Question about GE WBSE3120B Top Load Washer
Wlre4500g0ww Where's the washing machine filter
2 Suggested Answers
SOURCE:
machinetech7
  • 1344 Answers
SOURCE: WLRE4500G0WW Load Sizes
http://www.partselect.com/Schematics/GE/00123300i01.gif
Look at part number 10. This is called the pressure switch and controls the amount of water that goes into the machine. What I would do is put some water into the machine, and with the water in there unplug the machine and access the pressure switch. When you can visually see and reach the pressure switch, you will notice there is a hose that is connected to it. Remove the hose and then blow into it. What you are doing is making sure that the airway is clear and you'll know because the water in the machine will start bubbling if so. If the airway is clear and there are no holes in the tube, change the pressure switch
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Posted on Jun 16, 2012
Samsung SW60ASP washing machine won't spin or drain
5E is a Drain Error Code.
This can be caused by a clogged filter in the washing machine or a blocked drain line in your house. There can be a few other reasons, but these are the most likely.
If you would like to try to repair it yourself, then follow these instructions:
UNPLUG the washing machine. Repeat, UNPLUG the washing machine!!!
Check the filter in the back of the washing machine on the bottom right-hand corner. Place a shallow dish under the filter. Loosen the filter to drain out the water. Remove the filter and clean it out. Look at where you removed the filter and you will see the water pump impeller. Make sure it can move and isn't locked up. Remove any debris from the impeller.
Replace the filter, and plug in the machine. Try a short wash cycle.
Check for leaks around the filter.
Mar 11, 2013 | Washing Machines
AEG Lavamat 16830 won't drain
The simplest way is to lay the washing machine on the right side so that you filter closer to the floor and from bottom of the washing machine is accessible drain pump. It can be fixed by three screws
or just turn pump counter clockwise and pull out.
Dado
Mar 29, 2017 | AEG Washing Machines
Remove washing machine filter for cleaning: How do I remove the filter on my Bosch class iXX front load washing machine for cleaning? We can turn it 1/3 anticlockwise but it won't pull out.
Something must be jamming the filter. You will need to just keep working it. If you cannot get it to open, you will need to replace the whole assembly.
Nov 03, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Where is the filter in washing machine
Start by turning off the hot and cold water faucets that are connected to your washing machine. This will stop water from running into your washer so you can disconnect your water inlets without flooding the house! To relieve any built-up water pressure, pull the knob out on your washer that starts the washing cycle for just a few seconds. Now it's time to unplug and disconnect your washing machine. First, unplug your washer from the electrical outlet. Next, use a pair of pliers to unscrew the hose fittings on the back of the washing machine. There will likely be some water left in the hoses, so you will want to have a hose or a bucket handy in order to catch and clean up any spillage. Now it's time to break out the water-resistant vacuum. Place the vacuum over each water inlet. As you turn on the vacuum, tap on the inlet a little with a plier in order to free any debris or sediment that may have lodged in it. Continue vacuuming until the inlet is clear, then repeat on the second water inlet. Now that you're done clearing out the filters, it's time to reconnect your washer. Using your pliers, reconnect the correct hose to its inlet and make sure to tighten them properly. Don't forget to double-check to see if there are any leaks. If you find any, re-tighten accordingly. After that, all you have to do is plug your washer back into the outlet and you're ready to go. You've successful cleaned out your washing machine filter!
Aug 05, 2012 | Hotpoint Aquarius WF000 Front Load Washer
Jun 13, 2012 | GE Washing Machines
How often do I wash filter for dyson dc33 upright vacuum cleaner
Hi Mary,
In normal use, you should wash the filters in your DC33 at least once every 3 months. Use cold water without detergent - do not wash in a dishwasher or washing machine. Allow at least 24 hours for the filters to dry completely before replacing them in the machine - it may help to place them somewhere warm, such as by a radiator.
For step-by-step guidance on maintaining the filters, please see our online Support guide:
http://www.dyson.co.uk/support/dc33/dc33-multi-floor/dc33-maintaining-your-dyson-machine/wash-the-filters/filter-removal-step-1
I hope this helps - if you'd like any further assistance or advice, please visit www.dyson.com and click 'Support', or call our customer Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 13, 2012 | Dyson DC33 Bagged Upright Vacuum
Can you please let me know the position of the filter(s) for this particular washing machine? I just couldn't find the filter. The machine is getting not so sensitive now - sometimes just stopping half...
Actually the 'Cabrio' model, for some reason which I cannot fathom, does NOT have a filter which I have to say seems a bit strange! Maybe it is not practical/feasible (???).
It must be possible to be able to have the drain motor/pump checked 'cos that could be a bit blocked up???
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 01, 2011 | Whirlpool Cabrio WTW6800W Washer
My LG washing machine model-fuzzy logic WF-s6607tc, is not spinning
The filter for your empty pump is probably clogged. The machine can't drain the water in the alloted time because it is draining to slowly through the clogged filter. The machine won't start the spin cycle if all the water hasn't been evacuated. You will need to find and clean out your empty pump filter (Probably behind a little door at the bottom of the machine.
Jun 23, 2011 | LG Washing Machines
Washing machine not draining water during washes
hi..The problem most probably is your pump is not working
or the hose that the water drains out is blocked.
check it out..
thank u..
kindly rate my response..
May 08, 2009 | Washing Machines
GE WBSE3120B Top Load Washer Logo
18 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
