Question about ViewSonic ViewPad 10s
Pattern password forgot
How to reset as I forgot the pattern lock
I got locked out of my kurio
If the tablet is connected to the internet, tap on forgot password or pattern then enter gmail account to receive an email with the correct password/pattern you set.
Below are steps to recover from being locked out. The first is the most extreme. The second is less extreme. And the third is probably the preferred method.
Firs, t the extreme reset. You lose your data but it returns it to factory default condition, i. e. right out of the box.
Kurio Extreme 2 Factory Reset
Secondly, the soft reset.
Kurio How to Perform Soft Reset
Thirdly, a Kurio password reset:
Kurio Password Reset Kurio 4S Kurio 7S Kurio 10S
Aug 28, 2017 | Tablets & eReaders
How can I reset my tablet?
    1. Here's how to execute a factory reset:
      1. Turn your tablet off and remove the SD card, if there is one.
      2. Press and hold the combinations below until you feel the device vibrate: Power button + Volume up and down (if there is a physical Home button) Power button + Volume up + Home button (If there is a physical Home button)
      Forgot your tablet's password? - TechAdvisory.org
      www.techadvisory.org/2013/03/forgot-your-tablets-password/
    Feedback
  1. Forgotten Pattern, PIN or Password on an Android device
    acer.custhelp.com/.../forgotten-pattern,-pin-or-password-on-an-android-...
    What can I do if I set a Pattern, PIN, or Password on my Lock screen but forgot it? ...If you do not have Android Device Manager installed, the tablet must be reset ...
Nov 29, 2015 | Tablets & eReaders
Locked outmy tablet forgot my info to get on
If you cannot get past the password, then take a look through these pages which may help. If all else fails you can use the method for a factory reset, but be aware that you will lose any data stored.
Unlock forgottten password pattern lock of Android Tablet
How to unlock android tablet after forgetting pattern lock
How to Factory Reset Your Android Phone or Tablet When It Wont Boot
I hope this helps.
I post on behalf of HP.
Jul 18, 2015 | Tablets & eReaders
Change pin number
hard reset by recovey options
Nov 14, 2014 | Tablets & eReaders
Forgot home screen password for Samsung 12.2 tablet. How do I unlock it?
If it's an android device...
1. Enter wrong pattern 5 times and wait for 30 seconds.
2. Select "Forgot pattern" and enter your email account username and password.
3. Make sure you use the same account that was used to activate the device and double check the password by logging in to that email account in a browser.
4. If you don't have access to the original email account, you will need to do a hard reset and loose your settings and apps on the devcice. The data on the memory card will not be wiped though.
Note: if you can't remember your email password, you will have to visit the email service support page to get it reset.
also, see here...
http://www.androidtablets.net/forum/android-tablet-usage-tips-tricks/6280-forgot-your-unlock-pattern.html
or here... http://mytabletguru.com/forgot-password-pattern-unlock-of-android-tablet/
Jul 15, 2014 | Tablets & eReaders
How do I unlock
also, see here...
Jul 04, 2014 | ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip...
I have to reset a proscan tablet plt7044k that is locked up with a pattern password that i have forgot do you know how toreset it
Steps on how to reset the Proscan PLT7044K 7" android tablet.
1. Hold down the power and volume up buttons at the same time until you see the android logo then release both buttons.
2.Hold down power button then push the volume up button once for the reset menu to appear.
3.Use the volume down to select the factory reset to reset all data.
4.Reboot the device after reset has completed.
Mar 29, 2013 | Tablets & eReaders
Forgot password pattern for my a13 tablet
how to reset this thing when itz pattern locked ........?
Jan 05, 2013 | Generic A13-MID 1.2GHz 512MB 4GB 7"...
Forgot lock pattern on lock screen on a 7" uniden tablet
I have a uniden tablet and have had it for about 6 years now I forgot the password and I can't get into it. I have tried everything can someone help? ??????????
Dec 29, 2012 | Uniden Tablets & eReaders
ViewSonic ViewPad 10s Logo
18 people viewed this question
Top ViewSonic Tablets & eReaders Experts
Gareth Cockram
Gareth Cockram
Vijay Damaraju
Vijay Damaraju
Level 1 Expert
Are you a ViewSonic Tablet and eReader Expert? Answer questions, earn points and help others
