SOURCE: My Lasko Pedestal fan just stopped working completely
Its probably something simple, plug it into another outlet and make sure that outlet work also, if that dont work it will be in the control switch and i doubt the motor is burnt up. You can take srew driver and open up the control cover to see if there a fuse and check the wiring connection from the outlet to the control switch and make sure the fan is unplug before you open up the cover. Jiggle the wire inside the control unit than press and play with the button couple of time and plug it back into the outlet and see that will work. if not than have somone test the the motor with a volt meter making sure the motor still good. I believe it be more likely in the control swith unit. hope that work for ya
SOURCE: I have a Honeywell 16"
remove the battery from the remote for one day. See if it stays off. If it does replace the remote
SOURCE: i have a honeywell upright
The problem would be the burn out thermistor(FUSE), it is located in the winding of the motor itself.
Before that check the wiring connection in the speed switch, the main line might have cut off.
Using the tester, check the continuity of the fuse. You can't see the fuse, it is mainly covered and connected in the capacitor line.
The cause of the burned fuse is overheating, the shaft bushing needs oil or have to be replace!
Hope that helps you out!
