Acer aspire z3761 all in one keeps freezing
Keeps freezing
5 Suggested Answers
  • 71 Answers
SOURCE: acer apire 3000 keeps freezing!
The first, best thing to do is to back up your data and do a system restore. Acer's have the restore function usually built into their acer system management software.
Restoring the computer will solve most issues. If you keep having issues after the restore you probably have a hardware error like a bad hard drive or bad memory.
Be sure to back up any important data as the restore will erase everything from the hard drive and set it back to the way it came from the factory
Posted on Nov 15, 2007
  • 37 Answers
SOURCE: Acer Aspire 5100 Freezes
I am not sure which you are talking about either. But I will venture to say that I had a similar problem once where setup would not complete on my system either. I initially thought that I had a bad or dirty disc but later after running a few tests, I found out that my HDD was full of bad sectors. Thus I ended up replacing the HDD and all is well. I would try running a stand alone formatting software or you could try doing a complete format vs. a quick format during Windows setup. If setup still won't complete after a complete format then run a surface scan or a HDD regenertion program to verify the integrity of the drive. This will tell you if you have a bad drive or not.
Posted on Sep 23, 2008
fawkwindows
  • 96 Answers
SOURCE: my brand newacer aspire one keeps freezing
Bull sh** geek squad is a rip off... update your bios
set up your setting for linux or crappy windows
http://support.asus.com/download/download.aspx?SLanguage=en-us
Posted on Dec 14, 2009
bronk50
  • 27725 Answers
SOURCE: how to configuration hard drive to factory default
Step 1:
Which operating system ?
Laptop computers can be wonderful devices, except when the need to troubleshoot arises. Acer laptops are no different. A quick way to fix many problems with an Acer laptop running Windows is to reset it to factory settings. Resetting your Acer laptop to factory settings can eliminate slow operation, registry problems, virus problems and spyware issues. What's more, a factory reset of your laptop may reduce the need for a full reinstallation of Windows.
Back up all necessary data to an external device such as a disk, flash drive or hard drive Make sure all programs are closed and shut down your Acer laptop. Detach any external hardware such as an external hard drive or printer. Press the Power button to boot your Acer laptop. Press "Alt-F10" on your keyboard when the Acer screen appears at the start of the boot-up process. Wait a moment while Windows loads the reset files. Select "Restore System from factory default" in the Acer eRecovery Management window. Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration. Click "OK" in the notice window to proceed with resetting your Acer laptop. Wait while your Acer laptop is reset to factory settings.
Posted on Mar 16, 2013
How to configuration hard drive to factory default
Step 1:
Mar 16, 2013 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire one d257-13608 freezes randomly
It's likely to be the BIOS that needs updating. Full solution and link to get the stable BIOS flash is here:
http://blog.robkershaw.com/2012/01/acer-aspire-one-d257-freezing-issue.htmlhttp://blog.robkershaw.com/2012/01/acer-aspire-one-d257-freezing-issue.html
Sep 07, 2012 | Acer Aspire One D257-13608 Intel Atom N455...
Acer aspire 5332 keeps on freezing , need to keep dest to manager open for it too work
try to turn off the laptop, remove the cables and battery and then press and hold the power button for 8 secs. Reinsert the cables and battery and turn it on. Check if the pc performs better.
Oct 09, 2011 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire 8920g keeps freezing
Try to 'recover' to factory settings or 'restore' to a prior time when the laptop didn't freeze up. May have contracted some malware.
Dec 20, 2010 | Acer Aspire 8920-6671 Notebook
Laptop freezing
replace the hard drive and clean out the fan
or just go buy a new hp and put you laptop on craigslist
Mar 27, 2010 | Acer Aspire 8920-6671 Notebook
My Acer aspire one AO751h keeps freezing up is there any solution p.s. My os is Vista home basic k
This is a known issue in Acer aspire one A0751h model laptops. Its because of faulty motherboard, ram and cooling system. Only way to get this fixed is through Acer service center. They'll replace the faulty hardware with new one. Try with the service center if your laptop is under warranty.
Mar 11, 2010 | Acer Aspire One AO751h-1153 (LU.S820B.101)...
Acer aspire one AO751h keeps freezing is there any solution?
let me ask you if all you have on your system is much and you like opening much application at the same time then if all this are found positive then all your work will keep on freezing ok.
Solution is this upgrade your memory and probably your harddisk space so as to allow all this free flow ok.
Mar 11, 2010 | Acer Aspire One PC Notebook
My brand newacer aspire one keeps freezing
Bring it to best buy's Geek Squad. Or if you do not want to spend more money, bring it back to the store where you brought it.
Dec 14, 2009 | Acer Aspire One PC Notebook
Mouse keeps freezing
It maybe getting too hot. You need to blow out all vents and fans. I have seen acer laptops get too hot, easily, so you need to make sure it is dust free.
G'luck
Nov 11, 2008 | Acer Aspire 3100-1405 Notebook
Acer apire 3000 keeps freezing!
Nov 15, 2007 | Acer Aspire 3000 Notebook
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
Computers & Internet Logo
David Payne
David Payne
