Question about Music
Manual for digitech audio doorphone 2 to 2
I bought digitech security audio doorphone 2 to 2 but no installation instructions can someone help please
2 Suggested Answers
  • 1212 Answers
SOURCE: bought a digitech rp355 went to set it up but i have no sound
If the unit is in bypass mode, the display will indicate "BYPASS" That would bypass the RP355. You might try that to see if the problem is with the 355.
You might also have issue with the output being essentially low Z out if it is plugged into a High Z input.
Are you using the unbalanced 1/4 inch guitar jacks or the XLR? Is the XLR wired correctly? If not it may be grounding out the input.
If your eurozone power pack is the correct polarity on the coaxial power plug, the unit should light up. If it is not even doing that- check the polarity as it may be reversed from what you need. As long as the the output voltage and current is close to what the American power supply output current is- molded into the power pack, there should be no issue there if polarity of coaxial plug is correct. It should behave and respond to the various setting displyed on the RP unit.
Is it plugged into a computer? Did the computer recognize the driver? Is there a software conflict? If you have a windows machine, you can open the device manager and see if there is a yellow X or yellow question mark on the device- if so the driver either did not install, or there is a software conflict. you may need to to enable the audio for that input in "Audio Properties" in the control panel of the PC. If a mac- make sure it is selected under "Chooser".
In short- you should be able to plug your guitar into the unbalanced input of the RP, and then you can run a cable from the RP unbalanced output to the guitar amp. There are 5 different lengths of 1/4 inch jack in use- make sure yours are the right length for the amp, and the RP.
in bypass mode, the guitar should be heard, you can put the unit in bypass mode by pressing the up and down keys at the same time. Also make sure the amp is not in standby or muted either. These things can happen. It should work, it shoudl light up, it should give you visual indication something is or should be happening.
Posted on Apr 02, 2012
HOW DO I SET UP MY Digitech 1500, TO CHECK MY aa & aaa BATTERIES ?
http://www.instructables.com/id/Testing-batteries-with-multimeter/
Jan 27, 2018 | DIGITECH Music
How can I get instruction manual for digitech xc0430 weather guage ?
Hello!
Please kindly check - here is the list of Digitech devices. Hope you can get here the one you need or a similar one.
https://manualsbrain.com/en/brands/digitech/popular_categories
Oct 20, 2017 | DIGITECH Music
User manual for digitech audio AA-2014
not sure if this link will help you to find the manual you are looking for.
http://manualswarehouse.com/manuals.htm
Dec 23, 2016 | DIGITECH Music
How to install the digitech security audio door phone 2 to 2
HOW TO INSTALL DIGITECH SECURITY AUDIO DOORPHONE 2 TO 2
Dec 24, 2013 | Music
Bought a digitech rp355 went to set it up but i have no sound
Apr 01, 2012 | DIGITECH Music
Instruction manual for Digitech QM 1324
Hello
Try these links.
www.homeimprovementpages.com.au/.../jaycar_electronics_-_silicon...
http://www.dataentryjobs.us/67948.html
www.stereo.net.au/forums/.../38828-help-with-measuring-inductorsCached
ftp://ftp.digitech.com/pub/PDFs/Manuals/Vocalist_LIVE2/VL2Manual_v1.pdf
Copy and paste these links to the address bar to your borwser and press 'Enter', if you can't diretly go to ths links.
Feb 27, 2012 | Music
My digitech rp 500 has power supply but it won't
Make sure you have the OFFICIAL Digitech power adapter. Universal adapters or those for MOST other pedals will NOT work... things may light up but you will NOT get audio. This unit requires an adapter supplying 9 VAC (not DC) at about 1 amp. These AC output adapters are not very common and people get the units without an adapter and try using universal adapters and they do not work. An AC adapter is used by Digitech so they can generate both plus and minus voltages internally. I don't know what your utility power voltage is in Cebu, so you need to get an adapter for your voltage that will give 9 VAC output and fit the power jack on the unit.
Sep 15, 2011 | Digidesign Digitech Control 2 pedal for...
Vocalist live 2 problem. power to unit OK , lights up. Guitar output OK. No tuner, no vocal output.
NO power light or audio from Digitech Vocalist 2 live. Check that your power adapter is for 9 Volts AC (not DC like most pedals) and is rated at 1300ma or more. A DC adapter MAY light up the unit but not make it pass audio. Lights can be lit but that is NOT an indication thaat correct power is applied. They likely use the AC input to generate both positive and negative voltage within the unit. The use of a DC adapter will prevent generating one of these required voltages and prevent audio from passing.
Jan 13, 2011 | DIGITECH VOCALIST LIVE 2
Digitech rp6
Try contacting their service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply PS0912 which should still be available. Hope this helps.
May 25, 2009 | DIGITECH VOCALIST LIVE 2
Music Logo
129 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
