Question about Brunton Helios Stormproof Lighter
Repair My Brunton Helios lighter will not light. I have new fuel in it and I can see a spark. If I hold the button down and use an other lighter it lights but with a very low flame when it is on high. What can I do.
2 Suggested Answers
aexl
  • 212 Answers
SOURCE: I lost the bottom cap
Hi there! The only place that will sell Brunton Helios parts is Brunton itself. You can get in touch with them through numbers on this page -> http://www.bruntonoutdoor.com/contact.php. They may not support the product any more, as it is legacy. I would try contacting them first, and then check out second hand stores and pawn shops for a new one. Good luck! Alex
Posted on Jul 05, 2011
2005 Sebring cigarette lighter's not working
This could be several issues:
1) bad fuse.
2) something (rodent) damaged a wire. I had this happen to me with spark plug wire.
3) lighter itself has fail. Sometimes the spring that holds the cigarette light down fails to do so.
Aug 12, 2014 | Cars & Trucks
How do i relight my hot water system
Natural gas or fuel. turn dial to pilot hold down the button. Light with a long grill match or grill lighter. keep holding button until pilot light stays lit when released. now turn the dial to on.
Apr 01, 2012 | Water Heaters
How to change from metres to yards
Hold the back button down until it changes (meters to yards or vice versa). Momentarily push the back button to step through the modes (rain, reflectice, >150, no text=<150). To use turn on with front button, aquire target and hold down front button for 3 seconds
Jul 16, 2011 | Brunton Echo 440 Rangefinder
Several new torch lighter, filled with butane, has spark, wont light.
adjust the fuel output , it is easiest to do by holding the button down while lighting the flame with a seperate lighter and then setting the flame on the lighter that does not ignite proper, also take into account that the temperature of the lighter by being held in your hand for a while or by being in your pocket can have a great effect on the pressure of the buttane being expelled.
Jan 21, 2011 | Garden
Have 2 heaters 1st heater will not light, has gas
sometimes you need to hold down the button for 5 to 10 seconds while the heater heats up,, as soon as it gets to temperature then it should stay on with no problem.
as far as the one that is not lighting -- all I can thing of is that the igniter is not close enough to the fuel exit area ( ? ),, with the power off - ( un-plugged ) look inside as you press the igniter and see if you can see the spark arch. -- also, if this is a new heater there is a chance that there might be something wrong with the regulator and it is either getting to much or not enough gas.
c...
Dec 31, 2010 | Scheu (85-FAC) Heater
Pilot wont light
The thermocouple provides the power to keep the pilot coil energized after being lit and sometimes also provides the power to operate the main gas valve. the gas you hear when you hold down the button is from you manually providing that gas. It does sound as if the spark ignitor it no good. Some use batteries and others don't. If the spark mechanism is used soley for lighting the pilot, then yes, you can light it with a match or butane lighter. Just have the flame there before you push down the button. Keep holding down the button for 30 seconds or so to warm the thermocouple after it is lit. Good-luck.
Nov 02, 2009 | Heating & Cooling
How do I light pilot on Vaillant boiler
turn and push in button on your honeywell gas valve hold it in and spark lighter cont to hold for 20secs then ease finger off button very slowly pilot sould stay alight if not try again in 2mins best of l;uck
Sep 29, 2009 | Water Heaters
Helios h4000
While this was posted 2 years ago, I found a company that does repairs on the Helios, in fact I have used them twice so far for repairs on my unit. The first time for the power supply problem and the second time for a jammed tray door in March of this year; it would not open.
ECP Repair and Service in Eagleville, Pa.
Nov 10, 2008 | Neodigits Helios H4000 DVD Player
Brunton Helios Stormproof Lighter Logo
201 people viewed this question
Top Brunton Sport & Outdoor - Others Experts
Are you a Brunton Sport and Outdoor - Other Expert? Answer questions, earn points and help others
