Why is my machine ir1600 keeps on mixing toner yet toner is there full.?
2 Suggested Answers
spinal
  • 287 Answers
SOURCE: canon6050 toner recycling
I have glanced at and passed by your question several times, and finally cannot resist the urge to answer. Canon copiers are unique in the fact that they are " monocomponent". This probably means nothing to the average person. But suffice it to say,the"waste toner" you speak of is primarily drum polish and paper dust, neither of which is very good at producing a decent copy. In fact, ANY percentage of waste toner introduced into the Canon copy process is a recipe for disaster. I primarily say this because at some point you will have to replace the development unit (or have some serious service) and probably replace the drum ($1000) if you continue. I am not a Canon employee but have worked on Canon equipment for over 20 years. I merely wish to help. I would be hard pressed to see how you can save enough money up front to cover the back end costs.
Posted on Apr 10, 2008
Canon IR1600 Copier
what do you mean copy halfway only on the top of the paper or only on down side of the paper, or only on the left side or right side of the paper...are u using A4 paper..?
Dec 09, 2013 | Canon IR1600 230 VOLT 50/60HZ
How can solve mixing toner canon ir1600
when ur machine make mixing toner check the sensiors
Oct 12, 2013 | Office Equipment & Supplies
I Just replaced the toner in my CANON IR1600 PHOTOCOPIER and now have the Error code E100. I put the old one back in to see if it was different but it still said E100. How can I fix this? Thanks
Hi carolyn ,
I am a professional canon service eng . My Name Is D K Kumar . e100 is not related to toner at all . it is the indication that the develper unit has not been detected . remove the left side cover . you will be able to see the top of the develpoer unit. On the left top portion of the developer unit u can see a white coloured accuvator . it is a small white plastic piece ..whhen the side door is closed te white piece should get pressed or should move forward . if the moving action is not happening then the m/c will give u E100 error. in your case the reasons /problem could be :
!) The spring connected to the white plastic accuvator is missing or spring action is not happening.
2) the white accuvator it self is broken or missing.
3) the plastic stick /piece which protudes from the side door and pushes the accuvator is broken.
4)lastly you have not closed the side door properly or not closed at all.
Carolyn if u r able to understand my above tips thn u can do it your self , if not call a your local canon enginer.
best of luck God Bless u
P.S. Carolyn if my solutions have helped u then i request u to kindly reply to me at my enail id: narkumar81@rediffmail.com
Apr 10, 2011 | Canon Office Equipment & Supplies
Canon ir 1600 my copier print copy image is very poor
iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
Use GENUINE CANON DRUM UNIT and GENUINE TONER.
Jul 02, 2010 | Canon Office Equipment & Supplies
Canon IR1600 - E100 error
Delete the softwere from control pannel then install it again using the CD provides with the Printer
Feb 13, 2010 | E-Games Fax & Photocopy Full Version for...
My toshiba is showing that it's out of toner and won't copy. I've had a look and the toner cartridge is still pretty full so any help would be great!!!
hi when the copiers shows that need toner it is becouse there is no toner in the mix of developer, this is caused by a wrong toner in the machine, check that the toner is the one the machine use there are few copiers like lanier that seems to use the same cartridge but change the gear that turns the toner in the machine, move manually the gear in the cartridge by looking that the toner actually it is ok, activate the motor that moves the toner cartridge and check thatis is moving, also check the gears on the developing unit becouse if any of them dont move the toner never get the sensor of the developer unit and shows the signal of lack of toner
jesus contreras ortega
Sep 09, 2009 | Toshiba 1370 Black and White Copier
Gestetner 3245 error
Your machine must be serviced by a trained technician. Cleaning out the used toner requires disassembly and specialized knowledge and equipment. If you keep using the machine, it will stop working completely when the used toner is full, and will not be usable until the used toner is cleaned out.
Sep 26, 2008 | Office Equipment & Supplies
jasbo
jasbo
