Question about Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
"blotchy" picture on l.c.d. flat screen television
We recently bought a floor model of a flat screen lcd high def. television. there is a certain spot on the screen where there seems to be a "dirty" area...this is not noticable all the time, but more pronounced on lighter screens and flesh tones. We contacted Sony and the tech said to wipe of screen with a damp wet cloth. this didn't help. To me the screen doesn't appear to be smudged when the tv is off...but my husband says he can still see smudging. someone says if the l.c.d. screen is damaged this will cause the dark lines and smudges we see on the screen. if the screen is damaged does this void the waranty and if so, how costly is this problem to reapir? How CAN you clean an LCD screen? Thanks
  • 157 Answers
SOURCE: smudge looking marks onscreen
If you suddenly noticed it, this is most likely caused by a large piece of dust on the lens. It is hard to clean, you would need to take the whole TV apart in order to get to the lens (mounted on the optical block).
It could also be caused by a failure of the optical block, which had inherent issues. There is a pending class action law suit against Sony for problems with optical block that include smudges, hazes, and tints that appear after a certain number of hours.
Other causes could be a dirty portion of the mirror or a smudge on the inside part of the screen but these are rare because dust and contaminants do not usually accumulate on these parts of the TV.
Posted on Oct 06, 2009
0 characters
1 Points
No picture on Samsung HP-R5052
Just a couple of things to try:
You say you tried another cable box and a roku. Are you using the same cables? Are you using hdmi, component or coax cables? Could be a bad wire. True high def tv 1080 requires an hdmi cable for the best picture. The next best choice is the component cable. This is a triple cable with red, green, & blue and provides 720 resolution. The least quality is the coax wire which will only provide low def standard quality picture. Sometimes people hook up 1, 2, or all 3 of these choices not knowing what it all means. If thats the case with your tv it may just be a matter of selecting the correct input on your tv with your remote. On your samsung remote there should be a button for input. Try pushing that button and make sure it's set to hdmi or component, whichever your using. If none of this, is it possible the plasma tv itself is defective?
Apr 08, 2014 | Samsung HP-R5052 50 in. Plasma HDTV
Picture is schinking in on both sides
the picture is narrowed on the sides when you are not on a high def program.
commercials will often be standard def even on a high def channel.
check you cable or satelite box setting to "stretch" analog programming automatically.
Apr 12, 2011 | Audiovox PLV16081 8 in. LCD TV
Pixel solarization around letters and faces. 52" LED Sony I've tried adjusting the contrast, back light, and all other adjustments.
there is some interference with all flat tvs and it would be interesting to know is this in hd or standard def? in standard def the tv has to upscale the picture to fit a 52" screen and you will get this effect. there is nothing you can do, however this should dissapear in high definition.
Nov 28, 2010 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Tv turns on and has sound but no picture. Only black screen, the menu from the cable or dvd cannot be seen.
Make sure your using a cable box that is compatible with a high def tv, if your tuning a high def channel and your converter does not support high def, it will only play the sound, no vidio at all.
Sep 25, 2009 | JVC LT42P789 42 in. LCD TV
Recieving hy defintion picture
You need to do the following:
1: use HDMI cable to connect Cable box to TV
2: Call Cable company to activate HD service
3: Enjoy!
You can use component input, but the HDMI is best HD quality!
I hope this helps! please rate highly!
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
Picture in high def does not fill screen
That is normal. Most HDTV's have a format or picture size option on the remote or menu. It will give you options like full, stretch ot zoom to fill in the blank spots. The problem is those settings can also distort the picture size so people look funny.
Feb 28, 2009 | Protron PLTV-37 37 in. LCD Television
How do I adjust the picture to fill the screen
i was having problems in the tv menu getting full screen. no matter what i did there was two black bars on each side of the screen. i have att u verse so i went into the cable menu to options. In the options tab i went down to system options then to aspect ratio. in this screen you get a few options like 4:3 standard definition and 1080i on high def screen. I chose 1080i high def and then played with the zoom function on my remote and the problem was solved. hope this helps
Nov 19, 2008 | Insignia LCDTV26 26 in. Television
Full screen view
in order to get the full HD experience you should be using HDMI cables. if you're using the white/red/yellow cables then your HD channels will not broadcast in full HD and you'll be stuck with the annoying black things around your screen
May 21, 2008 | Vizio L32 32 in. LCD HDTV
Only get 480p
Your friend is wrong you will get same resolution of 1080i whether you use component or Hdmi.
But you will need a high def input to tv in order to get this resolution EG high def cable box or satellite.
Mar 24, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV Logo
479 people viewed this question
Top Sony Flat Panel Televisions Experts
Mando Mojica
Mando Mojica
Brian Sullivan
Brian Sullivan
Are you a Sony Flat Panel Television Expert? Answer questions, earn points and help others
