Question about Gateway (4000274) Motherboard
Bus error driver 816909015911 ex0000227 - Gateway (4000274) Motherboard
MSI 945GM2 H-F (816909015911) Motherboard
You can download the device drivers from MSI WEB supportsite, select your model motherboard to download :-http://www.msi.com/index.php?func=downloadindex
Apr 20, 2012 | MSI 945GM2 H-F (816909015911) Motherboard
Error code oxE0000227 in audio driver for intel mother board D945GCNL
Install the driver again.
Hope this helps. Let me know if you need more informationThanks
May 01, 2011 | MSI 945GM2 H-F (816909015911) Motherboard
I´m trying to install the driver and on the
You may encounter this error when installing the Realtek High Definition driver in XP. You can download the driver here.
Here is the solution:
  • Open Device Manager (Start> Control Panel> System> Hardware)
  • In the "View" menu , select "Devices by connection":
  • Disable and uninstall by right clicking on " UAA High Definition Audio Bus Driver for Microsoft":
  • You can now install the drivers normally and without error.
Hope this helps
Jan 23, 2011 | MSI 945GM2 H-F (816909015911) Motherboard
How to remove this erorr ox E0000227
Download (as in Save, not Run) the latest audio driver and install it. If it still doesn't work go to Device Manager/Device Drivers and disable and uninstall the Microsoft UAA bus driver before installing the Realtek driver.
Jan 27, 2010 | MSI 945GM2 H-F (816909015911) Motherboard
I have problem in realtek hd audio driver failure error code oxe0000227. how to rectify immediately
first reformat your pc and update inf driver then download MICROSOFT UAA HDA this driver from intel web site. and install it on pc then install sound card driver.
Dec 11, 2009 | MSI 945GM2 H-F (816909015911) Motherboard
Audio Driver Install , CD Drive Problem
You can either download the driver by clicking here or here and install it on your PC, since your CD/DVD drive isn't working properly like you said. Hope this will help you.
Sep 24, 2009 | MSI 945GM2 H-F (816909015911) Motherboard
Install Realtek HD driver failure
may be you have wrong audio, i mean the audio driver might not be compactable with your system, try visit google and search for your system audio driver pls
Jul 10, 2009 | MSI 945GM2 H-F (816909015911) Motherboard
Install realtek hd audio driver failure error code oxe0000227
1) open device manager click "system devices" disable "microsoft UAA bus driver for high definition audio"
2)uninstall "UAA bus driver" make rescan devices (Note: Not all had this step. You may want to skip it.)
3) install realtek driver the realtek driver includes the UAA driver too.
Jun 07, 2009 | MSI 945GM2 H-F (816909015911) Motherboard
Gateway (4000274) Motherboard Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
