Question about Crate Cfs3
I NEED A WIRING DIGRAM
NEED WIRING DIAGRAM AND PARTS NEEDED TO BUILD DIGITECH FSX3 FOOTSWITCH FOR THE JAMMAN LOOPER PEDAL
2 Suggested Answers
  • 4 Answers
SOURCE: Three button crate footswitch wires
My mate's crate uses two stereo jack leads similar to 6.35mm guitar leads but stereo. You can buy them anywhere.
Posted on Jul 06, 2012
Is a Harmon ps0913b 240-au-b power adapter, suitable for a Digitech Live Harmony pedal
Consult the manual for the rating of each power adapter to compare. The units will also have the specs needed printed next to the power input jack, but the manuals will be more detailed.
Sep 24, 2015 | Music
Wiring diagram for peavey delta blues footswitch
Contact Peavey toll free at 877-732-8391 or by email at customerservice@peavey.com,
Oct 25, 2012 | Peavey Delta Blues Footswitch
NEED WIRING DIAGRAM FOR RENOWN FOOTSWITCH
Aug 10, 2012 | Peavey Music
I have the fender accessories footswitch and the cyber twin. The pedal has stopped working and I have replaced the cable but still does not work. Is it the pedal or the amp? The amp buttons still work...
Verify the footswitch with an ohmmeter. You should find that each of four pins should have continuity to pin 2 of the connector when the switch associated with the pin is pressed.
Note the pin numbers on the connector seem to have a weird layout. Here is a link to your amp schematic. The Footswitch interface is shown on page 3 of 12.
http://elektrotanya.com/fender_cyber-twin_sch.pdf/download.html
Use the ohmmeter to check each wire in the cable is good. SOme cables, unless the official one for the unit, may lack some wires.
The amp "reads" the footswitch state into a register which is then read serially. The inouts are pretty well protected from user mistakes. With the schematic you should be able to analyze the failure.
Feb 27, 2011 | Fender Accessories Footswitch for Cyber...
My digitech looper phrase sampler will not turn on
A common problem is that somebody has paired the WRONG power adapter to this unit.
The REQUIRED adapter should be 9VAC (not DC) at 1300ma or 1.3 amps.
Note that UNIVERSAL replacement adapters will NOT work with the Vocalist.
Feb 06, 2011 | Digi-Tech Digitech Vocalist Live 4...
When i press the harmony effect i have to hold it
Well i hope the latching mechanism isn't busted!
Check/review your parameter settings for your programs. Especially in the Expression Pedal Control areas.
From their site:
--Harmony Footswitch
This footswitch turns the harmonies on or off. While multiple harmonies can be selected within a preset, the HARMONY footswitch activates or deactivates any selected harmonies simultaneously.
When the LED above the HARMONY footswitch is illuminated, the harmonies are on. When the LED is turned off, the harmonies are turned off.
--Note: The settings for FX Footswitch Control, Harmony Footswitch Control and Guitar Sensitivity apply to ALL presets. The setting for the Expression Pedal Control applies to the current preset only. If you modify the Expression Pedal setting and wish to store it you must Store the preset (see page 11 ). When you load another preset, its setting for Expression Pedal Control will take effect.
--To perform a Factory Reset procedure
If you are editing a preset, press the Up or Down footswitch to exit edit mode.
Press and hold the Major/Minor button and then press and release the Store button. The display will read FAC RESET- WILL ERASE ALL YOUR PRESETS... , then STORE=RST.
Press the Store button again to continue with the factory reset. If you don’t want to do the factory reset, just wait 5 seconds, or press almost any other button, to cancel.
Mar 27, 2010 | Digi-Tech Digitech Vocalist Live 4...
I need the operation manual for a Danville tec80G guitar amplifier. I also need to find out where I can get a footswitch for this amp. I would like to be able to incorporate some sort of distortion...
Well,its a real obscure amp.No company website from what I can find.
Here is a review of the amp though on a good tab forum:
http://www.ultimate-guitar.com/reviews/guitar_amplifiers/danville/tec80g/index.html
As for the footswitch dist.pedal,you have a few options.Look on the back of the amp and see if there is A)an effects loop.This may say "return" and "send" and you can hookup a pedal through that to bypass the input jack.Then just plug in normally to the front of the amp.Also check to see if there is a 1/4 input on the back that may say "footswitch".If so,fender makes a button footswitch that comes with most of their middle of the road combo's.This plugs in just like a guitar cable and will switch your channels.
If you need a recomendation on a distortion pedal go with MXR.Its a little morre expensive(by $10.00 maybe),but its the best bang your gonna get out of a pedal.
Sep 21, 2009 | Music
Pedal Malfunction RP250
You will have to recalibrate your pedal. If you don't have your manual anymore try going to www.digitech.com. The procedure for the RP350 so that you don't lose your presets is : 1. Press and hold the UP/DOWN Footswitches until PDLCAL appears in the display (BYPASS,TUNER and EXIT will be displayed before PDLCAL is accessed after about 5 seconds). 2. When the display prompts you with TOEDN, rock the EXPESSION PEDAL forward (toe down) and press either FOOTSWITCH.
3. When the Display prompts you with TOE UP, rock the EXPRESSION PEDAL back (toe up ) and press either FOOTSWITCH.
4. The Display now prompts you to calibrate the V-Switch sensitivity (VSWxxx), where xxx is the current V-switch threshold. Rock the EXPRESSION PEDAL forward and press firmly on the toe once to turn the V-switch on (WAH ON) and again to turn the V-switch off (WAH OFF).
5. If the V-switch is too sensitive, press the right UP FOOTSWITCH to raise the threshold (range is 0-2000. Keep testing the V-switch sensitivity and adjust the threshold until it only engages when you want it to ( too sensitive a setting will lead to the V-switch falsely triggering on or off when using the Expression Pedal).
6.When the V-switch sensitivity is set to your satisfaction, press both UP/DOWN FOOTSWITCHES simultaneously to exit. NOTE: IF the DISPLAY shows ERROR, an error has occurred and steps 2 through 5 should be repeated. Sorry fo the caps but thats how the instructions appear in my sons manual. You can also dowload the manual and an editor librarian (for the 350 at least) at their site. They might even have an update for your pedal. Hope this helps. Keep playing.
Jul 09, 2009 | Music
Digitech rp6
Try contacting their service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply PS0912 which should still be available. Hope this helps.
May 25, 2009 | DIGITECH VOCALIST LIVE 2
Metal Pedal mutes my guitar.
Sell the pedal and get a digitech, or convert it into a looper pedal.
Apr 05, 2009 | Boss Mt 2 Metal Zone Effects Pedal
Crate Cfs3 Logo
35 people viewed this question
Top Crate Music Experts
rjivaro
Michial Gueffroy
Ben Armstrong
Are you a Crate Music Expert? Answer questions, earn points and help others
