Question about ViewSonic VX2450WM Monitor
Disassemble take the lcd screen out
I need both screens for rca Galileo 11 pro lcd and touch screen
Answer 1:
From your description, the LCD is cracked. The outer glass you described is the touch screen digitizer and it sounds as though this is intact. If it was broken, even with the LCD visibly cracked, you would see that it was also broken. A similar question was asked in the forum titled, How do I replace a cracked screen?
In reviewing that post, the first answer indicates that the digitizer can be replaced independently from the LCD. Upon doing a search on Amazon for the LCD itself, I did find one listing that you could use to purchase it separately. However, the disassembly video in that post was focused on replacing the digitizer.
I found a similar video on Youtube, titled RCA 10" Screen Replacment - Disassembly - RCT6203W46 PRO, which may be more relevant to start from the back and work your way to the LCD. This video goes as far as replacing the digitizer, but you'll just need to remove the LCD and the respective connections and attach the appropriate ones to the new LCD.
Furthermore, I did a search on eBay and discovered that there are two versions of the LCD. One that is a straight lcd cable and the other that uses an l-shaped cable. It is important to purchase the correct one. This ebay listing is specifically for the straight cable, but the seller also sells the l-shaped cable as well.
How do you know which one your tablet has? You may need to disassemble it to find out, as there was no specific documentation that I came across based on the model number or manufacturing date that indicated a specific way to know. You could try contacting RCA support, but disassembling helps confirm it before you decide to order from eBay, Amazon or any other third party.
Answer 2:
https://www.google.com/search?q=I+need+both+screens+for+rca+Galileo+11+pro+lcd+and+touch+screen%3F&rlz=1C2GIGM_enUS766US766&source=univ&tbm=shop&tbo=u&sa=X&ved=0ahUKEwi6rqjt6IXXAhWKQCYKHUNvBNcQsxgIKA
Oct 22, 2017 | RCA Computers & Internet
How do I disassemble a Vizio E3D470VX Smart TV, to clean out the dust inside the Screen
Hi Alonzo,
To clean the dust inside the screen, you will have to disassemble the LCD panel. It is a very risky job and there is every chance of damaging the LCD screen unless you have a real good experience of doing it. If you are not good at doing such jobs, please let some professional do it for you.
Jul 05, 2016 | Vizio Televison & Video
How can I replace videocone integra LCD screen ?
You have to disassemble the TV; fully; to replace it. Should have all tools to disassemble it, and much experience in work too.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Nov 26, 2014 | Televison & Video
Acer 4745g black screen problem
So, if you can hear startup sound then motherboard, RAM and HDD is OK! Try to connect it with external monitor, if it's working on it, then problem in LCD, LCD light or LCD cable. If not working with external monitor then it is video card problem, if card is integrated then you need to reball or change at all south bridge on the motherboard, if video is as module card then just replace it with compatible one.
If LCD cable - disassemble laptop to get LCD cable and test each wire with any multimetr with sound beep and replace it if needed.
If LCD light - try to take LCD screen under good lamp then power on laptop and carefully look to dark screen if you see very dark Windows boot screen then you need to disassemble LCD housing, disassemble LCD, remove and replace LCD lamp with working one.
If all this cant help, then you need to replace LCD at all.
Nov 15, 2012 | Computers & Internet
Screen on laptop is distorted halfway
A) Video Cable connections are loose:
Connection at the motherboard, and the connection at the back of the LCD screen, in the Display Assembly.
Both need to be checked.
[For Toshiba the Video Cable is termed LVDS Cable.
Low-Voltage Differential Signaling Cable. I will just keep referring to it as the Video Cable ]
B) Video Cable is damaged:
Observe the sheath at the motherboard side of the Video Cable?
Is there obvious signs of damage to the sheath of the cable?
If so, there may also be damage to the tiny, thin wires inside the sheath, of the Video Cable.
Due to the routing of the Video Cable under the left Hinge, the Video Cable may be pulled on. This can create a bad connection.
Due to the above also, the Video Cable's sheath may be damaged, and the wires inside.
A view of the Video Cable by itself,
http://www.batterystyle.com/toshiba-satellite-a205-s5880-cable-p-484063.html
If the Video Cable checks out to be OK, the next item is the screen Inverter.
To test a screen Inverter you need a sensitive multimeter. This usually means expensive. { Or use a known to be good, compatible screen Inverter } Just thought I would state that. Don't want you to completely disassemble your laptop, just to fix a Video Cable, or screen Inverter. {Or LCD screen)
Most consumers decide to just replace the screen Inverter because;
1) If the problem isn't the screen Inverter, it is the LCD screen.
(A LOT of people buy an LCD screen, when all they really needed was a screen Inverter)
An EXPENSIVE part.
(LCD screen? $150 to $400 approximately. Screen Inverter? Usually around $22 to $48 )
2) The ease of access to replace.
As stated, if the problem isn't the screen Inverter, then it is the LCD screen.
1) With ALL power removed, AC adapter (Charger), and Battery, remove the Keyboard Bezel, and the Keyboard.
This is the motherboard connection side.
Display Assembly removed with Video Cable.
Now remove the Display Bezel, and LCD screen assembly, to access the Video Cable connection to the back of the LCD screen.
{NOTE*
The screen Inverter is mounted at the bottom of the LCD screen, and behind the Display Bezel }
This shows the Video Cable, and it's connection at the motherboard side,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-2.htm
Scroll down, click on the photo in Step 9.
The Video Cable is the cable to the upper Left side. Has one Red arrow pointing to the left.
The photo in Step 10 shows the Video Cable disconnected from the motherboard.
(This is Page 2 of a disassembly guide. Pages 1 through 4 are available above, and below. Page1::Page2::Page3::Page4::Find another model,
in white.
Just thought I would state that. Don't want you to completely disassemble your laptop, just to fix a Video Cable, or screen Inverter, or LCD screen) )
2) LCD screen side:
http://www.irisvista.com/tech/laptops/toshiba-satellite-a215/disassemble-display-panel-4.htm
http://www.insidemylaptop.com/remove-lcd-screen-from-toshiba-laptop/
All three links above will help you with checking the connections, or removing the cable to perform a continuity check. (Test)
Also with accessing the screen Inverter, and LCD screen.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 25, 2012 | Toshiba Satellite A205-S5880 Notebook
My computer fell out of the car on its bottom closed. got it home plugged it in it started up great when it got to running the screen went dark. not sure what could be wrong
Seems that the LCD screen cable went loose at either its connection with the inverter board or the LCD screen itself. You need to disassemble the LCD screen panel & check the cable connections at both ends. I would also recommend to disassemble the whole laptop & check all connections. The fall might have caused any of the connections to become loose.
Oct 11, 2010 | Compaq Presario CQ60-220US PC Laptop
Hi, I have hp pavilion dv2500 laptop. I have display problem.pls help how to rectify it. If i connect exteranl CRT monitor Display is coming . Pls tell me how to disassemble the laptop.
You might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
In this service manual, you will find an illustration of how to disassemble the laptop & replace either the LCD cable or screen inverter board:
http://h10032.www1.hp.com/ctg/Manual/c01295820.pdf
Sep 17, 2010 | HP Pavilion dv2500t Notebook
How do u change the screen on a d900
For change LCD is not necessary to disassemble all the phone remove only the four screw behind the screen (2 up and 2 under battery) ,remove flex cable and replace LCD.
Not necessary to disassemble the mothrboard.
Sep 09, 2009 | Samsung Cell Phones
I bought a HTC 8925 AT&T Tilt LCD Display screen with Touch
Try http://www.RepairsUniverse.com
They sell the screens at the best price and also provide full video fitting instructions on their site.
Oct 22, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
ViewSonic VX2450WM Monitor Logo
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
