Sharp ar m236 printer
It shows:- call for service code f9-10. please i need solution for it.
tehnik_bdg
  • 91 Answers
SOURCE: I need to obtain a meter reading for sharp ar-m236. How do I do that?
Simply press and hold the copy mode then you get the meter reading and toner percentage status
Posted on Apr 16, 2009
  • 990 Answers
SOURCE: sharp AR-M236 Fault U2-40
Hello sir; This error code require reset the procedure as follow;
press "#/p" " . " "clear" " . " then enter 16 press start enter 0 press start again, press "clear all" machine will back to normal.
Posted on Aug 04, 2009
  • 3741 Answers
SOURCE: sharp ar-m236 error code H4-21
-H4-21 means: Sub heater lamp abnormally low temperature detection. The setup temperature (about –25°C: Sim 43-1-1) is not reached within the specified time (about 32sec) from turning on the power ON SW. (When the temperature falls below 140°C in the standby mode.)
-Causes:
Sub heater thermistor defect
Sub heater lamp failure
Sub thermostat failure
Control PWB failure
-Check the sub heater lamp blinking with SIM 5-2-2.
When the lamp blinks normally: Check the thermistor and the harness. Check the MCU PWB thermistor input circuit.
When the lamp does not light: Check for disconnection of the heater lamp and thermostat. Check the interlock switch.Check the power PWB and the MCU PWB lamp control circuit.
Clear the display of self-diagnostics with SIM 14.
The H4 errors will not reset by themselves. You must enter service mode to reset this error even if the problem has been repaired. The reset process is outlined below (DO NOT USE ANY OTHER FUNCTIONS IN SERVICE MODE):
Press the following sequence: "#/P" "*" "C" "*"
Type in 1 4
Press start
hit 1 for yes
hit start
Unit should power off and the restart.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Dec 28, 2009
  • 35 Answers
SOURCE: sharp copier ar-m236 error h4-21
try to reset by programming...here u just do ..p * c * (p star c star ) u will go in simulation mode .then press 14 ,start .mechine will ask you yes or no ? u just press 1 for yes .and press start ...your mechine will work..if same problem prsist try to check fusing unit...dont forget to thanks to me
Posted on Feb 10, 2010
  • 3 Answers
SOURCE: please i need to reset my sharp ar-m236 password
You can reset the nic card password by ressetting the nic card to factory defaults, custom setting, key operator, 00000 , print settings , network settings, reset the nic, default password is Sharp
Posted on May 18, 2010
Call for service error code u2-40 on sharp copier AR-M236
That means there is a bad CRUM chip or the developer unit isn't connecting properly.
Aug 20, 2011 | Sharp AR-235 Copier
Code e7-02 sharp Ar m236
Hi.
that erorr is for SHARP AR405 E7-02 Laser unit problemHere an link
service manual here
Feb 13, 2011 | Sharp AR-235 Copier
I have Sharp copier AR-M236 with error code:f2-04, how can i remove this error?
That error is a bad CRUM. Replace developer unit use only Sharp supplies. The chip on the developer unit doesnt match with the machine.
Aug 22, 2010 | Sharp AR-M237 Copier
Please i need to reset my sharp ar-m236 password how do i do that
Mar 15, 2010 | Sharp AR-M237 Copier
Sharp AR-M236 Fault U2-40
Aug 04, 2009 | Sharp AR-235 Copier
Apr 15, 2009 | Sharp AR-235 Copier
How can I inter to s.p program for sharp ar-m236
Basicly there is not a trick to the S.P. mode. You go in to it & touch The S.P. on the display and then turn the main power switch off and then back on and that is that is needed. But if that did not work you will need to go deeper in to the problem.
Dec 16, 2008 | Ricoh Aficio 1035 Copier
26 people viewed this question
k24674
