Question about Kyocera Copystar 221 Black and White Copier
Drum reset counter taskalfa 221 - Kyocera Copystar 221 Black and White Copier
2 Suggested Answers
shawn38
  • 200 Answers
SOURCE: describe how to put the scanner wire in taskalfa
Fitting the scanner wires
NOTE:
When fitting the wires, be sure to use those specified below.
Machine front: (P/N: 2C91236), gray
Machine rear: (P/N: 2C91235), black
Fitting requires the following tools
Two frame securing tools (P/N 302C968310)
Two scanner wire stoppers (P/N 3596811)
Procedure
1. Remove the rear cover.
2. Remove the screw and remove the scanner wire drum gear from the rear side of themachine.
3. Remove the stop ring and bush.
4. Remove the stop ring and bush from the front of the machine.
5. Remove the scanner wire drum shaft from the scanner unit.
6. Insert the locating ball on each of the scanner wires into the hole in the respective
scanner wire drum and wind the scanner wire three turns inward and four turns outward.
With the locating ball as the reference point, wind the shorter end of each of the wires outward.
7. Secure the scanner wires using the scanner wire stoppers.
8. Refit the scanner wire drum shaft to the scanner unit.
9. Insert the two frame securing tools into the positioning holes at the front
and rear of the scanner unit to fix the mirror 2 frame in position.
10. Loop the outer ends of the scanner wires around the outer grooves in the pulleys on the mirror 2 frame, winding from below to above.
11. Hook the round terminals onto the catches inside the scanner unit.
12. Loop the inner ends of the scanner wires around the grooves in the pulleys at the left of the scanner unit, winding from below to above.
13. Loop the scanner wires around the inner grooves in the pulleys on the mirror 2 frame, winding from above to below.
14.Wind the scanner wires around the grooves in the scanner wire guides at the left of the scanner unit.
15. Hook the round terminals onto the scanner wire springs.
16. Remove two scanner wire stoppers and frame securing tools.
17. Focusing on the locating ball of the wire drum, move aside the wires to inside.
18.Move the mirror 2 frame from side to side to correctly locate the wires in position.
19. Put the mirror 1 frame on the scanner rail and move it toward the left side of the machine.
20. Insert the frame securing tools into the positioning holes (leftmost holes) at the front and
rear of the scanner unit and screw the mirror 1 frame while securing both the mirror 1 frame and the mirror 2 frame.
21. Remove two frame securing tools.
22. Refit all the removed parts.
I hope this is helpful,
Shawn
Posted on Mar 16, 2011
I have kyocera taskalfa 221 error code 6000 what can i do
I am afraid that your heater lamp is broken.
You will need to replace your fixing unit.
Best regards,
Marius
Nov 04, 2016 | Kyocera Office Equipment & Supplies
How can I fix the error c6400 on kyocera taskalfa 221?
Hi
I found this explanation of your error, although my understanding of it is not entirely clear.
Code: C6400
Description: Zero-cross signal error
Interrupt of the zero-cross signal does not occur more than 1 s.
Causes: Poor contact in the connector terminals.
Defective power source PWB.
Defective engine PWB
You can find this here:
Error Codes Kyocera Mita TASKalfa 221 Code C6400
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 17, 2014 | Kyocera Office Equipment & Supplies
How To Replace Kyocera Taskalfa 180 Copier Drum
Hopefully this will help.
Source:
http://www.manualowl.com/m/Kyocera/TASKalfa-180/Manual/345566
Dec 30, 2013 | Office Equipment & Supplies
Kyocera taskalfa 300ci
10871087 to enter service mode. There are 2 maint. kits for the 300ci. One for color and one for mono. If you were able to perform a maintenance then you should be well versed on which adjustments to make and which counters to reset. If not you can cause major problems so be careful.
Dec 16, 2013 | Kyocera Office Equipment & Supplies
Reset counter taskalfa 2550ci
there are many counters that count "page counts" for keeping up with PM, roller life, etc... if you are referring to the total counters they cannot be reset.
Nov 28, 2013 | Kyocera TASKalfa 180 Copier
Can I use Kyocera 180 as a scanner
No, a TaskAlfa 180/220 series will not scan. The 181/221 series can have a scan card added as an option.
Sep 17, 2013 | Kyocera Office Equipment & Supplies
Reset drum counter on a muratec mfx 1430
Drum counter is reset by installation of a "NEW" drum.
There is a small fuse at the rear of the drum on the top( you will see the 2 brass contacts) When a new drum is installed, the fuse blows and resets the drum counter. Installing a used drum will not reset the counter as the fuse is already blown.
Sep 15, 2009 | Muratec MFX-1430 Copier
Brother HL 1250 Laser. Drum & page counter
Reset the drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
  4. close front cover
Mar 23, 2009 | Brother HL 1250 Laser Printer
How to reset drum counter for fuji xerox 203A
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
Aug 28, 2008 | Office Equipment & Supplies
Kyocera Copystar 221 Black and White Copier Logo
69 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
