Pt 6944 db35 transformer specification - Heating & Cooling
2 Suggested Answers
SOURCE: Identifying specs of blown transformer on PCB
I have the same problem, with the same transformer. Did you ever find the specs?
I was thinking of buying the Frigidaire board, connecting to line voltage and measure output voltage.
Posted on Jun 12, 2011
Can the two transformers be hooked in parallel to service a 500 W zone?
If you are talking about low voltage light transformers, then answer is probably NO... but you could try it and see if it works... but I am almost certain that both transformers will probably burn out.
Output is 12 Volt AC... the transformer coils will probably burn out because the waveform from each transformer cannot be guaranteed to be the same.... even if both transformers are seemingly identical and plugged into same outlet.
For additional information, read transformer installation tips on following page.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#install
Power company transformers can be wired together in specific ways to produce 3-phase waveform, but these transformers are specifically engineered for the task. And the transformers do not combine the output (as you would be doing with yard transformer), instead each power company transformer produces 1 leg of power in a 3-leg power supply.
http://waterheatertimer.org/What-is-3-phase-electric.html#transformer
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 14, 2015 | Hardware & Accessories
Transformer power
try AE.... in Schagen, Netherlands they build new transformers and did a good and cheap job on my PT
Dec 04, 2013 | Crest Audio CC 2800 Amplifier
Can I buy a new print roller for my DYMO LetraTag label maker?
You will need to contact Dymo at 1-800-640-6944 to inquire about the LetraTAG print roller as it is not available online. You can contact them Between Monday to Friday: 9am - 5:30 pm Eastern
Aug 07, 2010 | Dymo LetraTAG Thermal Label Printer
Why Fry - 220 or 110 ????
You should be fine with this. Here is the spec:
Quartz lock large blue LCD display showing: speed, pitch & platter direction, locking platter reverse button, located in battle position, 3-speed design: 33, 45 & 78 RPM, 7 grams of anti-skate adjustment, adjustable pitch control+= 10 & pitch bend buttons, locking reverse button, hi-tech tone arm with height adjustment, feather-touch start/ stop control, strobe illuminator, pop-up target light, headshell, slipmat and dustcover included . 115V/230V switchable. 17.75"w x 6"h x 14"d. Weight:27lbs.
Jul 18, 2010 | Gemini PT-2410 Turntable
Jul 09, 2010 | Frigidaire FAC126P1 wall/window Air...
Need cable, st3250823ace to G5 Mac, power and data cable
I fixed it by getting a reply back from another web site for FREE. Thanks
Jun 20, 2009 | Seagate DB35 (ST3250823ACE) 250 GB Hard...
Lost instruction manual
manuale.gif 636 091 6944-E There u go!
Click on the link above, save the document an your pc,
Its a PDF-file
Good luck
PLEASE rate my help for you
Nic
Mar 09, 2009 | Sanyo Xacti C40 Camcorder
LG DR175--how do i make my dvd player multi regional
http://www.videohelp.com/dvdhacks/lg-dr175/6944
This link has info on a cd rom hack that works for this player. Hope this helps.
Sep 10, 2008 | Televison & Video
Removing kft7aa334f1
Yes thats the flyback or HV transformer.
Jun 24, 2008 | Panasonic PT-56TW53 56" Rear Projection...
Heating & Cooling Logo
274 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
