Question about Music
Wiring diagram for digitech fs3x footswitch - Music
4 Suggested Answers
  • 4 Answers
SOURCE: Three button crate footswitch wires
My mate's crate uses two stereo jack leads similar to 6.35mm guitar leads but stereo. You can buy them anywhere.
Posted on Jul 06, 2012
sg1972
  • 225 Answers
SOURCE: Bought amp with no footswitch
The schematic shows it as a standard 1/4 inch stereo plug. Wire the ground common to both switches (Channel and DFX), the ring to one switch and the tip to the other...I.E. ground (sleeve) to ring for one switch and ground to tip for the other. You'll have to experiment with which switch operates what function and label them accordingly.
Posted on Nov 02, 2012
sg1972
  • 225 Answers
SOURCE: wiring diagram marshall mg100fdx footswitch
Using a standard 1/4 inch stereo plug....Ground (sleeve) to tip for one switch and ground to ring for the other.
Nov 02, 2012 | Marshall MG100HDFX 100-Watt Amplifier Head
Wiring diagram for peavey delta blues footswitch
Contact Peavey toll free at 877-732-8391 or by email at customerservice@peavey.com,
Oct 25, 2012 | Peavey Delta Blues Footswitch
NEED WIRING DIAGRAM FOR RENOWN FOOTSWITCH
Aug 10, 2012 | Peavey Music
Three button crate footswitch wires need to be refastened. I need a wiring diagram.
Sep 16, 2011 | Crate Cfs3
On the Marshall 5 button footswitch for the TSL, there are 7 wires in the cable, 6 of which are clearly labeled by color on the circuit board in the footswitch. The brown must be combined with another wire...
Only 6 wires are used by the amp. Tie the brown wire to the metal frame to act as shielding if anything. You will probably find that the brown wire either connects to the shell of the connector or to nothing.
Apr 23, 2011 | Marshall Amplification Marshall 5-Button...
Hi i have a vocalist live 3.. my harmony button..when i press it, it does not stay on. can someone please help me. it worked earlier but not now, i am not sure if i pressed somehting
To the guy with the vocalist live 3. You need to change the FS (footswitch) setting under setup. It toggles between a true switch and working only when you hold it down.
Nov 22, 2010 | Digi-Tech Digitech Vocalist Live 4...
When i press the harmony effect i have to hold it
Well i hope the latching mechanism isn't busted!
Check/review your parameter settings for your programs. Especially in the Expression Pedal Control areas.
From their site:
--Harmony Footswitch
This footswitch turns the harmonies on or off. While multiple harmonies can be selected within a preset, the HARMONY footswitch activates or deactivates any selected harmonies simultaneously.
When the LED above the HARMONY footswitch is illuminated, the harmonies are on. When the LED is turned off, the harmonies are turned off.
--Note: The settings for FX Footswitch Control, Harmony Footswitch Control and Guitar Sensitivity apply to ALL presets. The setting for the Expression Pedal Control applies to the current preset only. If you modify the Expression Pedal setting and wish to store it you must Store the preset (see page 11 ). When you load another preset, its setting for Expression Pedal Control will take effect.
--To perform a Factory Reset procedure
If you are editing a preset, press the Up or Down footswitch to exit edit mode.
Press and hold the Major/Minor button and then press and release the Store button. The display will read FAC RESET- WILL ERASE ALL YOUR PRESETS... , then STORE=RST.
Press the Store button again to continue with the factory reset. If you don’t want to do the factory reset, just wait 5 seconds, or press almost any other button, to cancel.
Mar 27, 2010 | Digi-Tech Digitech Vocalist Live 4...
Pedal Malfunction RP250
You will have to recalibrate your pedal. If you don't have your manual anymore try going to www.digitech.com. The procedure for the RP350 so that you don't lose your presets is : 1. Press and hold the UP/DOWN Footswitches until PDLCAL appears in the display (BYPASS,TUNER and EXIT will be displayed before PDLCAL is accessed after about 5 seconds). 2. When the display prompts you with TOEDN, rock the EXPESSION PEDAL forward (toe down) and press either FOOTSWITCH.
3. When the Display prompts you with TOE UP, rock the EXPRESSION PEDAL back (toe up ) and press either FOOTSWITCH.
4. The Display now prompts you to calibrate the V-Switch sensitivity (VSWxxx), where xxx is the current V-switch threshold. Rock the EXPRESSION PEDAL forward and press firmly on the toe once to turn the V-switch on (WAH ON) and again to turn the V-switch off (WAH OFF).
5. If the V-switch is too sensitive, press the right UP FOOTSWITCH to raise the threshold (range is 0-2000. Keep testing the V-switch sensitivity and adjust the threshold until it only engages when you want it to ( too sensitive a setting will lead to the V-switch falsely triggering on or off when using the Expression Pedal).
6.When the V-switch sensitivity is set to your satisfaction, press both UP/DOWN FOOTSWITCHES simultaneously to exit. NOTE: IF the DISPLAY shows ERROR, an error has occurred and steps 2 through 5 should be repeated. Sorry fo the caps but thats how the instructions appear in my sons manual. You can also dowload the manual and an editor librarian (for the 350 at least) at their site. They might even have an update for your pedal. Hope this helps. Keep playing.
Jul 09, 2009 | Music
Digitech rp6
Try contacting their service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply PS0912 which should still be available. Hope this helps.
May 25, 2009 | DIGITECH VOCALIST LIVE 2
Music Logo
195 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
