air conditioner re gas station, most auto electricians do it, dealerships usually send them out which you end up paying extra for!!! You just need a re gas in your air conditioner.
Feb 14, 2011 | 1999 Dodge Durango
What kind of freon does my dometric air conditioner take its a 2005
It should take 134a. Look on the data plate and it should tell you.If not you can always contact the manufacture to be sure.
Sep 03, 2010 | Dometic Rooftop RV Air Conditioner
Air conditioners are two years old and not cooling like they shou
may just need cleaning, but should be able to buy a kit with instructions if needed (Walmart) but you need to know the kind of freon it takes
Aug 14, 2009 | General Electric ASD06LK Thru-Wall/Window...
Everything is working .No cold air coming from vents
if the compressor is on the condenser fan ison the evaporator fan is on and no cool means lack of freon and also you can start and check with gauges
May 01, 2009 | Kenmore 72187 Air Conditioner
Temperature display and "Cool" light flicker and click
It has an electrical problem, first. You (and I) won't know about needing freon until the compressor is running.
Jul 23, 2008 | Kenmore 72055 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
