Question about Radio Communications
UN-BTS07 I have lost the manual for this Stereo bluetooth headset. How do I put it into pairing mode ???
SOURCE: CABLE & WIRELESS CWBTH160
To initiate pairing, put the devices within 0.5m of eachother
Make sure phone / pc bluetooth is on and discoverable
Make surea headset is fully charged
  1. Ensure headset is switched OFF
  2. Press and hold the talk button (big central button on front of headset) until the indicator flashes red & green alternately, then release. Headset now ready for pairing.
    Note: Headset pairing mode will time out after 5 mins.
  3. To allow phone / pc to "find" the headset, consult your phone / pc bluetooth operating guide on pairing devices.
  4. Headset should be listed on phone / pc after search has finished - highlight and select the headset.
  5. A pin or password screen will appear, you must enter 0000 and confirm.
  6. When pairing is successful, headset indicator will change to green and flash continuously every 3 seconds.
Pairing is then complete.
Note: Multi-pairing.
It is possible to pair up to two phones with the headset - the most recently paired phone becomes the "primary "phone... only one phone can be connected at a time --> this function only works in Hands-Free profile. If both phones are in range, then the headset will connect to the "primary" phone first.
Posted on Jul 07, 2008
SOURCE: What is the default passcode for the Logitech F-0228A Mobile Freedom headset?
Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Pair Your Headset
Before using, you must pair your headset.
1. Turn phone on.
2. With Headset off, push Talk/Volume up button for 10 seconds. Blue LED will flash rapidly.
3. Follow pairing instructions in phone-setup or connect menu. Your phone should find “Logitech
HS04VXX”Headset and prompt you for a passkey pin.
4. Enter “0000”.
5. Press OK on phone.
6. From Headset device list press “Logitech HS04VXX” Headset.
7. Select connect.
When your Headset is successfully paired, the blue LED will flash slowly.
Posted on Sep 04, 2008
  • 3 Answers
SOURCE: alcatel universal bluetooth headset manual
I don't know if this will help but try this:
Make sure the headset is charged up.
On your phone, go to settings and find the bluetooth set up. Don't start it yet.
on the headset, press and hold the on/off button until the light comes on. It should flash blue and orange.
Now press the "add device" or similar language on your phone. It will search for the headset. Once it is found it will ask for a passkey. Try typing in 0000 (that is, four zeros). Press ok.
It should work now.
Posted on Dec 05, 2008
SOURCE: Lost N136 Manual
I have an N136 which turns out to be an HS850 (with folding boom}. This model requires the boom to be folded while the answer button is held down, When the light comes on the boom must be extended before the light goes out. The light will now stay on and the phone should find your headset.
Posted on Feb 12, 2009
SOURCE: Motorola Bluetooth HS850 Pairing Mode
This worked great for me... I got the headset in "pairing" mode by following these instructions. Then set my BB Curve 8350i to "discover" bluetooth devices. It discovered the headset and asked for a PIN number... one of the other articles I read said the pin was "0000" so I put that in and - PRESTO - it works
Posted on Jun 04, 2009
How can I get my player to connest to my bluetooth headphones have tried several times no luck
If you have a Kindle Fire or later this is possible. Any Kindle before this model has the hardware for BT, but not any method to access the BT (bad on Amazon\'s part, but that\'s the way it is).
Kindle Fire do this: Go to settings --> Wireless --> Bluetooth Turn on Bluetooth if it is not on.
Now on your headset put it in pairing mode. Instructions on how to do this should have come with your headset. Once in pairing mode press Pair a Bluetooth Device on your Kindle. Your Kindle should "see" your headset and list the name of it under PAIRED DEVICES.
You only need to pair the device once. Then you should be able to press the device name and if the device is near by and on it should connect to the Kindle.
HTH
Jul 31, 2014 | iLive IHB603B Micro Bluetooth Stereo...
I go to set up my wireless headset with my playstation 3 but it won't pick up any devices.
You must put both the PS3 and the Backbeat into pairing mode. See your instruction manual for the PS3 for pairing. Once you have both devices searching for each other they should pair right up.
Instructions for putting the Backbeat 903 in pairing mode:
With the headphones powered off, press and hold the Power/Pairing button until the LED indicator flashes blue and red.
Use the PS3's menu to search for the Bluetooth headphones and select 9xxBackBeat.
If prompted, enter 0000 for the PIN code/passkey.
Here is a link for the User's Guide:
Plantronics Backbeat User's Guide
Good luck from Headsets Direct!
Mar 23, 2011 | Plantronics Backbeat 903 Bluetooth...
I.Tech BlueBand Bluetooth Stereo Headphones whate is the pin code
Hi, In some states, hands free driving is the law. In order to avoid a ticket you need to talk on your cell phone with a bluetooth headset or speaker or with a headset that attaches directly into the phone. Bluetooth headsets are popular for this and other reasons but connecting it to your phone can be confusing. Here are some steps to help you connect your bluetooth device to your cell phone.
Instructions
Things You'll Need:
* Bluetooth headset
* Bluetooth capable cell phone
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Hope it helped.
And please don't forget to rate me...
Thanks and have a nice day...
Feb 21, 2011 | Itech Blue Pro Bluetooth Stereo Headphones...
How do I put my jwin jbth710 stereo bluetooth headset in discovery mode
Usually, bluetooth headsets enter pairing mode when you hold the button beyond turning the headset on.
Nov 16, 2010 | Jwin JBTH710 Bluetooth Headset
Hello I have lost owner manuel for my bluetooth wep301 samsung does anyone know what do to
Pairing Headset
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
You can obtain a copy of your user manual by locating the FCCID on the label directly on the device, then then going to the FCC Website - https://fjallfoss.fcc.gov/oetcf/eas/reports/GenericSearch.cfm
Be sure to put the first three characters in the first box and the rest (including hyphens) in the second box.
Oct 15, 2009 | Samsung WEP301 Bluetooth Headset
N97 connectivity problem with bluetooth HBH DS 200
Sep 08, 2009 | Sony Ericsson HBH-DS200 Stereo Bluetooth...
Lost instruction manuil for my mad catz bluetooth wireless headset
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above. Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Sep 04, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
LG HBS-200 Bluetooth Stereo Headset user manual instructions needed to pair with blackberry
User Manual
Aug 30, 2009 | LG SGBS0001606 Bluetooth HBS-200 Stereo...
Need to setup H300 bluetooth to my LG VU phone! How do I do this?
The quick answer is that you can put it into pairing mode, and your phone should recognize it. To put into pairing mode, push and hold the large power/answer button for at least 6 seconds. The light will start flashing, indicating that it is in pairing mode. Go into the Bluetooth menu on your phone and make sure Bluetooth is turned on, that your phone is visible, and that you can search for new headset devices. Make sure the headset is still flashing. When you discover the headset in the phone, it may prompt you for the code. I believe the pairing code is "0000". Add the device to the phone. You should now be able to use it with your phone.
If this doesn't get you there, do a search for H350 Manual to get a pdf of the user manual and quickStart guide.
Jan 08, 2009 | Motorola Mobility H300 Wireless Headset
Motorola H350 User Manual
On your bluetooth headset, hold down the power button until the light stays on steady. (it will blink when you initially power it on, but continue to hold for another few seconds for the steady light!) Your headset is now in pairing mode.
On your RAZR, press Menu > Settings and Tools > Connections > Bluetooth > Handsfree > Look for devices. Your phone will then scan for any bluetooth devices that are in pairing mode. When your headset pops up on the list, highlight it and press ok to connect.
If the device asks permission to bond with the phone, select yes. It will then prompt you for a pin code. The pin will be 0000 .
Jan 08, 2008 | Motorola Mobility Bluetooth Hands Free...
Radio Communications Logo
37 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
